01-10-2016, 11:05 AM
2011 23' FB Flying Cloud
Augusta
, Kansas
EB ground clearance
Is the ground clearance better on an EB , than other models?
01-10-2016, 11:20 AM
2014 27' FB Eddie Bauer
Chelsea
, Michigan
No
Not so you'd notice, and if it is different, it's a matter of a fraction of an inch. In the past some less than fully informed people got all excited because the EB had 16 inch wheels while most of the other models at the time had 15 inch wheels but what those folks forgot to take into account is that the tires were slightly lower profile so the effective diameter of the tire/wheel combo is basically the same. I am assuming that you are asking this question in the context of "off road" performance to which I can say that the EB is just as vulnerable as any similar sized Airstream to dragging it's bottom on a rough surface.
The Eddie Bauer is still a great model with a lot of nice features and I would definitely get it again.
Bob Martel
WBCCI# 5766
01-11-2016, 12:07 AM
Some Guy
1968 26' Overlander
2021 25' Globetrotter
Nashville
Bob,
I was told by the dealer when we purchased our 2015 EB that it has a 2 inch higher clearance than other models. I later read that as well.
D
The Jarretts
Nashville, Tennessee
1968 26' Overlander
2019 RAM PowerWagon TV-Petrol Hemi
WBCCI # 22342
01-11-2016, 08:57 AM
Chelsea
, Michigan
Originally Posted by nashrover
Bob,
D
Dealers are notoriously wrong. Next time you are in a position to do so, measure your EB vs. another similar sized, similar aged Airstream.
Bob Martel
WBCCI# 5766
01-11-2016, 09:18 AM
Home of Vortex tuning
2013 27' FB Eddie Bauer
Spearfish
, South Dakota
The wheel/tire combo on EB's are slightly larger than the 15" wheel from the "standard" models. The spare tire carrier has to be bent a bit to allow the EB wheel/tire to fit. Larger, yes. Real gain in ground clearance, no.
"Chip Tank" is in Westwood Ca.
01-11-2016, 09:29 AM
2012 25' Flying Cloud
Battle Lake
It uses the same axles as other models of its size, the only difference is tire diameter. I believe someone measured the tires to be 1" difference overall, 1/2" difference trailer height.
Many of us have installed the same tires on our FC's and Int'ls giving us the same height as E.B. if there is any. There are good reasons to buy a Eddie Bauer, nice concept, but ground clearance is not one of them.
Doug and Cheryl
01-11-2016, 10:14 AM
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
, *** Big Sky Country ***Western Montana
Yes, prior to some other models adopting the larger wheel / tire ~2015. Make out of it what you wish, but we find the taller ground clearance noticeable particularly on the pivot / overhang on secondary roads / unimproved campgrounds.
01-12-2016, 08:56 AM
Chelsea
, Michigan
I certainly hope that all of you who are asserting higher ground clearance for Eddie Bauers have actually measured the ground clearance of their unit in several consistent locations and compared those measurements to a 25 or 27 FB model of similar vintage with the same tire pressure. Comparisons to decades old Airstreams, comparing a 27 foot unit to a 16 foot Bambi, simply relying on the wheel size without taking tire diameter into account, not adjusting for tire pressure, or worse yet, believing an RV salesperson is not going to get you the correct answer.
Let's see some field measured, comparative clearance figures between EB's and other comparable AS models in this thread. I've done the comparison in the past but did not keep the actual numbers and I do not have access to an non-EB model at this moment to remeasure. In my experience the minor differences in ground clearance were within the tolerances of Airstream's manufacturing process.
Bob Martel
WBCCI# 5766
01-12-2016, 09:59 AM
2013 28' International
Bozeman
, Montana
The 15" GYM is 28.3" diameter, the 16" Michelin is 29.4" diameter per Tire Rack. So, if everything else is equal it should be about a 1/2" additional clearance.
01-12-2016, 10:09 AM
Small Town
Yes, we did measure, Bob.
See this post as well - from another member ...
oops ...HW already posted it here, too ...
01-12-2016, 06:48 PM
Chelsea
, Michigan
I think we are "all correct." There may be indeed 1/2 inch of additional clearance with any Airstream with a 16 inch tire (including the Eddie Bauer) compared to an Airstream with a 15 inch tire, but #1, this is not a feature of the Eddie Bauer, just of the 16 inch tire (which I believe is standard equipment on a lot of current Airstreams,) and #2, in any event, 1/2" does not qualify as meaningful additional clearance in the sense of providing any added safety for rough roads or off roading which I believe was the OP's original point.
Bob Martel
WBCCI# 5766
01-18-2016, 01:15 AM
Augusta
, Kansas
EB ground clearance
Thank you all for your knowledge on this subject. Much appreciated.
