Old 01-10-2016, 11:05 AM   #1
2011 23' FB Flying Cloud
Augusta , Kansas
EB ground clearance
Is the ground clearance better on an EB , than other models?
submirj is offline   Reply With Quote
Old 01-10-2016, 11:20 AM   #2
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
No
Not so you'd notice, and if it is different, it's a matter of a fraction of an inch. In the past some less than fully informed people got all excited because the EB had 16 inch wheels while most of the other models at the time had 15 inch wheels but what those folks forgot to take into account is that the tires were slightly lower profile so the effective diameter of the tire/wheel combo is basically the same. I am assuming that you are asking this question in the context of "off road" performance to which I can say that the EB is just as vulnerable as any similar sized Airstream to dragging it's bottom on a rough surface.
The Eddie Bauer is still a great model with a lot of nice features and I would definitely get it again.
Bob Martel
WBCCI# 5766
Old 01-11-2016, 12:07 AM   #3
Some Guy
djarrett's Avatar
2018 28' Tommy Bahama
Nashville , Tennessee
Bob,
I was told by the dealer when we purchased our 2015 EB that it has a 2 inch higher clearance than other models. I later read that as well.
D
The Jarretts
Nashville, Tennessee
2018 27' Tommy Bahama
2015 F250 TV-Petrol
WBCCI # 22342
djarrett is offline   Reply With Quote
Old 01-11-2016, 08:57 AM   #4
Chelsea , Michigan
Images: 12
Originally Posted by nashrover View Post
Bob,
D
Dealers are notoriously wrong. Next time you are in a position to do so, measure your EB vs. another similar sized, similar aged Airstream.
Bob Martel
WBCCI# 5766
Old 01-11-2016, 09:18 AM   #5
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
The wheel/tire combo on EB's are slightly larger than the 15" wheel from the "standard" models. The spare tire carrier has to be bent a bit to allow the EB wheel/tire to fit. Larger, yes. Real gain in ground clearance, no.
"Chip Tank" is in Flagstaff Az.
CDONA is offline   Reply With Quote
Old 01-11-2016, 09:29 AM   #6
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
It uses the same axles as other models of its size, the only difference is tire diameter. I believe someone measured the tires to be 1" difference overall, 1/2" difference trailer height.
Many of us have installed the same tires on our FC's and Int'ls giving us the same height as E.B. if there is any. There are good reasons to buy a Eddie Bauer, nice concept, but ground clearance is not one of them.
Doug and Cheryl
Old 01-11-2016, 10:14 AM   #7
mefly2's Avatar
2015 25' FB Eddie Bauer
Yes, prior to some other models adopting the larger wheel / tire ~2015. Make out of it what you wish, but we find the taller ground clearance noticeable particularly on the pivot / overhang on secondary roads / unimproved campgrounds.
Old 01-12-2016, 08:56 AM   #8
Chelsea , Michigan
Images: 12
I certainly hope that all of you who are asserting higher ground clearance for Eddie Bauers have actually measured the ground clearance of their unit in several consistent locations and compared those measurements to a 25 or 27 FB model of similar vintage with the same tire pressure. Comparisons to decades old Airstreams, comparing a 27 foot unit to a 16 foot Bambi, simply relying on the wheel size without taking tire diameter into account, not adjusting for tire pressure, or worse yet, believing an RV salesperson is not going to get you the correct answer.
Let's see some field measured, comparative clearance figures between EB's and other comparable AS models in this thread. I've done the comparison in the past but did not keep the actual numbers and I do not have access to an non-EB model at this moment to remeasure. In my experience the minor differences in ground clearance were within the tolerances of Airstream's manufacturing process.
Bob Martel
WBCCI# 5766
Old 01-12-2016, 09:59 AM   #9
2013 28' International
Bozeman , Montana
The 15" GYM is 28.3" diameter, the 16" Michelin is 29.4" diameter per Tire Rack. So, if everything else is equal it should be about a 1/2" additional clearance.
HeadWest is offline   Reply With Quote
Old 01-12-2016, 10:09 AM   #10
mefly2's Avatar
Yes, we did measure, Bob.
See this post as well - from another member ...
oops ...HW already posted it here, too ...
Old 01-12-2016, 06:48 PM   #11
Chelsea , Michigan
Images: 12
I think we are "all correct." There may be indeed 1/2 inch of additional clearance with any Airstream with a 16 inch tire (including the Eddie Bauer) compared to an Airstream with a 15 inch tire, but #1, this is not a feature of the Eddie Bauer, just of the 16 inch tire (which I believe is standard equipment on a lot of current Airstreams,) and #2, in any event, 1/2" does not qualify as meaningful additional clearance in the sense of providing any added safety for rough roads or off roading which I believe was the OP's original point.
Bob Martel
WBCCI# 5766
Old 01-18-2016, 01:15 AM   #12
Augusta , Kansas
EB ground clearance
Thank you all for your knowledge on this subject. Much appreciated.
19' Bambi ground clearance/"lifting" Glenn Hansen General Repair Forum 13 09-16-2007 07:11 AM
Raise ground clearance on 25', '91 Excella? ldetsf Axles 11 10-18-2006 06:29 PM
What should the ground clearance be? 63air Towing, Tow Vehicles & Hitches 4 07-19-2006 01:01 PM
ground clearance/battery charge Kintscher Our Community 14 06-01-2005 03:36 PM
how much ground clearance? Chuck Plumbing - Systems & Fixtures 1 05-26-2004 10:10 AM
