Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Special Editions and Limited Releases > Eddie Bauer - All Models
Old 11-14-2019, 04:22 PM   #1
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
Dacor self leveling over Sikaflex 221?
Resealing vents while installing new Maxim skylights. Stripped off all old sealant and resealed with Sikaflex 221. I have several tubes of Dacor self leveling and would like to top over the Sikaflex. Not sure if the two might not react well to each other.
sheriff1 is offline   Reply With Quote
Old 11-14-2019, 05:16 PM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Not sure because I have never been able to find technical information on Dicor, but it never makes sense to caulk over existing caulk/sealer.
Larry
lsbrodsky is offline   Reply With Quote
Old 11-14-2019, 06:34 PM   #3
2002 19' Bambi
Lafayette , California
Try a simple experiment. Put some Sikaflex on a piece of scrap metal, let it set up, and put the Dicor over it. Let that sit around for a week or two and see what happens. Having it be exposed to the sun might help the experiment.
Tim
Tim A. is offline   Reply With Quote
No drill solar panel mounts SikaFlex-221 or 3M THB tape? cdufault Electrical - Systems, Generators, Batteries & Solar 23 04-09-2019 06:39 PM
Sikaflex 221 & Vulkem Questions Hans627 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 06-27-2016 07:22 PM
Is there anyone who uses Trempro 636 & Sikaflex 221 on a 70's AS bennyg Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 07-29-2011 08:16 PM
Sikaflex 221 gray? AirHog Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 05-19-2011 12:22 PM
SikaFlex 221 buy locally? rogerdodger Leaks - Weatherstrips, Gaskets, Caulks & Sealants 17 10-18-2008 05:37 PM
