Old 11-05-2013, 07:19 AM   #1
jasperkins's Avatar
2012 27' FB Eddie Bauer
colorado springs , Colorado
Cold Aluminum! Headboard ideas?
We have the 27FB EB, and have noticed now that the temperature is dropping the aluminum is COLD behind our heads. Any ideas for a headboard from the rest of the forums? Creative ideas to prevent the cold for us full-timers radiating off the wall in that location?
I have been tossing around the idea of buying a 12" board and wrapping it in fabric. Or even a nice cedar plank. Anything but the cold metal.
On a separate note, the Dyson Hot / Cold fan set at 72 and a speed of 4 keeps our trailer perfect now that temps have dropped to the high 30's. The Sleep Number bed is also nice!!
jasperkins is offline   Reply With Quote
Old 11-05-2013, 08:05 AM   #2
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Rivet snaps to the skin at the backseat height. Rectangle fabric, core of heavy cotton batting. Snap in place.
Or some leather/ vinyl
Rob.
robwok is offline   Reply With Quote
Old 11-05-2013, 08:17 AM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
One inch thick extruded foamed Polyethylene foam can be cut on the back side to allow it to bend. Then you can wrap it in some valuer foam covered blanket material that will give better insulation that just tag board. The blanket material uses urethane foam that has a 5 year life expectancy, but can easily be replaced.
Old 11-05-2013, 08:21 AM   #4
2010 25' FB Flying Cloud
Davenport , Iowa
Let your hair grow and wear a stocking cap; just joking. I am switching from a queen to twin and in the progress, I am going to use carpet squares on the walls for that same reason; cold Aluminum. Don't get your "behind" against the wall either, it could be like your tongue on the pump handle.
Airtandem is online now   Reply With Quote
Old 11-05-2013, 08:31 AM   #5
tinbender's Avatar
2001 16' Bambi
2013 23' International
Piedmont Region , North Carolina
Baby crib bumper pads.
tinbender is offline   Reply With Quote
Old 11-05-2013, 10:09 AM   #6
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Use the long pillow from the couch as your "headboard". Works for us (27fb fling cloud).
Old 11-05-2013, 10:09 AM   #7
jasperkins's Avatar
Great ideas. The one problem I have seen is that Double Sided tape doesn't appear to stay long on the cold metal. I think this is possibly from the condensation? I have used the Scotch 20lb double sided tape to hand a 10lb picture- and it fell off in 3 days- I expect to the temperate change and condensation.
I hate to drill rivets with snaps- something about putting permanent holes into the aluminum scares me.
Carpet squares- simple and interesting idea. However I think the extra "batting" / foam will provide a bit more insulation.
Old 11-05-2013, 10:12 AM   #8
jasperkins's Avatar
Wow- never thought of that- using the couch pillow!
Old 11-05-2013, 10:15 AM   #9
W , New England
DW found that suggestion in the forums somewhere - wish I knew who said it first!! It is a great idea and works well! Plus nothing else to carry or "stick" to your aluminum.
Old 11-05-2013, 11:15 AM   #10
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
I have used the blue backpacker mattress foam for insulation on many projects. Easy to cut & glue for shape.
This area is on my list along with under the bed over the outside storage hatch.
Currently I'm using some of those EB down pillows, , ,
Psst, suction cups
"Chip Tank" is in Flagstaff Az.
CDONA is offline   Reply With Quote
Old 11-05-2013, 11:32 AM   #11
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Bolsters Are the Answer
Airstreams once came with bolsters for this very reason.
During the Beatrice Food years that everyone complains about, these were a nice feature.
You can make your own with a 1/4 inch fiberboard backer cut to the size you need. 1/4 foam or thicker to taste. Material of your choice from Hobby Lobby or Walmart.
It's a quick and easy project that provides unbelievable comfort.
Airstream actually glued the bolsters to the inside skin with construction adhesive. That's why you want the leave the fiberboard exposed on the backside. The fabric is wrapped about 2 inches over the edge all the way around the bolster.
Hope this helps.
P.S. If you aren't handy I sure Greg Schmuker at TBRich on these forums will do it for a very fair price.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 11-05-2013, 11:36 AM   #12
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Just velcro some of the hated "mouse fur" to the offending area.
Warm walls, one thing we really like about the Classic.
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 11-29-2013, 11:35 PM   #13
mefly2's Avatar
2015 25' FB Eddie Bauer
Velcro whatever you'd prefer to the wall for insulation ... we use memory foam. We both have allergies and have stayed away from the mouse fur.
Old 11-30-2013, 04:06 AM   #14
2005 28' Safari
saline , Michigan
We cut some heavy carpet pad to the right shape and put it between the window and curtain. Really makes a difference reducing the draft off that window and darkens the room in the morning when early sunlight would otherwise awaken me.
Kosm1o is offline   Reply With Quote
