11-15-2014, 05:53 PM
Seattle
CheapHeat install
11-15-2014, 06:01 PM
1993 34' Excella
Estancia
, New Mexico
If it does not burn propane is it electric or what? How cheap is cheap?
11-15-2014, 06:07 PM
Seattle
Yep, it's electric. 1800 watt heating coil that runs instead of the propane burner (uses existing furnace fan and duct work). It's cheapest when you don't have to pay for electricity but may still be cheaper than propane depending on electric rates.
On the big 5th wheels, the heating coil can be configured for 5kW @ 240V but on the Airstream 30A/120V hookup, it is limited.
11-15-2014, 06:11 PM
1993 34' Excella
Estancia
, New Mexico
Does it run on 120 AC? Does it need a dedicated circuit? How much does the unit cost?
11-15-2014, 06:26 PM
Seattle
It is configurable for either 120 or 240 depending on the hookup the RV has. For example the big 5th wheels and class-A coaches with 240V/50A hookup can be configured for 5kW of heat at 240V, but on the smaller RVs like the Eddie Bauer with a 120V/30A hookup, the CheapHeat is wired for 1.8kW/120V.
The power ties into the shore power hookup and then has its own breaker (that's the gray box next to the toilet paper in the storage compartment in one of my pics). It costs $500 not installed. rvcomfortsystems.com
11-15-2014, 06:30 PM
Seattle
Regardless of the CheapHeat itself, I feel like this worked out as a great proof of concept that good ol' fashioned aluminum can be made to look pretty good as cabinet material inside a modern Airstream.
11-15-2014, 06:54 PM
Rivet Puller
2003 28' Safari S/O
Atlanta Burbs
, Georgia
If one boondocks in cooler climates the utility value may be nullified.
11-15-2014, 07:14 PM
Seattle
Indeed. You could run it off of something like the 2400W Yamaha, but you'd be better off running on propane. Going back and forth is the flip of a switch.
11-15-2014, 09:02 PM
Rivet Puller
2003 28' Safari S/O
Atlanta Burbs
, Georgia
I missed the explicit "both' propane and electric capability in your earlier post. If it is dual powered as your latest post implies then it is a nice option to consider.
11-15-2014, 09:44 PM
1986 32' Excella
Canton
, Georgia
Wow, so it is propane AND electric? This is really cool! Where can these be ordered?
11-15-2014, 09:53 PM
Seattle
Yep, it adds onto your existing propane furnace. Then you're left with a switch mounted wherever is convenient to flip between gas and electric. Be forewarned though, things can be a bit tight inside of our Airstreams. This is why I had to build the custom cabinet. It was a fair amount of work.
Beats tripping over a space heater or burning propane when plugged in.
You can order them at rvcomfortsystems.com or email info@rvcomfortsystems.com. It is recommended that an RV service center install them or be pretty mechanically inclined.
11-17-2014, 12:51 PM
1986 32' Excella
Canton
, Georgia
So it doesn't replace your propane furnace, it adds to it?
11-17-2014, 06:54 PM
Seattle
Yes, exactly.
Most of the RV furnaces (made by Atwood or Suburban) have what is effectively a blank piece of sheet metal on the end of the furnace opposite the exterior wall of the trailer. This piece of sheet metal has holes in it where your ducts attach. With the CheapHeat, this end cap of sheet metal is removed and the CheapHeat cabinet goes in its place, adding about 6" of overall length to the furnace (this is where the clearance needs to be considered). The existing ducts then reattach to the CheapHeat.
The CheapHeat cabinet itself includes a heating element similar to what you would find in a residential electric furnace. A separate controller box is mounted nearby to allow control of the furnace fan separate from the propane burner.
12-10-2014, 11:41 AM
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
Please post more info / link and advise if you also offer the required and matching cabinet extension...total cost?
12-10-2014, 04:05 PM
Wise Elder
2010 30' Classic
South of the river
There are alternatives.
http://www.airforums.com/forums/f427...ble-64289.html
1500w/1800w electric heat will only work when the weather is mild, down to about 55 degrees, I find. Heat distribution is much less of a problem under these conditions than in extreme cold, so the use of the ductwork doesn't provide as great an advantage as it does for the furnace.
I have been happy with my setup although in practice I find it has limited applicability. We don't go through that much propane when the weather is mild enough for the electric heat to be a viable alternative.
12-10-2014, 05:44 PM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
Really? how so? just not enough wattage? At 55F, I wouldn't even turn on the furnace. not cold enough to need any heat.
I've used a cheap cube heater down into the upper 20's; it was able to maintain the temp. Of course, my trailer is a lot smaller than yours, which I'm sure is a major factor.
I'd like to have an electric "furnace"...IMO, the propane ones are really "electric", because they use so much electricity to run the fan. You can't really use it unless you're on a full hookup, anyway, so why bother?
(unless, of course, you have a gi-normous battery array and 400watts of solar).
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
12-14-2014, 04:03 PM
Seattle
You can find out everything you need at rvcomfortsystems.com. The cabinet was custom made by a local sheet metal shop here in Seattle. I had it made up out of 0.080 aluminum sheet reinforced with 1/2" plywood so that it wouldn't been if someone kicked it. I reused the return air vents and just stacked them vertically. I could probably dig up the measurements used for the cabinet, but it isn't something that is orderable. Note that many RV installs don't require a custom cabinet at all. Because if the cabinet, it was a fairly involved process.
12-14-2014, 04:13 PM
Seattle
A gas furnace has a flue that exhaust 40% of input. Which means that 25,000 BTU furnace puts out 15,000 BTUs and then you have a 90 sec pre purge and a 60 sec post purge. This means every heat cycle has 2 1/2 minutes with no fire so, true output is around 11,000 btu at the register. The 1800W CheapHeat has 6150 btu at the register.
At 1800W, it will easily go down to 30 degrees maybe as low at 25 at 70 inside. Figure it 40 to 45 degrees above outdoor temp on your trailer.
12-14-2014, 05:48 PM
Contributing Member
Austin (Hays County)
You must have no insulation. A small ceramic heater will keep my Classic 28 comfortable down to about freezing, once the trailer is no longer cold-soaked..
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
