Old 11-12-2013, 07:15 PM   #1
2014 25' FB Eddie Bauer
Knoxville , Tennessee
Back Hatch Lock
Well, I had the silver gal out in the driveway and put the key in to unlock the back hatch. Much to my surprise, when I turned the key, the entire lock mechanism came out. Bummer...it is these "little" issues that really bug me as far as AS quality is concerned. Just checking to see if anyone else has had this problem. Just means another phone call to customer service and another trip to the dealer...I guess I should be grateful my dealer is close.......At least the hatch is still locked!
Jfed is offline   Reply With Quote
Old 11-29-2013, 11:16 PM   #2
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
Yes, ours hasn't worked since new. Fortunately, there is a lock release / engage from the inside of the hatch. It might be cheaper to just drive by a local locksmith as it sounds like it is the retention pin in the lock cylinder - and ask your dealer to reimburse or credit you.
Old 07-31-2014, 02:19 PM   #3
KristiBear's Avatar
2014 27' FB Eddie Bauer
Cool , California
When we got our EB the salesman said "You have to lock and unlock it from the inside only" so we thought our broken lock mechanism was a "feature." I kept puzzling over why there was a key for it and a keyhole on the outside if it wasn't meant to work. And it didn't work, just turned freely, with no effect.
When we took it in for other warranty work we questioned the purpose of the keyhole and told him what the salesman had told us, and the service manager was all "No, no no. That should definitely lock and unlock from the outside." And now it does. :-)
KristiBear is offline   Reply With Quote
Old 11-24-2014, 05:02 PM   #4
StagrLee's Avatar
2012 25' FB Eddie Bauer
My problem was different. The outside key lock would only turn a 1/4 turn, not the 1/2 turn required to unlock the rear handle. I took it apart and found a stuck part. I sprayed some dry teflon lube on it and it all works now.
I learned that the inside handle will turn to open/close the rear hatch no matter what the position of the outside key lock is in (good to know). The outside lock only effects weather or not you can use the outside handle. Here is a photo of the sticky part... Takes about 15 minutes to do as there are only 8 phillips head screw to remove the large mechanism panel cover.
"Stagr" Lee
2012-1/2 25' Eddie Bauer
StagrLee is offline   Reply With Quote
