Old 11-11-2014, 06:02 AM   #1
2015 27' FB Eddie Bauer
Aston , Pennsylvania
Anderson Leveling on Eddie Bauer
I read in another post where people are using the Anderson Leveling system on their Airstreams.
3600 - Ultimate Trailer Gear duffel bag
There was some discussion around trimming if they had 16" wheels due to them not fitting. Was curious if anyone on the EB forum was using these and had 1st hand experience.
I'm picking up my trailer in a few days so need to get 'something' here. My thought with the Anderson product is the following: I will be getting a rear view camera which is a license plate mount attachment on the EB. When I get to a spot, I can rig up a system to place a level out in front of the camera clamped off of the rear bumper. From the dash, I'll be able to backup, watching the level from the TV and stop once level. Not sure if that's do-able or not.
Thanks.
BASE729 is offline   Reply With Quote
Old 11-11-2014, 07:30 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I use the Anderson leveling chocks. The only issue I have had is the front one has a tendency to slide backward on slick cement pad when reversing to lift the wheels. My fault for not jamming them under the wheel enough. They are very easy to precisely adjust the trailer level. As a solo traveler I use the get out and look as required technique. If you have not done so, check out the video on Andersons web site.
MICHAEL
Old 11-11-2014, 08:21 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Thanks.
If you mount the level on the trailer frame or have a trailer level mounted on the front of the trailer and can see it from the camera it will work. You will soon learn the amount of return the system has when you release the brakes and put the TV in park. AS you get used to this return you will just drive beyond the level point before stopping. This will put the trailer level as you get out to chuck the wheels.
2004 Excursion 4x4
Old 11-11-2014, 08:37 AM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
There is a small bubble level on the top of your tongue jack which will indicate level as close as you will ever need it. Just take a few boards along to stack and level close as needed, you will find it a very simple process after a few times. Fewer gizmos make for a better travel experience.
There is a gizmo in this process I really like and that is two Fast-way One Step chocks. Just set them between the wheels and step down to chock the trailer, lift the cable to remove. Very easy and secure. If using boards to level, add a board under this chock as well.
Doug and Cheryl
Old 11-11-2014, 10:10 AM   #5
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I have the Lynx levelers. I've only had to use them twice. They will slide, too.
I like the idea of having a level on the front of the trailer where it can be seen in the rear view camera. I have some stick-on levels in a kitchen drawer in the trailer. I guess I should stick them on-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 11-11-2014, 11:45 AM   #6
SteveH's Avatar
Common Sense , Texas
I use the Andersen's with my three axle 34' equipped with 16" wheels/tires without issues. I like them. Yes, it's more to carry, but if you don't need to level, you can use the chock part of them as chocks, something you need to carry anyway, so it's really not that much more to carry, IMHO. Another good thing about the Andersen's is you can use them on a tandem or three axle to lift the trailer to change a bad tire, so you probably don't need to carry a jack.
Regards,
Steve
Old 11-11-2014, 03:36 PM   #7
dznf0g's Avatar
Oswego , Illinois
About the slipping or skidding.....see the black "mat" in the kit in post #1? I made a bunch of those for legos in sand and to put under the Andersons on concrete. They stop the skidding and prevent legos from sinking in sand as well. I made mine out of the 1/8" thick rubber flooring squares from your big box store.
-Rich-
25 FB Eddie Bauer :: 2012 Airstream Eddie Bauer Jennybeth Airstream Registry Discussions 0 09-26-2013 06:28 PM
Eddie Bauer :: 2012 Airstream Eddie Bauer 25' FB screamstream Airstream Registry Discussions 3 12-12-2011 03:00 PM
Eddie Bauer/FirstAscent Winter Tour in a Pan America Brett - TTT Commercial Listings 6 06-24-2010 09:24 PM
Timeless builds winter tour trailer for Eddie Bauer Brett - TTT Commercial Listings 9 03-20-2010 11:18 PM
towing with Ford Explorer (Eddie Bauer) harlanghoffman@sbcgl On The Road... 11 11-23-2005 03:42 PM
