Old 05-27-2016, 04:10 PM   #1
RivetingTravels
RivetingTrvl's Avatar
2015 25' FB Eddie Bauer
2013 30' International
Richmond , Virginia
Adding Awning Package to 2015 EB25
We're about to pick up our 2015 EB25, which, sadly, does not have the S.S. and Rear awning option. Has anyone gone through the process of adding them after the fact? Better yet, does anyone have any leads on a set that isn't being used? I found a S.S. awning on eBay for around $400 new, but it's for a EB27, which, of course, won't fit.
Michael & Michelle | Riveting Travels
2015 25 Eddie Bauer (Mossy) & 2015 Ford F150 EcoBoost (Skye)
2012 30 International Signature (Shiny) • 2011 Camplite 16DB (Tiny)
WBCCI 22386 | SKP 111234 | Follow Us!
BlogFacebookTwitterInstagram
RivetingTrvl is offline   Reply With Quote
Old 05-27-2016, 04:30 PM   #2
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
If you have a very qualified dealer who can give references on metal work, they can install the ZipDee street and rear awnings. Make sure they order the correct fabric to match what you have curb side.
We had the dealer do this on our 2013 25FB International Serenity. We were able to order the ZipDee lawn chairs with the fabric that matched the awnings. Since our 2015 23DInternationalSerenity has the same awing material that the 25FB had, the ZipDee chairs match as well.
The 23D and Classic both were built with complete awning sets.
Old 05-27-2016, 07:36 PM   #3
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
We had rear and SS awnings added to our 2013 25FG FC by an independent third party who had done quite a few before.
I suggest before having the SS installed, visit and sit in a trailer (any AS model) with a SS awning, and see if you like how much view it blocks. Carefully measure the distance from the belt line trim to the bottom mounting of the awning on the trailer, and the length of the awning fabric. Have your installer match that, or not, depending on how you like what you see. I say that because on our trailer, the installer mounted the feet lower than the normal factory position, and the awning restricts our view more than we like. This change also resulted in the hold-open hook being several inches lower than normal, which put it at a place where it flexed the area around it a lot.
Also, when you take delivery, make sure the travel latch engages properly, and all the mounting feet are properly sealed against leaks.
SSquared is offline   Reply With Quote
Old 08-20-2017, 03:53 AM   #4
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Old thread, but why not call the Zip Dee factory direct? They might still do installations as well as make the awnings.
Paula
Adding second battery to a 2015 22' sport - rosie29 Batteries, Univolts, Converters & Inverters 13 12-20-2015 07:14 PM
Adding an awning mprokop87 Awnings 4 07-23-2015 06:12 AM
Adding an awning to 1970 Overlander TroutStream Awnings 5 02-12-2015 05:58 PM
Adding an awning if not originally installed. Mark_S Awnings 5 08-29-2013 05:52 AM
34' Slide Out and Factory Tow Package - 2002 Classic jcanavera 2001 - 2005 Classic 17 06-30-2003 10:25 AM
