TinKerToy
Jack Roger Jack Roger is offline
Airstream Registry
Airstream Name TinKerToy
Year 1959
Make Airstream
Model Tradewind
Length 24'
Options None
1959 Airstream Tradewind
Overview As found had floor rot limited to area around doorway. Was missing the L-77, found one here on the Forum. Shell was very oxidized and has "beauty marks" from years of use. Was missing original door step, had to fabricate a new one from scratch. Frame was rust free, but some outriggers had been damaged from previous tire blowouts.
Exterior
1959 Airstream Tradewind Exterior 1959 Airstream Tradewind Exterior 1959 Airstream Tradewind Exterior
I am in the process of installing custom made louvered vent for the refrigerator (to hide damage to the skin from the door hitting the side of the trailer). The first two passes of polishing have been done. I have to finish polishing with Nuvite polish.
Interior
1959 Airstream Tradewind Interior 1959 Airstream Tradewind Interior 1959 Airstream Tradewind Interior
As found the trailer had most of the original cabinetry. Original wood was mahogany, pickling stain from the factory. It had been painted over by PO. I have re-built the dinette, the dresser, the side bed and a cabinet for the refrigerator with a hidden compartment for a flat screen TV/stereo. Used formica boomerang pattern for both the kitchen and the bathroom counters. The trailer came with none of the original lighting fixtures.
Customization
1959 Airstream Tradewind Customization
Mohagany dresser top finished with envirotex.
Systems and Running Gear
Things still left to be done. Plumbing and electrical. I am going to use the Curve port a potty since the coach came with no black tank and I don't want one. Still have to update the trailer brakes, install new belly pan and plumb propane lines.
Tow Vehicle
2000 Toyota Tundra.
Old 05-10-2014, 07:20 PM   #2
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
Nice, thanks for posting.
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 05-12-2014, 10:54 AM   #3
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Looks great Jack. Let me know if I can assist your rebuild process.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
