The Overlander
Janet H's Avatar
Janet H Janet H is offline
Airstream Registry
Airstream Name The Overlander
Year 1964
Make Airstream
Model Overlander
Length 26'
Options International
1964 Airstream Overlander
Overview Built in CA and rescued from a duck hunting club using it as a duck blind. This trailer was painted camo....
Exterior
1964 Airstream Overlander Exterior 1964 Airstream Overlander Exterior 1964 Airstream Overlander Exterior
Patched holes, shortened street side lower window to accommodate new seating area, added forward facing scare light (to cover hole). New axles, new plumbing, new, systems, new bumper box (old one was gone). Removed aftermarket awning, replaced all window seals and glass and polished trailer. Most windows had interior latches and operators replaced.
Exterior patches were used where old furnace and water heater were removed.
There's a detailed discussion about updates here: http://www.airforums.com/forums/f157/new-project-1964-overlander-88805.html
Interior
1964 Airstream Overlander Interior 1964 Airstream Overlander Interior 1964 Airstream Overlander Interior
We tried to keep the intent of the 64 design in tact but reconfigured the area around the toilet, removing bench to make this space functional. We also changed front couch to an L shaped seating arrangement with a pedestal table that can be removed.
New sink, fridge, furnace and updated counters were added and the original (and badly damaged) stove was swapped out for a stove from a 1977 Tradewind.
The subfloor was repaired with 2 sections replaced (near front door and in back in bathroom) and new floating floor added.
These pics are the trailer as we found it -->
Customization
1964 Airstream Overlander Customization 1964 Airstream Overlander Customization 1964 Airstream Overlander Customization
Counter over fridge was extended through the vertical closet. That closet was cut in half, retaining the upper storage space and lower portion to accommodate counter extension. The door was reworked to cover new smaller closet spaces. Two fantastic fans were added and the astro dome replaced with custom cover.
On the exterior, we added a new bucket fillable water fill (off a mod seventies argosy) and outdoor electrical plugs.
Systems and Running Gear
1964 Airstream Overlander Systems and Running Gear 1964 Airstream Overlander Systems and Running Gear 1964 Airstream Overlander Systems and Running Gear
All new. New axles, new brakes, new wheels and tires, new propane tanks, new, new, new.... Please send cash
We also added a small gray tank in the street side rear closet and replaced the fresh water tank. New inverter, new furnace, new water heater, solar on roof, still considering the need for AC or not.
Other Information
1964 Airstream Overlander Other Information 1964 Airstream Overlander Other Information 1964 Airstream Overlander Other Information
The bathroom reconfiguration was a substantial project. The batteries, electric panel and plumbing lines had to be moved. The batteries were moved to space under the curbside bed. The electric panel was moved inside into bathroom closet, and then empty space in the rear where this stuff used to be was enclosed becoming part of the bathroom interior. All plumbing lines and electrical lines had to be rerun. new dump valves were added in rear under the aft streetside bathroom cabinet.
Old 07-14-2013, 01:05 PM   #2
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Looks great.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 07-14-2013, 03:04 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
The Overlander :: 1964 Airstream Overlander
Greetings Janet!
Your '64 Overlander looks FANTASTIC! As you know, I am very fond of my '64 Overlander and I hope that you enjoy yours as much as I have enjoyed mine!
Happy Travels!
Kevin
Kevin D. Allen
AIR #827
