Susie
mikesSE's Avatar
mikesSE mikesSE is offline
Airstream Registry
Airstream Name Susie
Year 2007
Make Airstream
Model Safari SE
2007 Airstream Safari SE
2007 Airstream Safari SE 2007 Airstream Safari SE 2007 Airstream Safari SE
Overview New from Sagon in Feb.2008
Exterior
2007 Airstream Safari SE Exterior 2007 Airstream Safari SE Exterior 2007 Airstream Safari SE Exterior
OEM door handle added to lower door for handicap access.Inner door panel reinstalled with no alteration.Retains original handle operation inside and out.
Interior
2007 Airstream Safari SE Interior 2007 Airstream Safari SE Interior 2007 Airstream Safari SE Interior
Formica tops scrapped and new Corian tops/w undermnt sinks fabricated and new faucets installed.New oxygenics shower head installed to lessen water useage.LighteningRod water heater element/kit installed to lessen propane useage.New china toilet installed 06/13.
Customization
2007 Airstream Safari SE Customization 2007 Airstream Safari SE Customization 2007 Airstream Safari SE Customization
Hand rails added in bed and bath area.Shower door removed and folding curtain installed.New temperpedic mattress cut to fit corner bed area.L-couch was scrapped.New riser built for storage and raise height of new Riveted chairs.New drink tables fabbed on outside of each chair.
Systems and Running Gear
2007 Airstream Safari SE Systems and Running Gear 2007 Airstream Safari SE Systems and Running Gear 2007 Airstream Safari SE Systems and Running Gear
ALL halogen lighting changed to LED.New AGM batteries installed.Cabinet locks installed after Jack Daniels incident.1500w. inverter installed under front couch for dry camping TV.Rear wired camera installed above license plate.
Other Information
2007 Airstream Safari SE Other Information 2007 Airstream Safari SE Other Information 2007 Airstream Safari SE Other Information
Microwave was removed from area above refrigerator and a door made to use space for storage.Then new stainless microwave and trim was installed below sink .Range,exhaust hood,converter and furnace cover painted 'hammered metal'finish.
Tow Vehicle
2007 Airstream Safari SE Tow Vehicle 2007 Airstream Safari SE Tow Vehicle 2007 Airstream Safari SE Tow Vehicle
1997 2dr Tahoe[big Blazer]Z71-7000lb.tow pkg.Load range E michelin tires installed on Tahoe.Air shock absorbers to adjust trailer tongue height. 7500lb.SwayPro hitch.Rear view monitor on dash,cameras on hitch,luggage rack,and rear of trailer to aid towing visibility.GM383 crate motor added 06/12.MonsterTransmission 4L60E added 04/13.TirePressureMonitor system added 07/13.
Old 10-20-2011, 08:59 PM   #2
Tin Trekkers's Avatar
2007 23' Safari SE
Matawan , New Jersey
Love what you've done!
"We had the same pattern upholstery in our 2007 SE. Look at our registry under MikesSE. Our sofa is still the same as yours,but we have added a few mods to help my wife get in and around the trailer[she uses a wheelchair]. This size trailer is perfect for us.To see yours posted is a delight."
Oh my! Those counter tops and sinks are gorgeous. We also were thinking about the grab bars by the bed and in the bathroom. Nice to see how you installed them - looks great. Good idea with the microwave...hard to see what's going on up there. Thanks for the inspiration. No major modifications are in the budget right now but we can start planning ahead.
Happy traveling...
Claude & Marianne
2007 23' Safari SE Lounge (IdaJune)
'05 Toyota 4Runner LE 4.7 V8 4WD w/ tow package
What if the Hokey Pokey really IS what it's all about?
Tin Trekkers is offline   Reply With Quote
