Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Registry Discussions
Ohana
Erik Olson's Avatar
Erik Olson Erik Olson is offline
Airstream Registry
Airstream Name Ohana
Year 1974
Make Airstream
Model Ambassador
Length 29
1974 Airstream Ambassador
1974 Airstream Ambassador 1974 Airstream Ambassador
Overview Rear Bath, Mid-Twin with Bunks.
Original bulkheads and cabinetry. In 2022, the original front gaucho was removed, and a new u-shape "UltraLounge" fabricated / installed.
Corian Glacial and Everest solid tops in galley, lounge, rear bathroom.
Ohana74 was renovated in 2020-2021 by Capital City Customs, with updated rear frame, outriggers, subfloor, bath & stainless shower, sink and Corian countertops.
New kitchen galley featuring Corian Glacial countertop, stainless sink, Suburban gas range.
Exterior
1974 Airstream Ambassador Exterior 1974 Airstream Ambassador Exterior 1974 Airstream Ambassador Exterior
- Cyclo polish in 2021
- White rubber finish on roof
- Underbelly restoration, banana wraps restored on English wheel, and black finished
- Frame restoration / outriggers / new rear bath subfloor in 2021
- Updated original Carefree awning to stainless hardware
- Replaced 1/2" belt and 1" rub rail with blue goods from Out-of-Doors Mart
- Painted beltline end caps with Rustoleum Sail Blue paint
- Painted tail light bezel flute rings with Rustoleum Sail Blue paint
- Painted International placards with Rustoleum Sail Blue, Rustoleum Red and White Automotive paints
- New LED running light package
- Barker hitch jack installed
Interior
1974 Airstream Ambassador Interior 1974 Airstream Ambassador Interior 1974 Airstream Ambassador Interior
- NEW 2022 Ambassador UltraLounge with three configurations: u-shape; curb-side / streetside couches; full-size (residential dimensions) bed.
- Wilsonart NeoWalnut tabletop surfaces and lounge cushion endcaps.
- New custom rear bath with Corain Glacier u-shape countertop, stainless fronts with "skylight" style aluminum boxed cubbies, lined with charcoal trunk fabric
- Carpet removed, Stainmaster Burnished Oak Fawn vinyl flooring installed (lengthwise-orientation)
- Re-upholstered gaucho
- Updated original light shades
- Updated nose inserts
- Replaced door and most window metal screens with black fiberglass wire
- Replaced Thetford AquaMagic toilet with Dometic 310
Customization
1974 Airstream Ambassador Customization 1974 Airstream Ambassador Customization
2020 - 2021 Renovation - Bathroom and kitchen update completed. Replaced Thetford AquaMagic toilet with Dometic 310. New Atwood 10G water heater (Bowen original).
Installed Stainmaster brand vinyl plank flooring "Burnished Oak Fawn" in forward cabin.
Systems and Running Gear
New Dexter Torflex Nev-R-Lube / Nev-R Adjust axles from Andy at Inland RV.
Tow Vehicle
1974 Airstream Ambassador Tow Vehicle 1974 Airstream Ambassador Tow Vehicle
2015 VW Touareg TDi V6 Lux
Old 09-28-2011, 07:32 PM   #2
Erik Olson's Avatar
1974 29' Ambassador
CONCORD , North Carolina
Send a message via Skype™ to Erik Olson
Ohana 74 vanity plate. Now, what to do about that Yankee style plate light? Get in line ($$)!!!
Erik Olson is offline   Reply With Quote
Old 10-04-2011, 01:47 PM   #3
Erik Olson's Avatar
1974 29' Ambassador
Changed out main door rubber seal with part from Out-of-Doors Mart. First removed old, cracked rubber seal with razor blade, steel wire brush and finally a nylon bristle brush.
With the door open against the trailer, I started on the bottom trailing edge of the door and worked my way up and over without stretching the material at all. The bottom is sealed with a cut piece once you've done the upper part of the door in a continuous run. Note that the old seal on the 1974 Ambassador was under the hinges - this is not the case with the new seal.
Will post photos.
Old 10-11-2014, 07:57 PM   #4
Erik Olson's Avatar
1974 29' Ambassador
Ohana received new upholstery this week to celebrate her 40th birthday!
Erik Olson
1974 Ambassador 29' Ohana
www.overlandfilmstudios.com
Old 04-21-2016, 08:45 AM   #5
Erik Olson's Avatar
1974 29' Ambassador
With a bit of help from Andy at Inland RV, we completed the axle replacement on Ohana this week. All the appropriate numbers from the original Henschel axles were provided to Inland to try and get the replacements manufactured to match the original specification. With two scrappy men, working in the parking lot of a well-equipped race shop, this was a five hour job, wheels off, to wheels on.
Just a couple of notes on this:
  • REPLACEMENT AXLES MAY HAVE WIDER O.D. SQUARE TUBING THAN ORIGINALS - CUTTING REQUIRED!!! New Dexter axles square tubing was about 3/16" wider O.D. than the originals, requiring the use of a plasma cutter on the original axle bracket opening. We widened it up roughly 1/8" fore and aft of the axle, grinding and then treating the surface prior to jacking the new axles into place.
  • The new Dexter axles were an exact match to the Henshel originals when measured from inside the curbside mounting bracket to the streetside mounting bracket. PERFECT!
  • MOUNTING HOLES A BIT OFF... The axles are secured to the original factory (tandem) axle bracket by two graded bolts per wheel. These bolts, washers and nuts are provided with the new axles. Unfortunately, no matter how we cheated the axles fore and aft, the bolt holes on the new axles didn't quite match up. We decided to favor the aft hole, which is really a vertical slot, for all four mounts, in order to keep the axles consistently aligned from a fore / aft standpoint. Once these rear slots were mated to the tandem axle bracket, it was necessary to use the plasma cutter again on the forward axle bracket holes to notch that vertical slot. This unfortunate extra work (and slop) could be avoided if the purchaser were asked to provide Inland / Dexter with one additional measurement: DISTANCE, MEASURED ON CENTER, FROM BOLT-TO-BOLT ON THE ORIGINAL (TANDEM) AXLE BRACKET. A quarter inch matters.
  • SHOCK MOUNT BRACKETS MUST BE WELDED ONTO TORSION ARMS... Inland (and I suspect others) ship the shock mount brackets and mounting hardware separately, requiring that the installer weld on the new shock mounts. Thankfully, Inland takes the time to pre-weld the studs to the brackets. BE AWARE that you or your installer will be required to weld these shock mount brackets to the axle torsion arms. We measured, inside-to-inside (67-7/8", in my case) the distance from shock bracket to shock bracket on the original Henschels and matched that on the new Dexter axles. Once we'd found a good compromise that would put the two brackets equidistant from each other on their respective torsion arms, we tacked the end of each bracket and double checked the measurement against the originals. The metal thickness of the torsion arms seems to be thicker where it flares out on the circular ends, and welding changes as you would expect as you get toward the thicker metal. Unless you break the hubs off, you will not likely be able to access the outside of the bracket to filet there. We only welded up the inside filet and it won't likely ever come off. After all, we all know these shocks do nothing anyway.
  • CONNECTING ELECTRIC BRAKES... Ohana has a "Romex" type of 12AWG(?) "Trailer Brake Wire" that penetrates the belly pan near each hub. These were just long enough to make to the new Dexter axles, utilizing butt crimp connectors. We slipped heat-shrink (1/4"-1/8") tubing onto each wire to try and keep water and dirt out of the connections for as long as possible. The two wires that come on the Dexter replacements are both white, neither of which is striped. We made the trailer's white wire to the top wire on the hubs and the trailer's black wire to the bottom wire on the hubs.
Thanks to Andy for everything he does. He is a walking encyclopedia of knowledge and his counsel is much appreciated. From date of order to pick-up at a local shop was about three weeks. The hardware from Inland arrived in less than five days. Nice!!!
Erik Olson
Old 08-26-2021, 10:11 AM   #6
Erik Olson's Avatar
1974 29' Ambassador
2021 Renovation
So many updates to the trailer, with almost a year away at Capital City Customs in North Carolina.
Extensive rear frame and outrigger work, with new subfloor and back bumper / storage pan.
Complete exterior refinish and Cyclo polish. Underbelly restoration and update to modern black finish. Original front wraps went on English wheel.
Inside, new Corian countertops in the original galley configration. New Suburban cooktop. Custom rear-bath with Corian u-shape countertop, stainless shower stall. Curbside closet was removed to accommodate shower, with most electrical relocated to rear hatch. New Progressive Dynamics PD Series power center, fuse block. Furrion 30A marine power input installed on street side.
Shureflo inlet installed above new 10-gallon Atwood dual system water heater. Plumbing renovated to PEX and Watts Aqualock (SeaTech) fittings throughout trailer.
Shakedown Run Photos https://photos.app.goo.gl/FG86Wf53nk5CxHcaA
Erik Olson
Old 11-07-2021, 07:56 AM   #7
Erik Olson's Avatar
1974 29' Ambassador
New bathroom and galley update photos... https://photos.app.goo.gl/poc8UzexohxajBUw8
Erik Olson
Old 12-22-2021, 06:11 PM   #8
1976 25' Caravanner
2003 36' Land Yacht XC Diesel 330 hp w/2slides
Long Beach , CA
Thank you for sharing. Beautiful job!
C-YA-L8R is offline   Reply With Quote
