Ohana
Erik Olson's Avatar
Erik Olson Erik Olson is offline
Airstream Registry
Airstream Name Ohana
Year 1974
Make Airstream
Model Ambassador
Length 29
Options Mid-Twin
1974 Airstream Ambassador
1974 Airstream Ambassador 1974 Airstream Ambassador 1974 Airstream Ambassador
Overview Rear Bath, Mid-Twin with Custom Bunks. All original cabinetry.
Exterior
1974 Airstream Ambassador Exterior 1974 Airstream Ambassador Exterior 1974 Airstream Ambassador Exterior
- Updated original Carefree awning to stainless hardware
- Replaced 1/2" belt and 1" rub rail with blue goods from Out-of-Doors Mart
- Painted beltline end caps with Rustoleum Sail Blue paint
- Painted tail light bezel flute rings with Rustoleum Sail Blue paint
- Painted International placards with Rustoleum Sail Blue, Rustoleum Red and White Automotive paints
- New stop/turn and back-up light lenses
Interior
1974 Airstream Ambassador Interior 1974 Airstream Ambassador Interior 1974 Airstream Ambassador Interior
- Carpet removed, Pergo-style flooring installed (PO)
- Re-upholstered (PO)
- Updated original light shades
- Updated nose inserts
- Updated Moen bath mix cartridge / knob
- Replaced door and most window metal screens with black fiberglass wire
Customization
1974 Airstream Ambassador Customization
Tow Vehicle
2004 Dodge Crew Cab 5.7 Hemi
Old 09-28-2011, 07:32 PM   #2
Erik Olson's Avatar
1974 29' Ambassador
CONCORD , North Carolina
Send a message via Skype™ to Erik Olson
Ohana 74 vanity plate. Now, what to do about that Yankee style plate light? Get in line ($$)!!!
Erik Olson is offline   Reply With Quote
Old 10-04-2011, 01:47 PM   #3
Erik Olson's Avatar
1974 29' Ambassador
Changed out main door rubber seal with part from Out-of-Doors Mart. First removed old, cracked rubber seal with razor blade, steel wire brush and finally a nylon bristle brush.
With the door open against the trailer, I started on the bottom trailing edge of the door and worked my way up and over without stretching the material at all. The bottom is sealed with a cut piece once you've done the upper part of the door in a continuous run. Note that the old seal on the 1974 Ambassador was under the hinges - this is not the case with the new seal.
Will post photos.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
