Big Bullet
Action's Avatar
Action Action is offline
Moderator dude
Airstream Registry
Airstream Name Big Bullet
Year 1966
Make Airstream
Model Overlander
Length 26
1966 Airstream Overlander
Overview Purchased used on e-bay in spring of 2001 from a seller in Indiana. Drove from AZ to Indiana and back in 3 days.
Sold spring of 2012
Exterior
Updated roof top A/C unit
Interior
1966 Airstream Overlander Interior 1966 Airstream Overlander Interior
All original appliances still work well except the hot water heater
Customization
Previous Owner glued carpet to the ceiling and walls
Systems and Running Gear
All Original
Tow Vehicle
1990 Ford E-150 5.8l
Old 01-03-2018, 11:36 AM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Sold in Phoenix some 5 + years ago.
Used mostly to go to Mexico.
Installed new roof top AC. Repaired water supply system. Replaced all foam in cushions. Replaced a lot of small parts for windows and cabinets.
Pictures taken of trailer were done on a trip to four corners.
ID:	301774   Click image for larger version
ID:	301776   Click image for larger version
ID:	301778   Click image for larger version
ID:	301780   Click image for larger version
Old 01-03-2018, 07:19 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I had a 66 Trade Wind. Just 2' shorter. Had a smaller galley and living room. Bed and bath were the same I believe. I completed a lot of work on the Trade Wind.
Now a 75 Overlander. I find the 75 well built even with its faults.
David
Name:	1309 Exterior Curb Front (Small).JPG
Old 01-03-2018, 07:31 PM   #4
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
If I had it to do again I would have bought a Trade Wind. The Overlander was too long. However at that time my mind went to bigger is better.
And I think '66 is nearly the best year.
One of the last years for vertical shock absorbers
Wider body than '65
Curved side glass (Made by Corning) versus the multi- piece glass
Improved window cranks
Lighter to pull than '69 or later versions of the same length
>>>>>>>>>>>>Action
