AZ Streamer
switz's Avatar
switz switz is offline
Airstream Registry
Airstream Name AZ Streamer
Year 2014
Make Airstream
Model Classic
Length 31
2014 Airstream Classic
Overview Classic model 30 ordered with 50 amp service and second air conditioner, International Serenity flooring, aluminum back splash above sink, twin beds and golden ultra-leather upholstery.
Interior enhanced by items from our world travels.
Exterior
2014 Airstream Classic Exterior
Nine 100 Watt AM Solar panels with Victron SmartSolar MPPT 150/85-TR solar charge controller going into a Xantrex Freedom SW3012 pure sine wave converter/inverter. Both devices have remote displays mounted onto a hickory board along with new Micro-Airthermostat.
Voyager wireless camera mounted above rear window with power from reading light above street side twin bed with an On/Off switch.
WiFi Ranger and Verizon cell antenna mounted on refrigerator vent.
Maxim skylights - front clear-bronze-clear and rear clear-frosted white diffuser-clear.
Maxxfan 7000K fan.
WineGard TV crank up antenna replaced by their Rayzar automatic antenna.
Storage lockers rekeyed to custom pattern.
Custom aluminum water heater cover for Turma with wasp screen, stainless steel furnace cover with wasp screen, stainless steel range vent hood, stainless steel water fill door, stainless steel banana wrap rear storage compartment and water hookup compartment.
John Leake 5 pole flag stand on front of trailer. Using Mr. LongArm 9272 Twist-Lok 6' to 12' poles for flags.
Interior
2014 Airstream Classic Interior 2014 Airstream Classic Interior 2014 Airstream Classic Interior
Shelf in clothes closet with new light under shelf.
Custom 8" Rocky Mountain Mattresses and pillows with Airstream 600 thread linens.
120Vac duplex outlets added to closet, rear storage compartment, street side storage compartment, and water central compartment. Custom duplex with USB charger sockets in twin bed nightstand.
Ships engineering clock from Victory Ship Asbury, built in March 1944.
Replacement glued down Marmoleum Vivace Asian Tiger flooring throughout.
Customization
2014 Airstream Classic Customization 2014 Airstream Classic Customization 2014 Airstream Classic Customization
New main electric panel in street side storage compartment with front air conditioner breaker and the unused breakers for new Truma "AquaGo comfort" instant on water heater (propane only) and Vitrifrigo DP2600 refrigerator with DanFoss compressor running only on 12Vdc (has refrigerator and freezer doors skinned in magnetic stainless steel for park magnets). Has 30 amp 240 Vac breaker feeding Xantrex Freedom SW 3012 inverter/charger with control panel (top of avatar). 600 amp-hour Lithionics lithium iron phosphate battery with battery management system under the front sofa with round state of charge display seen in middle of avatar. Victron SmartSolar MPPT 15085-TR solar charge controller inside triangular cabinet. All factory 120Vac outlets plus added ones can run off batteries. Upgraded all 120Vac outlets to Hubbell 20 amp GFI. Installer Micro-Air easy starts to both air conditioners and the Micro-Air thermostat as shown in bottom of avatar.
SeeLevel 714 tank monitoring system fitted to replace factory system.
All interior lights converted to LEDs.
Installed stainless steel Dickinson Mediterranean stovetop/oven.
Systems and Running Gear
BrakeRite II SD disc brake controller with 12" Kodiak Dacromet finish rotors and stainless steel calipers. Five Michelin LT225/75R16/E LTX tires are mounted on four SenDel T03-66655T aluminum wheels and one SenDel S62-66655TG galvanized steel wheel for the spare. Centramatic 300-356 (all "A" plates) wheel balancers and a Tuson TPMS were installed.
Other Information
2014 Airstream Classic Other Information 2014 Airstream Classic Other Information 2014 Airstream Classic Other Information
Order placed in May 2013. Construction started 19 December 2013 and resumed 2 January 2014 and I was there everyday to photograph the progress. The unit was essentially completed by 15 January and arrived at the dealership 27 January 2014 covered in road salt.
Tow Vehicle
2014 Airstream Classic Tow Vehicle
2012 Dodge Ram 2500HD Cummins diesel with Kelderman all wheel air bag level ride suspension. Additional Cummins fuel filtration and external oil filtration was added to engine and transmission. Oversized covers with cooling fins added to to both differentials along with temperature probes. Vision camper bed shell. Enhanced engine instrumentation and LED driving and fog lights added. Curt 15049 2,550 pound rated rear hitch installed. Curt 31015 front hitch installed. Engine performance enhancements added for better life and cooler running.
Old 08-25-2014, 02:52 PM   #2
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Wow! Do you keep a website/blog with more details on your modifications?
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
