05-09-2004, 11:45 PM
Lotoflabor - 1963
Just bought our 63 Soverign a little less than a month ago. It was stripped out and being used for storage, I have about 80 manhours in it so far and am almost ready to install new floor, shell is setting on frame and I am welding some new outriggers and crossmembers in. Still suffering from sticker shock from the local Ace Hardware store on the price of elevator bolts and 3/4 inch plywood. If anybody has a cheap source for elevator bolts I would appreciate a heads up.
Leonard
Leonard
LotalaborAZ
05-09-2004, 11:48 PM
1977 23' Safari
Hillsboro
, Oregon
post some pictures of your work!
Van
2009 F-350 FX4 Crewcab 4x4 6.4l
former '78 Argosy 20' Minuet owner
former '77 23' Safari owner
former 25' Fun Finder X-250BHS SOB owner
current 26' Komfort Trailblazer 262BSLE SOB owner
05-10-2004, 12:29 AM
I have a lot of pictures but I guess the file size is to large, any idea about proper file sizes for posting pictures.
Leonard
Leonard
LotalaborAZ
05-10-2004, 03:36 AM
1965 20' Globetrotter
Houston
elevator bolts
Leonard
http://www.fastenal.com/shoponline/search/ItemDetails.asp?ProdID=140333
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
05-10-2004, 04:33 AM
1984 29' Sovereign
Savannah
, Missouri
Here's an example`
Leonard
upallnight,
It's common to use the highest resolution for taking digital pictures but, that can make your file too large to post on here. What you need is a graphic program to resize the pictures..Any number of free programs available will do this for you..You could also re-program your digital camera to take what's termed "e-mail" pictures. These picture are suitable for sending over the internet via e-mail~! They work perfectly here as well..
I'm posting this one as an example~ it's file size is under 21kbits and the pixels is 360x270. Also, just as a reminder..try to use jpeg file~ that file works the best all around..
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
05-10-2004, 08:08 AM
1959 22' Caravanner
Atlanta
, Georgia
Fun isn't it? LOL
Fastenall, as Bobby pointed out, is a good source. Might also check your local yellow pages under hardware, fastners, screws. Probably a local companty that has them. I used a place called "threads of the South" I honestly don't remeber what I paid but it was a lot less the the local ACE was going to charge. Ace if great when you need 4-5 bolts. When your buying 50, don't go there.
Same with Plywood. HD probably would have given you a better price but looking for a distributor like Ply Mart would have saved you a few bucks.
Pictures need to be 640wx480h max. You can load larger to your www.airstreamphotos.com site and link if you like but the above size is what most computers will show as a full page. Also that size is a bit more user friendly and for thos stuck on dial up they will like you a whole lot better. That will make a picture around 70k with compression that is nice and clear for veiwing on the net.
Welcome to the fun!
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
05-10-2004, 09:56 PM
Really appreciate the heads up on the bolts, should be here in a couple of days, will also be posting pics soon, again thanks alot, I've learned alot from reading all the repair post.
Leonard
Leonard
LotalaborAZ
05-10-2004, 10:03 PM
Administrator
1961 16' Bambi
Dallas
Try uploading your photos to AirstreamPhotos.com it has a larger limit because is resizes them.
05-11-2004, 12:48 AM
Try this link to see the first picture I posted to A/S Photos, It is a picture of a SOB that I took on the side of the road here in Globe.
Leonard
http://www.airstreamphotos.com/photo...955sob-med.jpg
Leonard
LotalaborAZ
07-01-2004, 02:47 PM
230 Hrs. $1150.43 for Supplies
Well I have 230 hrs in labor and $1150.43 in supplies in my project so far. I spent last Saturday night in the Silver Sucker. There is a lot of room for my wife and 5 granddaughters and myself. I left the SS at the campground for the rest of the summer, I'm paying $175 a month for the space so I might as well use it. I'll only be working on it on the weekends that I go up. It's about 150 miles to the campground so no running out to check things. I'll post some pictures on Monday after we get back.
Leonard
LotalaborAZ
07-01-2004, 02:57 PM
1956 22' Flying Cloud
Durango
Leonard
Which bolts did you end up using? I assume plain finish/couse thread 1/4x1-1/4?
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
07-01-2004, 03:08 PM
Originally Posted by Ken J
Leonard
Ken
Ken
I used item #18 from Barnhill Bolt Co., Inc. They were 1/4 x 1 1/2 NC. I paid a little more for shipping because I thought I would need them before I did, but thats usually the way I do things, get it in a hurry then let it sit for a week. I ordered 200 and used nearly all of them. In the wall channel I used 1/4 x 1 1/2 NC grade five hex bolts. In the places where the PO had cut the channel or it was broke from movement I braced it with 1/8 x 1 1/2 flat strap then drilled through the strap to bolt it.
Leonard
LotalaborAZ
07-01-2004, 03:10 PM
The web site for Barnhill is www.barnhillbolt.com , they are in Albuquerque so they are fairly close to you and I for shipping.
Leonard
LotalaborAZ
07-01-2004, 03:14 PM
Durango
Leonard
Cool - thanks! I'm in Albuquerque quite a bit - so that really works great!
thanks again....
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
07-01-2004, 03:16 PM
Leonard
thanks again....
Ken
If you make it to Albuquerque you can save on the shipping, they run 14.89 per 100.
Leonard
LotalaborAZ
07-01-2004, 03:32 PM
Durango
Leonard
One more question - what kind of bolts did you use? Also what does NC mean?
I looked up the Barnhill web site - I assume they are the plain steel - 14.89/box?
Thanks again
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
07-01-2004, 03:38 PM
I used the plain steel elevator bolts, NC is National Course threads, I think about 18 or 20 threads per inch, I can't remember. My memory is really starting to go.
Leonard
LotalaborAZ
07-01-2004, 03:40 PM
Durango
Thanks - yeah I hate it when I get CRS
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
07-01-2004, 03:41 PM
Durango
welp - when I asked what kind of bolts - I really meant nuts - regular nuts with lock washers or nylocks?
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
