Old 08-23-2014, 11:25 PM   #29
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Originally Posted by Tltulsa View Post
Not sure about the specs, but i'd have to think the Cadillac might be heavier, and possibly a longer wheel base. I know that the longer wheel base makes a large difference after letting my friend tow my 29' Excella behind a short wheel base older suv. If you ask me, heavier is also better for staying "in control". I agree with many of the earlier posts...do you homework, read the specs for each car, and call Andy.
The current Cadillac SRX is a front-drive CUV, essentially. It's rated at 3500 lb with the optional towing package and transmission cooler. Basically the same weight as the FJCruiser with a bit longer wheelbase, but less "SUV" than the previous SRX platform. If you want a smaller-than-Tahoe GM SUV I think a Lambda-based SUV (Buick Enclave/GMC Acadia/Chevrolet Traverse) would be a better choice than the SRX. Cadillac doesn't have a Lambda-platform offering.
David
Old 08-24-2014, 03:03 PM   #30
2012 16' Sport
Philadelphia , Pennsylvania
UPDATE: We went to look at new Airstreams yesterday. We thought the 19FT was do-able, but really liked the 22 and 23ft models. The larger 25-30 ft trailers were very nice, but we are really intimidated about towing them.
A side note about depreciation, the dealership mentioned that your Airstream will depreciate about 20% in the first two years. They also said long term prospects are good as they, if taken care of will hold about 60% of their original value. Seems like buying new doesn't make any sense.
We are considering going with a 3-5 year old model or getting a vintage airstream and renovating it to our exact taste.
Need to get over my fear of towing something large. a 27 ft or 30 ft would be so nice. Hills, turns, and the idea of finding somewhere to park all the time, scare me.
adamwright is offline   Reply With Quote
Old 08-24-2014, 03:19 PM   #31
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I guess depreciation can depend on the model too. When we looked to buy a used 25', the cost of a new one was only a few thousand more. We thought that was worth it for the 2 yr warranty and improvements in the model.
2012 Dodge Durango Hemi/AWD
Old 08-25-2014, 01:22 AM   #32
CA_Tallguy's Avatar
1977 31' Excella 500
Zavalla , Texas
Don't worry TOO much about your aptitude for towing -- at least one of you is bound to be good at it, if not both. You both will probably do fine. Plus, Airstreams pull much easier than those big ugly square fiberglass travel trailers that sometimes get blown over in strong winds!
If you still want to hedge your bet by not going too large, I would aim for at least a 25ft model, maybe 28. If you go for a vintage trailer, you might need to go a little larger as they are generally not as wide (depending on the year/how "vintage" you go).
A HUGE reason to go for 25ft+ is DUAL AXLES!! When I was going through this decision, the benefits and safety of DUAL axles became a "must have" after I thought about it. Just think about having a blowout on your ONLY wheel on one side vs one of TWO wheels. In a pinch, you can even drive a dual axle trailer with just ONE wheel on a side.
What might make a bigger difference in the ease of towing than the length of the trailer might be your tow vehicle. Plus your towing equipment (sway control and load leveling hitch, if you use one). I was pretty intimidated after all the talk on here about different hitch systems and what felt like everyone pushing for a massive tow vehicle. Don't let all that talk worry you too much like it did me. I hadn't had time to get my truck setup for a hitch system (though I was convinced that I needed one) when I picked up my 31' 1977 trailer for the first time so I ended up towing just on a plain hitch just to get the trailer home -- and you know what? I still am towing that way today. It has been fine for me, maybe because I have the heft of a 3/4 ton truck as a tow vehicle.
Now I'm certainly not trying to discourage you from hitch systems and beefy tow vehicles. You would probably do well do have one or the other... OR you could go for both to inject an extra level of confidence in your ability to handle a trailer (or a larger trailer as it sounds like might be appealing to you now). If you go for a midsize/luxury SUV as a tow vehicle then you should almost certainly invest in some kind of hitch system. Read up on those to learn more.
As for hills, turns and such -- well going in forward direction, that's all the easy part! The trailer will just follow you around, and you'll be surprised at how easy forward maneuvering is, even through parking lots. Backing up can be a little more tricky for some people, but you'll generally be fine if you just take your time. Since there are two of you, one will get out and guide the other person doing the backing.
Finding places to park -- camping is not going to be a problem with any size Airstream, except maybe in some limited state parks and such. But seriously, 98% to 99% of campgrounds will easily handle any size airstream. If you stop at a store, you just park out in the wide open parking areas. And keep in mind that you can always drop off your partner or vice versa to run into a store where you can't get the trailer in while the other one of you does a circle around a couple blocks. Street parking is pretty easy too though you might have to park a block or two away from where you want to go to find some open curb space.
You won't have trouble finding gas stations to pull into as well (though a few older types of stations are not usable).
If you are absolutely, positively sure that you are going to be spending more time in cities than rural areas, then smaller may be helpful. In my case, I have been surprised at how much more time I spend out "in the country" compared to what I expected (2 years ago lived on the Sunset Strip in West Hollywood). This is a HUGE country to explore, and almost all of it is wide open space!
To make a long story short -- relax! You'll be fine. Go for 25 to 28ft trailer so you don't find yourselves wishing that you had when you realize it's no big deal to tow an Airstream!
WBCCI #1711
Texas Gulf Coast Unit, Texas Airstream Harbor
Angelina National Forest, Zavalla, TX
CA_Tallguy is offline   Reply With Quote
Old 08-25-2014, 03:08 AM   #33
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
You may wish to consider a 23 front bed Flying Cloud. Much better sleeping, larger bathroom, enough room for a family of four (2 adults, 2 dogs). It is about $8,000 more than the Bambi, weighs about 1,000 lbs more, has more fresh water capacity, two axles, and should tow nearly as well with an SUV. A fully loaded 23 FB is about 6,000 lbs. vs. 4500 for the Bambi.
If you have not purchased a tow vehicle, think long and hard about this. There may be some places crossing the Rocky Mountains where a gasoline powered, non turbo engine will struggle. Above 10,000 feet, normally aspirated gasoline engines are not happy unless they are fairly powerful to begin with.
Once you are near the total package you decide upon, let us know.
Ms Tommie Lauer
Greensboro, NC
2015 Serenity 30 RB / 2008 Dodge Cummins 4 X 4
WBCCI #4165 AIR #31871
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 08-25-2014, 11:16 AM   #34
Wilmington , North Carolina
Welcome Adam,
I'm so excited for you! I am in the process of trying to get my partner on board. He claims he's too tall (6'3"). Hopefully soon we'll be making the same amazing discoveries!
Best of luck! Post pictures when you decide!
John
coffej is offline   Reply With Quote
Old 08-25-2014, 07:39 PM   #35
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
go to Trailer Towing Guides | Trailer Life Magazine for the towing guide for every 2014 vehicle that has a two rating. Then go here The 2015 Airstream Travel Trailer Lineup - Airstream to figure out which vehicle and which Airstream would work best for you two.
Good Luck! Derek
Old 08-25-2014, 10:34 PM   #36
Len and Jeanne
Len n Jeanne's Avatar
2005 16' International CCD
2015 19' Flying Cloud
Creston Valley , British Columbia
If you are full-timing, you probably want a "dry bath" and a decent kitchen, as well as more cupboard space.
But also think through how you plan to camp. If you want to get into mostly National Park, and US Forest Service campgrounds, sometimes small is better, as many of their campgrounds were designed for shorter RVs before the days of monster 5th wheels with 4 slideouts. The lighter the trailer, the better for your gas mileage on long-distance trips. However, if you think you'll be mostly staying in RV parks, not driving a lot of miles, and really using the AS as your home base, in an RV park with occasional weekend get-aways to civilized places, then you probably want the largest one you can afford.
Len n Jeanne is offline   Reply With Quote
Old 08-26-2014, 04:11 AM   #37
CA_Tallguy's Avatar
Zavalla , Texas
Originally Posted by coffej View Post
Welcome Adam,
John
I am 6'8" -- your partner is NOT too tall for an Airstream.
WBCCI #1711
Old 08-26-2014, 07:45 AM   #38
BeachHouse's Avatar
2005 25' International CCD
Lilburn , Georgia
I agree with most comments here. My partner and I mostly camp on weekends, but do hope to take long trips in the future. Our 2005 25' International is ideal for us in many ways. But... we do have the corner bed. We liked the CCD bright color design of the mid 2000's and the price as a used trailer. But do think about the corner bed. The metal outside walls of the newer trailers get quite cold. Even our dog won't sleep against it. Eventually we will do a removable upholstery solution to help with that.
We also didn't want a truck or a huge SUV as our TV. So we settled on a Jeep Commander (similar to the towing capability to a current Jeep Grand Cherokee). We talk about our next TV and will consider something larger/more powerful. We burned the transmission fluid going up hill at low speed for too long. The factory transmission cooler is not adequate in our vehicle.
If you do stay with a smaller SUV, consider going to Can Am (an Airstream dealer near Toronto) to buy or at least get your hitch set up properly. You can find many treads about CanAm hitch set ups especially for smaller vehicles. We camped near someone who had a VW Touareg set up by CanAm. They were pulling a 25' similar to ours and loved it. They had been through the western mountains with no issue.
BeachHouse is offline   Reply With Quote
Old 08-26-2014, 11:02 AM   #39
Msmoto's Avatar
2007 25' Safari
Images: 135
The corner bed on the 25 is horrid. Cold, small, and impossible to get the fitted sheets on the mattress. Traded after six months my 2007 25 SS for 2009 27 FB Int Ocean Breeze.
The shorter front beds 23, 25, are much nicer and the bathroom at the rear is probably the best in the line roominess wise.
AIR #31871 K4MTL
Old 08-27-2014, 01:36 PM   #40
IanPoulin's Avatar
2011 28' International
Aldie , Virginia
Two Gay Boys Going on an Adventure
Welcome Adam,
John
John -
I am seven foot tall even and am fine in the airstream. The only two items of note for me are to watch swinging my feet out of bed at what's in reach of the toes, and add a nice teak "shelf" to the shower cause you ARE going to take seated showers for the most park.
Ian
2011 Airstream International Serenity 28' - 30a/taupe
2013 Fors F150 v6-ecoboost with max tow and HD payload packages
2016 Ford F250 Crew 4x4 KR Diesel
IanPoulin is offline   Reply With Quote
Old 08-27-2014, 01:52 PM   #41
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
You don't need dual axles. There's a bunch of us who have been taking our single axle TT's all over the country and are still alive. Some of us even had a blowout. The 22' Sport is light and has plenty of room.
Ahab is offline   Reply With Quote
Old 08-27-2014, 02:26 PM   #42
cory_can's Avatar
2015 30' Classic
Calgary , Alberta
Dual axes not needed but living full time in 22' with a partner and two dogs would be awfully tight quarters
'15 Classic
'16 Ram 2500HD CTD 4x4 Limited w/ Air and Ramboxes
Instagram: cory_can
cory_can is offline   Reply With Quote
Airstream Trailer - 1992 Sovereign 21' - Custom - Texas - Adventure for Two eBay Watch Airstreams on eBay 0 10-15-2013 11:20 AM
Florida FOD Rally-Gay Days Weekend, June 2012, Fort Wilderness, Walt Disney World crazeevw Friends of Dorothy 2 12-25-2011 06:50 PM
Going on an Adventure! 69 23' Safari! lydia-n-eli Member Introductions 5 01-10-2011 10:07 PM
Gay Airstreamers Pahaska Our Community 0 07-05-2004 11:45 AM
