Old 09-30-2013, 06:19 PM   #15
1974 Argosy 20
Kooskia , Idaho
I have used the MiFi jetpack extensively and find it to be great. I have an external antenna that I usually plug into it, as I am at remote places very often, and have limited service without the external antenna. I just leave it in the Jeep most of the time I am camping, plugged into the rear 12 volt outlet for power. That way I can use it in the trailer when at the campsite, and if I go out sightseeing, the MiFi is with me in the Jeep and all I have to do is to grab the 'puter. It takes so little 12 volt power you can leave it on 24/7 for days and days with no danger of discharging the Jeep battery.
Old 09-30-2013, 07:23 PM   #16
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
We have used the Verizon for several years with great success. However, make sure in your travels you are not picking up a cell signal from Mexico or Canada. Very expensive lesson. We also use the Wilson Electronics cradle signal booster. About $150 from Best Buy or Amazon. It usually adds one or two bars and can make the difference.
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
Old 10-01-2013, 08:27 AM   #17
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Great responses everybody. Thanks for the imput.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 11-01-2013, 02:55 PM   #18
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
how can you tell if you are pinging off tower in Canada or Mexico if close to border ..??
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 11-01-2013, 03:14 PM   #19
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
In the WWAN settings for the device, you can tell it to "disable roaming." That's a good default mode, I don't think it's likely you'll find many places where Sprint has significantly better coverage than VZW, and that would likely be the only roaming option in the US.
David
Old 11-11-2013, 01:15 PM   #20
1961 28' Ambassador
Mesa , Arizona
Based on research and help from forum we ended up purchasing the verizon jetpack mifi from Costco for $10.00. We used it while on a road trip w/out trailer. It worked very well at relatives and in hotel. We stayed w/verizon as the provider and wrapped the gig usage into our cell plan for now. We may even consider getting rid of our landline / internet bundle at home and using the mifi at home also.Thanks for the good advice.
Hittenstiehl
Old 11-11-2013, 02:23 PM   #21
2016 30' Classic
Erie , Colorado
And if the antenna doesn't get you the range you need take a look at Maximum Signal The Ultimate Solution For Cellular Reception Problems. I have the Traveler IN Vehicle and when I am out in the wilds of Colorado many times still have a solid wireless data signal.
ghaynes755 is offline   Reply With Quote
