Old 06-01-2016, 08:03 PM   #1
1969 27' Overlander
Leadville , Colorado
replacement of waste water holding tank 1969 overlander
I have a slow leak under the waste tank. I dropped the underbelly skin only to find another metal housing enclosing the tank. Rust and discoloring lead me to believe there must be a slow leak inside that housing possibly in or around the tank. When I filled the tank drops appear around the skin, from where, I cannot determine. The gate valve does not work. I replaced it with the add on V value. Does anyone have advice or pictures of removing the housing and replacing the tank? I have somewhere around 350 hrs in this restoration project in the last 2 months looking forward to enjoying my work but I am ,perplexed. Apparently the leak was slow enough it didn't bother the last folks but I hate to go so far and not address this issue. Dave up high in the CO mountains. Leadville
DJHorning is offline   Reply With Quote
Waste Water Holding Tank 66 Caravel problems Stefandmissy General Repair Forum 12 05-21-2013 12:17 PM
Waste tank issues? 1969 Overlander edglenn Plumbing - Systems & Fixtures 4 10-04-2011 10:59 AM
