Old 07-02-2014, 12:23 PM   #1
Hibby's Avatar
2012 30' Flying Cloud
Grand Rabbits , Michigan
Images: 14
My High Speed Internet Solution for working and entertainment
I have had requests to post based on this discussion in another thread, and I thought it was timely since 3GStore is running a special on this right now...
I need High Speed Internet access in my Airstream for remote work access, watching movies, streaming Pandora, accessing Dropbox files, or just plain fun. About two years ago, when we bought our new 30' FC, I decided to set it up correctly right away, and it has worked VERY well, and it's very inexpensive. See info copied below from the other thread:
Here's the link to the Wilson signal booster:
Wilson Sleek 4G Universal SmarTech III Cell Phone/Hotspot Cradle Signal Booster - 460107 [700/800/1900/1700/2100mhz], 132 Reviews : 3Gstore.com
NOTE: it is on sale through July 12 for ($139.99 $40 off!) and shipping is only $5.
I had the dealer mount the antenna to the roof with aircraft adhesive and drill/fill/seal a hole to run the coax into the interior of the Airstream (comes into the stereo cabinet). I then mounted the cradle to the cabinet just above the stereo faceplate (it comes with an adhesive swivel bracket). This allowed me to plug the DC power plug into the 12v outlet that is right above the DVD player.
Every time we are in the airstream, I just pull my Verizon Jetpack out of my briefcase and pop it into the cradle. Voila! Instant wi-fi throughout the trailer.
This works so well for two reasons:
1. It gets the reception OUTSIDE of the trailer by mounting the antenna on the roof.
2. The cradle boosts the signal from the cellphone/jetpack/etc.
I almost always have full signal now (4+ bars) and never use campground wi-fi. It allows me to use my laptop, iPad, phone, etc. all at the same time. My wife also usually has her laptop connected too. We are even able to use our AppleTV in the Airstream to watch movies from iTunes or Amazon Prime.
Hope this helps!
Hibby
Hibby is offline   Reply With Quote
Old 07-02-2014, 01:23 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Who's and what data plan are you using to support this level of usage?
2004 Excursion 4x4
Old 07-02-2014, 03:36 PM   #3
Hibby's Avatar
Images: 14
Verizon, 8 gig per month... I can change the data usage part of my plan each month as needed, so I often downgrade it to only 2 gig if I'm not going to be traveling much.
Hibby
Old 07-02-2014, 09:19 PM   #4
2016 30' Classic
Erie , Colorado
One of the best deals out there if you need a bunch of capacity is through Millenicom. They use the Verizon network, you can get the same Jetpack from them at a good price and 20gb/month is currently $89.99.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 07-02-2014, 10:58 PM   #5
Hibby's Avatar
Images: 14
Good to know... I'll have to check that one and compare. We currently have 2 adults and four kids (although two of our daughters claim to be adults). Our plan is about $125/mos for five devices and 2 gb. When I upgrade to 8 gb of data, we pay closer to $190.
Hibby
Old 07-16-2014, 07:45 PM   #6
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Depending on your devices, I'd suggest your Verizon 2 or 4gb for phones and get the Millenicom 20 gb plan for ipads and computers.
This will break things up a little better for data usage and how you're more likely to use each device.
Family of 4 living, working & exploring the USA in our Airstream.
OUR BLOG | FACEBOOK | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Mac Mini-based AV/internet solution writeup mmccurdy Audio, Video & TV 8 06-09-2008 09:42 PM
A Sewer Solution.... Solution FreshAir Waste Systems, Tanks & Totes 15 09-29-2007 11:23 AM
Hi speed internet mwinter Computers, Internet & Satellite 11 04-23-2007 10:17 PM
High Speed on Interstate Tarheel Off Topic Forum 55 05-11-2006 11:39 AM
2 speed wiper switch has no low speed rdm Mechanics Corner - Engines, Transmission & More... 6 01-09-2003 09:47 PM
