Old 10-27-2013, 04:49 AM   #1
1997 34' Limited
Staunton , Virginia
Where to place satellite receiver - 2011
We recently purchased our Airstream, 2011, classic 31D and have been debating where to place our satellite receiver. I have not found a suitable spot on this model. We've considered a small shelf above the tv but I'm unsure as to the best way to secure the shelf to the wall. Any thoughts or suggestions?
Shenvalley is offline   Reply With Quote
Old 10-28-2013, 09:44 AM   #2
casarodante's Avatar
2012 31' Classic
Potentially put it in the same cabinet as the DVD player and piggyback/switch on the existing HDMI cable run?
Roger & Roxie (rore62) Smith (Air#178 - WBCCI#1646)
On the road!
2012 31' Classic - Nuestra casa rodante
Blog: https://www.casarodante.org - Old Airstream slides: https://airstream.casarodante.org
casarodante is offline   Reply With Quote
Old 10-28-2013, 06:39 PM   #3
1997 34' Limited
Staunton , Virginia
Thanks for the reply...I think I have decided to install a shelf just above the TV. On my model there isn't anyplace to put a receiver. Airstream told me there is 3/4" between the wall and the refrigerator so, I can avoid drilling into the frig. I've a wood worker friend coming over tomorrow to help me out with design, construction and installation.
Again, thanks for the input.
Old 11-02-2013, 11:13 AM   #4
time2play's Avatar
2013 30' Classic
Kent , Washington
Once you have installed the satellite, can you post pictures? I would love to see how you did it.
thanks!!
Yolanda (and Phil)
2013 30' Classic Limited
2015 GMC Sierra Denali 2500HD
ProPride 3P Trailer Sway Control Hitch
WBCCI #7878
time2play is offline   Reply With Quote
Old 11-03-2013, 07:56 AM   #5
1997 34' Limited
Staunton , Virginia
Originally Posted by time2play View Post
Once you have installed the satellite, can you post pictures? I would love to see how you did it. thanks!!
let me give an attempt to post a photo
Old 11-03-2013, 09:52 AM   #6
time2play's Avatar
2013 30' Classic
Kent , Washington
Shenvalley
Geat picture! Thanks for posting. We're thinking of getting a satellite receiver as well, so this really helps!
Good job on the shelf!
Yolanda (and Phil)
WBCCI #7878
Old 11-14-2013, 08:07 AM   #7
Barefootdog's Avatar
2013 30' Flying Cloud
I'll be installing a satellite receiver in our 2013 30' Flying Cloud and a shelf above the TV seems like a good solution. I thought about putting it in the cabinet with the DVD player and using an hdmi a/b switch but then I'd need to figure out how to connect the satellite dish (I plan to use a Tailgater). Were you able to use the cable tv port that came with your AS to connect the receiver to the satellite dish?
Barefootdog is offline   Reply With Quote
Old 11-14-2013, 08:23 AM   #8
1997 34' Limited
Staunton , Virginia
Yes, the cables work just fine. I use a short coaxial from the wall outlet to the receiver input. Then, just a short run from the receiver to the tv. Good luck with yours
Old 02-26-2014, 04:03 PM   #9
2006 31' Classic
Scottsdale , Arizona
Where did you mount your dome? We are thinking about the new winegard x1.
Patti & Paul is offline   Reply With Quote
Old 02-26-2014, 06:33 PM   #10
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I keep mine on top of the 30' D food pantry/convection oven which is directly behind our dinette on the street side. I do keep the receiver in a box that I lay on the floor in the back bedroom when traveling. I place my cell phone charger, satellite receiver (Dish 211Z) and the HD TV which sits on a pedestal on that same top area. It all fits well.
The TV is taken off its pedestal and also stored in its original box back in the bedroom when we travel. Here's a picture. The satellite receiver is sitting flat behind the TV set.
Jack
Jack Canavera
STL Mo.
AIR #56
jcanavera is online now   Reply With Quote
Old 02-26-2014, 07:07 PM   #11
2011 30' Flying Cloud
Arvada , Colorado
I saw an interesting installation where the receiver was mounted flat on the wall right below the TV.
Jack46 is offline   Reply With Quote
Old 02-26-2014, 07:34 PM   #12
jcanavera's Avatar
Fenton , Missouri
Images: 143
Technically I could mount there but I'd have to pull the large mirror on the wall off, plus I think the exposed wires might be somewhat ugly. Right now the TV hides the wiring pretty well. I could also mount the receiver on the wall behind the TV but that wall is the refrigerator compartment. At this point the receiver is small enough that it just isn't worth the effort to permanently mount anything. And the plus is if I ever sell the trailer, that entire area stays very clean with no electronics present.
Jack
Jack Canavera
STL Mo.
AIR #56
2011 classic
Where to put satellite receiver xo1rider Audio, Video & TV 23 11-23-2015 06:48 PM
Receiver height on 2011 Tahoe danlehosky Tow Vehicles 2 12-10-2011 06:53 AM
Cable TV/ Satellite Receiver Dual Coax Face Plate pwesterman 2008 Safari SE 2 11-14-2010 01:09 PM
satellite tv receiver placement Antique Pedaler Computers, Internet & Satellite 3 11-30-2009 04:24 PM
portable dish connect to satellite receiver? tsaxy Computers, Internet & Satellite 4 09-03-2008 09:59 PM
