Old 08-07-2018, 04:21 PM   #1
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
Villa Power Recliners
One of our reclinerís rear motor mount bars broke away from the side frame. It tore the mounting bracket at the 90 degree angle. Has anyone had this happen and are parts available or do you have to replace the Leggett & Platt mount or weld it? Thanks in advance!
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
NWRVR is offline   Reply With Quote
Old 08-07-2018, 07:09 PM   #2
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
The least expensive option is take it apart and get it welded.
If you could have a superpower, what would it be?
I chose America
Bigventure is offline   Reply With Quote
Old 08-07-2018, 08:21 PM   #3
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
Yup, that’s a given.
Has anyone had this happen, if so, how difficult to pull the recliner base?
Old 08-08-2018, 08:02 PM   #4
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Mine broke. Had to remove the entire sofa. Upon inspection, I found metal fatigue on both recliners. I had doublers added and welded in place. I predict this will happen to Villa recliners after about 2-3 years of average use. Next time this happens (and it will). Iím dumping the sofa and putting in some decent recliners.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 08-09-2018, 08:37 AM   #5
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
Thanks BAB. This is what I was looking for. Any tricks to removing the sofa or is it just removing the bolts from the base and seats?
Classic Villa Power sofa Bigventure 2016 - Current Classic (all lengths) 7 06-11-2017 06:23 AM
SOLD -- 2 Villa Lift Recliners - like new hedgebet Airstream Classifieds 0 05-25-2016 11:52 AM
Recliners by Villa Lift ? swede0030 Cabinets, Counter Tops & Furnishings 2 04-28-2013 06:31 PM
Building L sofa Need Help & Suggestions (Bob Villa) LI Pets Cabinets, Counter Tops & Furnishings 21 11-08-2006 11:22 PM
