Old 09-03-2014, 06:44 PM   #1
2014 31' Classic
Southwest Michigan , Michigan
Trailer Levels
We have a 31' Classic Limited and want to mount a permanent level to the trailer to help when setting up. Where does everyone mount their levels and what kind of level do you have? Thanks.
ratchet is offline   Reply With Quote
Old 09-03-2014, 06:50 PM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We use the one provided on the top of the tongue jack. It's adjustable to calibrate and works well for us.
Doug and Cheryl
Old 09-03-2014, 07:00 PM   #3
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
We use Hopkins Never Fade. The left and right is placed on the body under the big window behind the propane tanks. The front and back is placed on the side of the hitch frame, also behind the propane tanks. By reading the graduations you know how many 1-inch plastic blocks it takes to get level left and right. Easy!
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 09-03-2014, 08:10 PM   #4
Wayward's Avatar
Cary , North Carolina
I bought one of these at Lowes then drilled, tapped and screwed it to the tongue right behind the hitch coupling latch.
Dirt cheap and accurate enough.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 09-04-2014, 07:42 AM   #5
2011 31' Classic
Neat, Wayward. I like that solution a lot.
Old 09-04-2014, 09:45 AM   #6
mefly2's Avatar
2015 25' FB Eddie Bauer
After having Montana's harsh winter weather negatively impact levels installed on the outside of our SOB, we now use the trailer jack level ( as dkottum does) to get the unit in the ballpark for level and then use a torpedo level on the counter in the galley to fine tune madam's silver bullet! The levels sure do look pretty on the outside, but ... YMMV
Old 10-25-2014, 07:46 AM   #7
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I just take out my 6" torpedo bubble level kept in the front storage and place it on the rub rail that runs around the midline. Its close enough so the fridge is level. I don't want to attach anything to the outside permanently.
Kelvin
Old 10-25-2014, 08:07 AM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I have a bubble level outside. Came with the AS.
Also I found my iPhone app works well. It spells out the "degrees" plus/minus.
Folks with a ProPride or haha can use it to set the stinger / hitch box angle too
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-25-2014, 09:15 AM   #9
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
I agree with Doug, the bubble level on the top of the jack works great. Calibrate it by adjusting the three screws.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Reading holding tank levels 1911dan 2004 Safari 0 07-23-2008 10:33 AM
Reading holding tank levels 1911dan 2004 Safari 1 07-22-2008 11:04 AM
Parking Levels Devoman Our Community 6 08-28-2005 01:24 AM
How to determine waste tank levels? Janet H Waste Systems, Tanks & Totes 2 01-07-2004 04:13 PM
