Old 06-17-2017, 12:00 PM   #1
time2play's Avatar
2013 30' Classic
Kent , Washington
Surge Protector
I've been searching these forums trying to figure out which surge protector we should buy for our 2013 Classic. Looks like most people seem to be recommending the Progressive Industries surge protector.
But when I look at their website, there are quite a few different models. I've narrowed it down to this one:
http://www.progressiveindustries.net/ems-pt-x
Do you agree this is the best one for our trailer? The price is more than I was planning on spending. I remember doing some research when we first bought our trailer and I thought they were about $175. Has the price gone up that much?
Thanks in advance for your advice.
Yolanda (and Phil)
2013 30' Classic Limited
2015 GMC Sierra Denali 2500HD
ProPride 3P Trailer Sway Control Hitch
WBCCI #7878
time2play is offline   Reply With Quote
Old 06-17-2017, 01:59 PM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
That's the one I have on my Classic. You want the 50 amp version, not the 30 amp. The "ems" versions do a better job of protection (they disconnect the trailer) than a simple surge setup. That's the main driver on the cost. They are way cheaper than just about anything you would loose in a bum connect situation or a surge.
Old 06-17-2017, 03:08 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I hardwired this one when I upgraded from 30 to 50AMP
EMS-HW50C. It can do both 30 & 50.
I have a "remote" display so monitoring is no problem.
Plug into the pedestal, check monitor for proper power status.. start switching on systems... heavy loads initially.. verify power is stable...
Also when original went up in smoke, upgraded converter.
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-18-2017, 08:08 AM   #4
Half a Rivet Short
Hi
When I got mine, I was all set to go hard wired into the trailer. I mentioned what I was going to do and multiple people cautioned me about this being a fire risk. I asked for further details, but nobody seemed to have any hard data. Even though it sounded like voodoo to me, I went with the external unit.
Old 06-18-2017, 08:43 AM   #5
2012 28' International
Prince Edward County , Ontario
We bought this one (an older model it appears) in the 30 amp version almost four years ago. It has served us well and last summer shut the power off when the park's voltage dropped too low (the AC was running at the time and we were away).
http://www.campingworld.com/shopping...y-50-amp/81278
Cyclist is offline   Reply With Quote
Old 06-18-2017, 09:03 AM   #6
bganso's Avatar
1994 30' Excella
Truckee , California
This one (30 amp) on sale now: http://www.adventurerv.net/portable-...als_06_17_2017
bganso is offline   Reply With Quote
Old 06-18-2017, 09:33 AM   #7
Half a Rivet Short
Hi
I believe that the 30' Classic the OP has is set up with 50A service. You would want the 50A version for a 50A trailer. It would also do fine when running on 30A or 15A shore power.
Old 06-18-2017, 10:27 AM   #8
MWBishop's Avatar
Huntsville , Alabama
I have older 30A (left over from previous TT) and new 50A for the AS.
We too experienced total shutdowns during low voltages at campground.
The newer one is harder to read the display, but would not connect without.
2017 Airstream 26U Twin
2017 F250 Platinum
MWBishop is offline   Reply With Quote
Old 06-18-2017, 10:56 AM   #9
time2play's Avatar
2013 30' Classic
Kent , Washington
Thanks so much for all your advice!
I like the idea of hard-wire unit, rather than portable. How difficult is it to install? Is there a real advantage to having a permanent install, rather than portable?
And I found a website which sells the portable 50-amp at a reduced price:
http://rvsafety.net/proddetail.php?prod=EMS-LCHW50
This include free shipping.
The Progressive website charges $25 shipping! But I've never purchased from this website and do I still get the lifetime warranty even though it's purchased from a different website?
bganso - the product you referenced doesn't seem to be a Progressive, from what I can tell it's a different model.
Yolanda (and Phil)
WBCCI #7878
Old 06-18-2017, 10:59 AM   #10
time2play's Avatar
2013 30' Classic
Kent , Washington
The link I posted is for a hard-wire unit. If we decide to get the portable, this is the one we'd purchase:
http://rvsafety.net/proddetail.php?prod=EMS-PT50X
Interesting that the portable is more expensive than the hard-wire. For some reason, I would think it would be the other way around.
Yolanda (and Phil)
WBCCI #7878
Old 06-18-2017, 01:00 PM   #11
2016 28' International
2010 25' FB Flying Cloud
Grand Rapids , Michigan
We've had a lot of success with this one from Progressive: SSP-50XL.
ArkFortyCal is offline   Reply With Quote
Old 06-18-2017, 07:13 PM   #12
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
1- to steal the SP they will probably need to steal the AS
2- from inside the AS I can get status on the Permanent SP without going in the rain.
3- you can run 30AMP power thru the 50... but you can't push 50 thru a 30... as far as I know.
4- no need for a "locking cover" to minimize threat of theft...
5- no key to lose, misplace, or have someone with bolt cutters relieve you of your troublesome SP..
6- hard to replace the "plug" end of the portable SP... I don't know how it is done... maybe Progressive will replace under lifetime warranty???
Downsides...
A- if onboard SP fails, you have no power in the AS .. unless you know how to jury-rig it.. no, I won't disclose how to do that...
B- I have no other idea
Channing
WBCCI# 30676
Old 06-18-2017, 07:31 PM   #13
Half a Rivet Short
Downsides...
Hi
Commonly claimed "other downside": surge comes along from close lightning strike, hardwired protector bursts into a ball of flame ...
Old 06-19-2017, 01:04 PM   #14
time2play's Avatar
2013 30' Classic
Kent , Washington
Thanks again for all the information.
I'm leaning towards the hardwire unit. For those of you who installed the hardwire unit, where exactly did you install it?
Thank you again.
Yolanda (and Phil)
WBCCI #7878
I'm new. Need for surge protector? bcombs Member Introductions 14 11-09-2013 07:47 AM
1968 - Progressive Ind. 30 amp surge protector? Randy Gates 1965 - 1969 Globetrotter 13 10-17-2011 01:35 PM
Room for in-line surge protector in 23' Intl? Hoonanea Electrical - Systems, Generators, Batteries & Solar 0 10-03-2011 11:07 AM
Loud Humming Noise from Surge Protector Michigander Land Yacht/Legacy Motorhomes 8 07-23-2011 03:56 AM
surge protector pip8688 Batteries, Univolts, Converters & Inverters 15 08-09-2010 05:14 AM
