09-04-2016, 09:27 AM
Livingston
SS exterior cover locks
During the dealer PDI, they had to work on the exterior shower hatch. I'd did not close or open without difficulty, due to the mounting screws along the hinge interfered with the lid edge. So the dealer removed the screws and replaced with rivets. It still has an issue with the locking latch not fully engaging the keep 100% closed. It moves about 3/8" in and out, even with the lock closed.
Better, but yesterday during sticker removal day, I was wiping the lid and water started leaking out. More than enough to account for the past rain. I finished the sticker removal and went get the keys to work on the leak.
Well, none of my small black keys will open the shower hatch. They open every other SS hatch though. And I know it was open at one time because I saw the tech working on it.
Is there a separate exterior shower key for the SS hatch door?
I just can't get the keys to turn at all, but goes in fine.
Dumbfounded.
Sphere Guy
AIR 50601
09-04-2016, 09:34 AM
Biloxi
, Mississippi
Give it a shot of oil or graphite. Mine seem to freeze up every once in a while and the lube helps.
MICHAEL
09-04-2016, 09:52 AM
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach
Hi Sphere Guy.
We have the SS waterfall and shower doors, and the same small brass key opens both.
Regarding how loosely your SS shower door is closing when locked, do you have the same relatively thick foam gaskets on the inside of the door (see attached image). On ours, it is the thickness of those gaskets that causes our door to close very snugly and seal from external water.
Hope this helps a bit.
Joe
09-04-2016, 10:07 AM
Livingston
Thanks all.
I will give a shot of oil, then try it later. Funny thing is that the key will not budge once it is inserted. I figure it may turn some, but.....
Joe, once I get it open I will check for the gasket, but right now I can't tell if it is there. From the looseness, I would say the gasket is not there. And can't remember if it was there while the tech was working on it.
Also Joe, what do you mean "waterfall" ??
Sphere Guy
AIR 50601
09-04-2016, 10:17 AM
Fernandina Beach
Sorry, that should say "water fill" not "waterfall". (I have the Auto-Typo function turned on.) 😀
Joe
09-04-2016, 10:25 AM
2017 25' Flying Cloud
Fayetteville
, Arkansas
The SS outdoor shower and water fill are beautiful much better than the plastic. Did you install or were those factory?
FishByFly
because I catch fish on a fly...
2017 25' Safari FBQ - “Fly Fish Inn”
2023 F150 XLT
09-04-2016, 11:19 AM
2000 25' Safari
Davidson County
, NC Highlands County, FL
Can you tell me if the hose to the shower head has a vacuum breaker?
I've been trying to figure out a water discharge issue (for another thread)
Sorry for the question not related to this issue!
Alan
09-04-2016, 11:52 AM
Livingston
NP Joe.
The SS covers are available from Airstream.
They are standard on the Classics.
Sphere Guy
AIR 50601
09-04-2016, 12:14 PM
Fernandina Beach
Fishbyfly - the pictured SS upgrades were ordered from aArstream and installed by me. The SS water fill was a perfect fit, no cutting needed. The SS shower required a very small expansion to the corners of the existing hole in the trailer (done with a Dremel in about 5 minutes).
Joe
09-04-2016, 02:39 PM
2015 25' Flying Cloud
GILBERT
Airstream has a big sale every year in January for all the SS doors, great prices.
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
09-04-2016, 05:11 PM
2003 31' Classic
Terra Alta
, West Virginia
Thanks for that info. Another reason this forum is so nifty. I will wait for a bargain for my 03 Classic.
Dave
09-04-2016, 05:34 PM
Fayetteville
, Arkansas
Now back to the original question. Are both keyed the same like the basic plastic doors?
FishByFly
2017 25' FB Flying Cloud Queen
2010 F250 Lariat
Past: 2005 30' Safari Bunkhouse
Past: 1986 28' Excella Twin
FishByFly
2023 F150 XLT
09-04-2016, 06:06 PM
2019 23' International
La Habra
We have an older version and thus, no lock. Turn it with a quarter. Somehow the valve did leak or possibly worked itself open and water poured out on ours when I opened the door. It must of been filled with water for some time because the hose turned white. I now check for water inside when we camp.
I'd like to replace the outside plastic AC outlet with a stainless cover however, I don't see one listed in the Airstream parts section. Anyone replaced their AC outlet cover with a stainless?
09-04-2016, 06:52 PM
Fernandina Beach
Mine are both keyed with the same CH-501 key.
Joe
09-05-2016, 07:23 AM
Livingston
No, the SS doors are keyed different than the plastic doors. The SS key is small with a black head and some numbs stamped on them.
I sprayed with oil and still no luck with getting the key to turn. We've tried all 4 of them... Repeatedly...
Sphere Guy
AIR 50601
09-05-2016, 07:45 AM
Fernandina Beach
I think his question is: are both SS doors keyed the same as each other. In my case, the answer is yes, with the same small CH-501 brass key opening both the shower and waterfall doors. These keys came with the SS covers purchased from Airstream in 2015. They may have changed the lock sets since then.
Best,
Joe
09-05-2016, 07:57 AM
Livingston
Thanks Joe, Basically yes to keying alike. My keys have 2233x on them.
Sphere Guy
AIR 50601
09-06-2016, 02:49 AM
Fayetteville
, Arkansas
Yes. Thanks for the keying feedback. For those having problems with water holding in the outdoor shower cabinet, is there a way to make a weep hole to allow it to drain? Seems the back flow preventer is going to drain into the cabinet.
FishByFly
2023 F150 XLT
09-06-2016, 04:46 AM
Loretto
, Ontario
If your trailer is like mine all the locks have numbers on them that match the numbers on the keys.
It took me a couple of years fumbling with keys to figure this out.
09-06-2016, 04:57 PM
Livingston
I finally got it open. It just took a lot of torque to the left. The sprayer was not on, maybe, but I couldn't tell. I had about 1" of water inside at the bottom.
I tracked it down to the latch lever was about 1/8" too long. I got it ground down to the correct length after a few tries and also got the key turn to turn counterclockwise to lock instead of clockwise. How do I know, well the tumbler falls out if you don't hole it tightly and there is a specific flat spot to align it to. LOL
How this was not corrected at the dealer after they had to work on this cover for the interference with the screw heads, is beyond me. But, I feel it was a poor PDI, Maybe partly my fault since I know everything....... HA-HA
And Joe, I do have the inner foam gasket around the door.
I still have a little play in the door, maybe 1/8" instead of 3/8" prior. I still think this will be on my punch list for the factory.
Thanks all who helped me figure this out. And, Yes, it is the same key for all the SS cover locks.
Sid
Sphere Guy
AIR 50601
