Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Classic > 2016 - Current Classic (all lengths)
Old 09-25-2016, 09:10 PM   #1
2016 30' Classic
Lakebay , Washington
Replacing an overhead bulb
Can anyone tell me how to remove the cover on an overhead light fixture? I have a 2016 classic with a burned out bulb but I can't see how to remove to cover so that I can replace the bulb.
c17rabbit is offline   Reply With Quote
Old 09-25-2016, 09:56 PM   #2
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
Bulb replacement.
Go to 2:00 in the video link and watch. You need a small blade screwdriver or I use the knife edge on a leatherman to pry the inner ring loose. I got good at it after a while as I upgraded all my lights to LED. If yours is a 2016 it might already be LED.
SuperTrouper is offline   Reply With Quote
Old 09-26-2016, 04:47 AM   #3
Retired.
. , At Large
I'm pretty sure the entire fixture will need to be replaced. Most of those are held in the ceiling by a pair of stiff springs, so be careful when you remove it.
Old 09-28-2016, 09:25 PM   #4
2016 30' Classic
Thx for the info I'll give it a try.
Old 09-29-2016, 06:43 PM   #5
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Actually, this is pretty simple. Grasp the stainless steel outer surround, and give it a 1/4 turn to your left and pull down. This will release the bezel. You'll find some small metal screws (I think there are 3 of them). Use a small Philips screwdriver and unscrew the fixture. It'll now pull down. You'll see that Airstream has used crimp fasteners. Check and make sure that you're getting 12V to that fixture BEFORE you cut the wires (black is positive, white is ground). Just in case it's a wiring issue. If you're getting 12v, then you'll just replace the fixture. Reverse process to install.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 09-30-2016, 03:41 AM   #6
jayseejay's Avatar
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach , Florida
You are still under warranty so Airstream will send you (through your dealer) the entire light unit for replacement, not just the LED. So you grasp the outer bezel ring and pull down firmly and slowly down until one side of the two mousetrap-like spring bars release. You'll then need to cut and connect two wires with crimp connectors or similar. Here's a picture of what you dealer will send - it gives an indication of the spring mechanism.
Joe
Name:	ImageUploadedByAirstream Forums1475228370.218198.jpg
jayseejay is offline   Reply With Quote
Old 09-30-2016, 08:20 AM   #7
Mantua , Ohio
All that to replace a bulb? That's all the op wanted to know.
Old 09-30-2016, 09:25 AM   #8
jayseejay's Avatar
I too think it is crazy to have to replace the whole light fixture, but AS and the dealer would only send the entire fixture, saying that the LED can't (practically) be replaced alone on the newer models. Joe
Old 09-30-2016, 05:55 PM   #9
2007 22' International CCD
Since LEDs are supposed to last 'forever', I guess the new fixtures have permanently mounted LED circuit boards. Kinda makes sense.
From my view, I'm glad I have the old halogen fixtures where I can replace bulbs with LEDs fairly easily.
Old 09-30-2016, 07:40 PM   #10
BAB
BAB's Avatar
2015 30' Classic
Confucius said something about a "picture being worth 10,000 words." The OP has a Classic. The Classic has a different ceiling light fixture. Here's what it looks like. To remove it: twist the stainless steel bezel to the left 1/4 turn. The bezel will come off. There are 3 screws holding the fixture to the ceiling. Airstream will replace the light as your trailer is under warranty. As I said earlier, I'd use a multi-tester to make sure you don't have a wiring issue.
_________________
ProPride 3P
AIR# 58452
turn signal light bulb replacement...bulb not turning ArgosyMinuet All Argosy Trailers 5 01-01-2021 10:21 PM
Replacing Auto-Lamp 575- what's this second bulb for? Globie64 Electrical - Systems, Generators, Batteries & Solar 2 07-21-2011 09:17 AM
replacing plastic overhead fixtures Silverslug75 General Interior Topics 6 07-15-2009 07:18 PM
replacing wires to overhead light jwaldin Electrical - Systems, Generators, Batteries & Solar 1 02-18-2003 07:52 AM
