Old 05-18-2014, 11:27 AM   #1
time2play's Avatar
2013 30' Classic
Kent , Washington
Question about the foldout table
This is a question about the foldout table with the extension. The extensions seems to be held in place with a "U" shaped pin (see picture). This pin looks doesn't seem to do the job too well. Every time I pull out the table, the extension slides down and hits the floor.
The "U" shaped pin just seems a bit flimsy to me. Do you have the same problem as I have when pulling this table out?
I apreciate your help. Thank you!
Yolanda (and Phil)
2013 30' Classic Limited
2015 GMC Sierra Denali 2500HD
ProPride 3P Trailer Sway Control Hitch
WBCCI #7878
time2play is offline   Reply With Quote
Old 05-18-2014, 11:32 AM   #2
dznf0g's Avatar
Oswego , Illinois
No, but you could try either compressing or expanding the "U" so it has a more friction fit.
-Rich-
Old 05-18-2014, 11:34 AM   #3
1987 25' Sovereign
Oregon , Ohio
That appears to be the same kind of pin that is on the table in our 1987 Sovereign. Our extension is hinged and folds over, it works fine although the spring action is a little sticky.
msmcv51 is offline   Reply With Quote
Old 05-18-2014, 05:23 PM   #4
time2play's Avatar
2013 30' Classic
Kent , Washington
Thanks Rich, I'll give that a try next time we take the trailer out.
But...I paid a lot of money for this trailer. It irks me that I have to pinch this cheap "U" thingy so the extension doesn't slide out.
And thanks for the info msmcv51. So in 26 years, Airstream couldn't find a better "U"?
Any other suggestions, comments etc?
Yolanda (and Phil)
WBCCI #7878
Old 05-18-2014, 05:44 PM   #5
dznf0g's Avatar
Oswego , Illinois
Be prepared for many more irkings. It is what it is.
-Rich-
Old 05-18-2014, 09:25 PM   #6
Wise Elder
Jammer's Avatar
2010 30' Classic
Mine works OK. I had to replace the grommet (warranty) at one point because it fell out and disappeared.
Old 05-19-2014, 04:30 PM   #7
casarodante's Avatar
2012 31' Classic
The clip you are showing stops the table from folding out to full size when stowed.
I am thinking the extension you are talking about is the part that slides out to lengthen the support where the table top folds out and lays on?
In our '92 the extension would always extend as we opened the table. It is a simple household cabinet feature so you could try another one of the same or try a different style or try two of them?
Roger & Roxie (rore62) Smith (Air#178 - WBCCI#1646)
On the road!
2012 31' Classic - Nuestra casa rodante
Blog: https://www.casarodante.org - Old Airstream slides: https://airstream.casarodante.org
casarodante is offline   Reply With Quote
Old 05-19-2014, 04:33 PM   #8
2012 31' Classic
Does it look like this?
On the road!
Old 05-19-2014, 05:27 PM   #9
2011 30' Flying Cloud
Arvada , Colorado
The clip is very easy to bend/break when folding the table into the closed/recessed position. Since the table will slide laterally when open this is easy to overlook.
Jack46 is offline   Reply With Quote
Old 05-22-2014, 08:15 AM   #10
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Those plastic grommets are designed as a cash generating device for dealers. Spares should be on hand for these as well as other items like the awning clips etc.
If we towed a second trailer for spare parts.........
I think the clips are really cheap for this expensive of a unit. Airstream resolved this issue in the 2015 model year by only making a single model of the Classic and it lacks the table.
Old 05-22-2014, 09:13 AM   #11
2012 31' Classic
Which model is it? The 27 and 31 both lack the table now, only the 30 has one. I have not found a 2015 brochure on their site yet.
On the road!
Old 05-22-2014, 09:42 AM   #12
1982 34' Limited
Harrowsmith , Ontario
My '76 had the same clip and my '82 does too! They have got a lot of use from that design.
BradB is offline   Reply With Quote
Old 05-22-2014, 09:51 AM   #13
time2play's Avatar
2013 30' Classic
Kent , Washington
Lots of good information here.
But bottom line, when I pull out the table, some part of the extension always falls down and hits the floor. Not sure if it's the actual extended table, or the part that supports the extended table. I guess I have to look at it more carefully next time. But it's unfortunate because once it slips down, I always have to grab it with with my fingers to push it up as I pull the table out. And unfortunately, it means I usually end up pinching or smashing my fingers in the process.
Yolanda (and Phil)
WBCCI #7878
Old 05-22-2014, 10:36 AM   #14
switz's Avatar
2014 31' Classic
Images: 8
The pain and pleasure of Airstream ownership!
Need to replace foldout table badkat Cabinets, Counter Tops & Furnishings 9 05-14-2014 09:06 AM
Step Covers - An Alternative to Foldout Steps When Docked. Shehanigans Steps 31 08-04-2013 07:07 PM
Bambi II folding table question Antique Pedaler 1964 Bambi II 4 06-21-2012 04:47 PM
Replacing Front Gaucho w/Dinette- flexible foldout beds my3sonsdad All Argosy Trailers 8 12-22-2011 06:07 PM
falling table leaf of credenza fold-away table Fenghuang Cabinets, Counter Tops & Furnishings 3 02-13-2007 10:27 AM
