Old 04-12-2015, 06:41 PM   #1
time2play's Avatar
2013 30' Classic
Kent , Washington
Question about city water hookup
In our 2013 Classic, we're finding the hookup to the city water is difficult to reach, it's almost at ground level. You have to really bend down and reach to get to the opening.
Are we the only ones having problems with this? What do you do? What is your solution? I'm sure there's an easier way to hook up the city water. Any suggestions?
Thanks!
Yolanda (and Phil)
2013 30' Classic Limited
2015 GMC Sierra Denali 2500HD
ProPride 3P Trailer Sway Control Hitch
WBCCI #7878
time2play is offline   Reply With Quote
Old 04-12-2015, 06:49 PM   #2
SteveH's Avatar
Common Sense , Texas
Yes, they are very low and difficult to get to, so I put a quick disconnect fitting on it and on the end of the hose I use. That way at least I don't have to spend so much time down there on one knee tightening the hose fitting every time I hook up.
Regards,
Steve
Old 04-12-2015, 08:20 PM   #3
time2play's Avatar
2013 30' Classic
Kent , Washington
Great suggestion! We did put one on the end of the hose, but never thought about putting one on the hookup itself. We'll give that a try. Thank you!
But I still say it's a lousy place to put a water hookup!
Thanks again.
Yolanda (and Phil)
WBCCI #7878
Old 04-12-2015, 08:30 PM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We use the quick connects for all of our plumbing connections and have for years. We also have run into the really low city water faucets on many occasions. About two years ago we started use a short white hose to come from the city water faucet to our splitter. We have found that this makes the low connection easier to deal with.
Brian
SuEllyn & Brian McCabe
Old 04-12-2015, 08:40 PM   #5
SteveH's Avatar
About the difficulty connecting the hose to the fitting in the water compartment, other friends of mine leave a 1' hose attached to the trailer and find connecting the longer hose to that just as easy.
Regards,
Steve
Old 04-13-2015, 10:15 AM   #6
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I have a 90 degree elbow attached to the city water connection. I don't think it necessarily makes it any easier to connect. There is a short length of hose connected to the black water flush. I can route the city water and the black water flush through the bottom of the compartment and close the compartment cover with the 90 degree elbow attached. I have to kneel in the same general vicinity to hook up to the sewer connection. I lay out all the hoses and kneel down once to make all the connections. The quick disconnect might be a good idea. Are there quick disconnects for the sewer hose, too?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 04-13-2015, 10:40 AM   #7
SteveH's Avatar
Not that I know of, but wish there were.
Regards,
Steve
Old 04-13-2015, 12:27 PM   #8
m.hony's Avatar
2013 30' Classic
Back to laying all the hoses out and kneeling once to hook them all up-
TAC #MS-10
Airforums #70955
Old 04-13-2015, 01:39 PM   #9
SteveH's Avatar
I use plumber's knee pads.
Regards,
Steve
Old 04-13-2015, 05:00 PM   #10
demijac
2014 27' FB Classic
Livingston , Texas
Send a message via Skype™ to demijac
Quick Connect - Problem Solved
Spent a few dollars on the 'quick connect' parts at a hardware store. Now can connect/disconnect in a split second without having to kneel down and wrestle with the standard hose connection like before. Appreciate this method the most when its cold, dark or buggy out.
demijac is offline   Reply With Quote
Old 04-13-2015, 05:20 PM   #11
m.hony's Avatar
2013 30' Classic
I have a yoga mat left over from my wife's 2 classes- she decided that lady was trying to kill her-
TAC #MS-10
Airforums #70955
Old 04-13-2015, 05:28 PM   #12
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I am going this route.. soon..
http://www.drainmaster.com/main/2012...t-vs-cam-lock/
Peace and Blessings..
Channing
WBCCI# 30676
Old 04-14-2015, 05:20 AM   #13
Airborne6's Avatar
2015 23' International
Lakeview , Arkansas
Moosetags. Newbie question. I see you have a y connector for city water. One to city water hook up and the other to ?? Black water tank flush?? My other question is the tank dump hose. Seeing the diameter is that just for grey tank?? So much to learn, so little time. ��
Some days your the bug.
Some days your the windshield.
WBCCI # 1959
Black 2015 Toyota Tundra TRD Pro CrewMax
2015 23D International Signature (Salsa)
Stella our Bull Pointer mix
Airborne6 is offline   Reply With Quote
Old 04-14-2015, 06:58 AM   #14
moosetags's Avatar
The 'Y' splitter on the city water supply line on my set-up is used to supply the city water inlet on the Airstream. The additional hose is used to supply my Sewer Solution sewer dump system. The dump hose that you see in the photo is part of the Sewer Solution. It is used to dump both the gray and black water. The Sewer Solution macerates the black tank's contents and drains through the much smaller hose.
Brian
City Water hookup & Fresh Water Tank? Driver1 Fresh Water Systems 3 02-17-2009 03:28 PM
City water hookup(s)? Not Done Fresh Water Systems 6 04-16-2008 10:44 AM
City water hookup honez Water Heaters, Filters & Pumps 6 01-27-2008 09:07 PM
HELP! City Water Hookup Missing... sierrajb Fresh Water Systems 14 01-13-2006 07:45 PM
Is this the city water hookup? Stefrobrts 1966-68 Caravel 7 05-06-2003 10:13 AM
