Old 10-06-2013, 03:56 PM   #1
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Power outlets - 120 VAC
We are doing some electrical home work and do not have access to a 2013/2014 Classic 30 with twin beds. Normally accessible outlets are my concern.
Going from the rear to the front:
1. Some photos on other models show an AC outlet on the street side of the night stand between the twin beds. Does that apply to a Classic 30?
2. A duplex or single power outlet for the bedroom TV. Is it a duplex or single outlet? If a factory inverter is installed, a single outlet with blue label is provided.
3. A duplex outlet with GFI is in the bathroom above the sink.
4. Is it a duplex or single outlet for the Television above the dinette? If an inverter is factory installed, then there could be a single outlet with blue label there as well.
5. A duplex outlet with GFI is above the kitchen sink.
6. A duplex outlet is shown in a photo above the "end table" in front of the dinette and a blue label inverter outlet shows there as well. Is the blue label outlet a single or duplex outlet?
Are there any power outlets on either side of the lounge sofa for computer etc use?
Are there any other normally accessible outlets?
Thanks.
Old 10-06-2013, 05:45 PM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I can give a little info on the factory inverter install on our 25'. The blue labeled inverter outlets are near front and rear televisions, the BluRay player, and the dinette for computer use. They look like duplex outlets but are not, only 1/2 of the receptacle is an outlet while the other half is cast without openings for the electrical plug.
I interpret that as intended for light duty use.
Doug and Cheryl
Old 10-06-2013, 06:42 PM   #3
richinny's Avatar
2011 34' Classic
airstream did their best to hide all the outlets behind curtains in my classic. i have to unsnap the curtains to use most of them. there should be outlets on the wall on each side of the couch.
it would be nice to use one location to charge two cell phones with the inverter.
Ricky
2013 classic
No power to outlets hnspaulding Electrical - Systems, Generators, Batteries & Solar 6 01-27-2012 06:49 PM
Half of the outlets have no power VeggieBullet Electrical - Systems, Generators, Batteries & Solar 23 01-22-2012 08:08 PM
No power to 12v outlets on Dash dgmelp Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 3 12-12-2011 08:50 PM
New VAC Monthly Newsletter Ed Emerick VAC | Vintage Airstream Club 22 08-06-2011 11:55 AM
120 volt outlets from battery power? etobolski Electrical - Systems, Generators, Batteries & Solar 4 04-05-2011 02:15 PM
