Today is Wednesday, 8 January, and the Dometic Fridge and oven and cooktop are still in shrink wrap on the factory floor with cabinets stacked along side. Debbie was finishing the forward dinette bench and would do the other one tomorrow morning. At least the ceiling foam and wall fuzz were nearly completed with the unit back on the "preliminary" assembly line. Unit goes back to the paint building to install awnings if they came in today. Otherwise, we start down a "final assembly" line tomorrow with wiring outlets and power panel (if they got the rear roof cabinets attached to the ceiling metal piece assembly installed).
The Classics seem to take longer than the 5 day build out target assigned to the other trim lines.
The foreman said the build might be done Friday, Monday for sure. Don't know if I want to spend another long weekend in the motel room.
It was 21 here today as a high, but the snow flurries started as I drove back to motel.
