Old 08-26-2016, 06:51 PM   #15
Lets travel's Avatar
2014 30' Classic
Fayetteville , North Carolina
Wow!!! is that a beauty. Hope you have many safe miles. If you can find the time can you give some reviews of the new features, the aldi system, the legs, the new unit controller. Love your colors. How do you like the flat panels you installed, how many watts, battery system. I can go on forever. Thanks for doing this.
Lets travel is offline   Reply With Quote
Old 08-26-2016, 08:11 PM   #16
Rawn77's Avatar
Montreal , Quebec
Send a message via Skype™ to Rawn77
I had similar panels on my '15; these are 120w each x 3
There are 6 Lifeline group 27s; 2 in the battery storage box and 4 under the bed; a 2000w inverter is also installed under the bed which when activated powers the whole RV (not just select outlets like Airstream's factory option); actually ran the front 15k AC unit on it for 15 minutes before I got nervous and shut it down
Ron
Montreal, QC
2017 Classic
Triple Flexible Solar Panels
2000w Inverter
6 Lifeline Group 27 batteries
Honda EU3000
Drain Master Sewer Connection
2017 GMC Denali 2500 Duramax (on order, rented F150 for the month)
Hensley
Rawn77 is offline   Reply With Quote
Old 08-27-2016, 06:24 AM   #17
Naper's Avatar
Loretto , Ontario
Did CamAm install the TV dish? What provider do you use?
Naper is offline   Reply With Quote
Old 08-27-2016, 07:16 AM   #18
Rawn77's Avatar
Montreal , Quebec
Yes CanAm did install the dish. If you look carefully at the pic showing the satellite you'll see they installed a piece of aluminum for the ball to roll on so it wouldn't mark the roof in its resting position.
I went with DirecTV as I already have an account with them. Works perfectly!!
Ron
Montreal, QC
2017 Classic
2000w Inverter
Honda EU3000
Hensley
Old 08-27-2016, 12:42 PM   #19
Naper's Avatar
Loretto , Ontario
Does your setup with Direct TV work in Canada?
Old 08-28-2016, 08:24 PM   #20
2016 30' Classic
Lorton , Virginia
The jacks look interesting. Is that a full strength leveling system? Mind telling how much something like that costs?
Zybane is offline   Reply With Quote
Old 08-29-2016, 11:35 AM   #21
cory_can's Avatar
2015 30' Classic
Calgary , Alberta
I'll let Ron answer your question about the "new" version Canam just installed on his '17, but I have something similar on my '15 and boy does it make changing tires super easy. On my last trip I ran over a screw which brought on a slow leak. All I had to do was raise the trailer on the Levelers, pull the tire, have it patched while the trailer stayed off the ground and then reinstalled and dropped it back down.....built in tire jacks. Their "real" purpose is to level and completely stabilize. You no longer have to deal with the constant trailer movement while walking inside since they eliminate tire and suspension flex......you also don't have to build Lego block fortresses
- Cory -
'15 Classic
'16 Ram 2500HD CTD 4x4 Limited w/ Air and Ramboxes
Instagram: cory_can
cory_can is offline   Reply With Quote
Old 08-29-2016, 07:41 PM   #22
Rich and Kat
AIRHEDS's Avatar
Annandale , Virginia
What are they called? I can't wait to learn more...
Rich
2017 Classic 30', ProPride 3P Hitch, 2016 RAM 3500 Laramie CC 4x4 SRW w/ 6.7L Cummins Turbo Diesel and Retrax Pro MX Tonneau Cover
KB2ZMF
Save
AIRHEDS is offline   Reply With Quote
Old 08-29-2016, 10:33 PM   #23
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Saskatchewan
Please post information on 2017 Classics
Yes this leg system would be of interest to me also. So if we could get some more info that would be great
Doug
Trying to use my camera to create memories - not photographs!
WBCCI #2525 (Region-10 Unit #120)
Air #85270
Arcticfox is offline   Reply With Quote
Old 08-30-2016, 07:46 PM   #24
2016 30' Classic
Lorton , Virginia
I am also interested. It would be super nice not to have to do the leveling block chock/dance every time I park at a new site.
Old 09-04-2016, 08:55 PM   #25
paiceman's Avatar
Upper St Clair , Pennsylvania
Front lounge
Question:. Do those who have a classic with front lounge that reclines find them comfortable? We are considering a 2017 and this is a concern, now have a 30' 2015 with factory recliners we will be selling. Thanks
SAFE TRAVELS
Bud & Alice (Bud posts)
Abby- Black Lab-TDI Certified
Hopey-Yellow Lab-TDI Certified
2015 F350 6.7 Diesel Crew Cab
USAF - Military Training Instructor (TI) - 68-72
Old 09-05-2016, 07:46 AM   #26
Rawn77's Avatar
Montreal , Quebec
Believe it or not they're the same jacks as the tongue jack; though not the 2017 jacks being used. CanAm switched out the existing jack to the Super Jack; same ones used in previous years on the Classics. The price I believe is around $2500 installed; but not really sure since there were a lot of mods.
I've been camping for the last two weeks at various parks; they've gotten lots of use. They work amazing. I use Hoss pads which make deploying them faster
Ron
Montreal, QC
2017 Classic
2000w Inverter
Honda EU3000
Hensley
Old 09-05-2016, 07:51 AM   #27
Rawn77's Avatar
Montreal , Quebec
The front lounge with recliners have not changed from the 15 to the 17 except that now the reclining switch has a USB charge in the middle.
This should not be in your decision making about whether or not to upgrade to '17
Ron
Montreal, QC
2017 Classic
2000w Inverter
Honda EU3000
Hensley
Old 09-05-2016, 07:57 AM   #28
Long Island , New York
Rawn77 -- great trailer and thanks for the photos and details!
Are these new Leveler jacks really spec'd to raise the entire trailer off the ground, in order to change a tire (as cory_can said)? Including wind loads from the sides?
Unless Airstream has beefed up the trailer's frame structure, it would seem that putting the entire weight on the four point loads of the Levelers, is quite a change from having all the weight centered over the axles.
I am also curious to know what the 12-volt loads are for the Levelers, in terms of battery management.
Peter
PS -- Not sure if this 2014 comment applies to the jacks being discussed here, but it says no go to raising the trailer:
https://www.airstream.com/faq/my-tra...care-for-them/
OTRA15 is online now   Reply With Quote
NorCal : 2017 Olema Spring Rally April 7-9, 2017 (formerly at Casini) HootMon-Frau Forum Rallies & Meet Ups 6 09-11-2016 09:05 AM
Motorhome Classics Magazine ALANSD Airstream Motorhome Forums 10 10-30-2002 10:28 AM
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
