Old 09-04-2018, 11:57 AM   #15
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Originally Posted by mikeinca View Post
I'm bumping this old thread because I've come across a similar issue with our 2018 Classic Twin. The bottom strip which secures the tension on the Oceanair blinds has come completely off the clips on one window and I'm unable to reattach it. The strip seems to have a curve to it which make it very difficult to line up the clips properly. Is that curve normal?
This issue has caused me to examine the other shades and I found one with a loose clip and another where a clip has pulled the screws right out of the sill, as apparently has happened to some other folks in this thread.
This problem may have first shown up in the 2015 Classic but 3+ years later it seems to still be with us.
Hi mikeinca,
Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team.
You can also reach Airstream Customer Service and Technical Support at customer_support@airstream.com
Thank you.
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 09-06-2018, 01:20 PM   #16
mikeinca's Avatar
2018 30' Classic
Santa Rosa , California
Originally Posted by AirstreamInc View Post
Hi mikeinca,
Thank you.
I've made an appointment with my dealer to address this and another issue. If things are not resolved to my satisfaction I'll make contact with customer service. Thanks.
“The good thing about science is that it's true whether or not you believe in it.”
― Neil deGrasse Tyson
2018 30' Classic Twin
2017 F250 4x4 6.7 max tow Platinum
200W portable solar
240Ah LifePo4 upgrade
mikeinca is offline   Reply With Quote
Old 03-22-2019, 03:58 PM   #17
beetlebob's Avatar
2015 30' Classic
Green Cove Springs , Florida
I am going to add to this site for maybe an answer. Since out of warranty and am now on to the 5th corner blind string breakage. Does anyone have any ideas on what gauge the string is???
beetlebob is offline   Reply With Quote
Old 03-22-2019, 04:16 PM   #18
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Hi Bob,
If you look carefully you’ll see that the string is highly specialized. It appears to be braided (obviously for added strength). I doubt this will be easy to source. Do you suppose OceanAir would sell it? Probably not. As I recall from an issue I had with a broken spring when my trailer was new (Terry Halstead fixed it), they sell the corner unit for around $1,500. They do not sell the corner tracks and a replacement shade separately.
I keep thinking of an alternative to the curved shade. Of the 4 in my trailer only 2 of them actually close fully. I’ve moved the tracks several times, but the shades aren’t long enough to fully cover the curved window.
Hope you and P are doing well!
Barry
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 03-23-2019, 05:48 AM   #19
beetlebob's Avatar
2015 30' Classic
They make special string for the blinds but in 3 different thickness. The string is cheap so I guess I will get the thickest one and restring it. Will let you know how it goes BABS. Going to Utah in a month to summer in garden springs. The Utah dealership in Salt Lake is supposed to be good so I am going to stop in there for all the other stuff that’s broken. Later
Blinds vs. Oceanair Window Shades BAB Upholstery, Blinds, Walls & Interior Finishes 2 04-17-2014 04:48 AM
Oceanair shades Dee Cov Windows, Doors, Locks & Vents 6 07-08-2013 03:57 PM
Source for Oceanair cassette blinds Ramble On Upholstery, Blinds, Walls & Interior Finishes 4 03-24-2013 07:34 PM
OceanAir Cassette Blinds - Tried Them? mstephens Upholstery, Blinds, Walls & Interior Finishes 11 10-24-2012 10:58 AM
OceanAir AS Part Numbers.... Mexray Upholstery, Blinds, Walls & Interior Finishes 9 06-29-2008 05:09 PM
