Old 07-14-2016, 06:25 AM   #1
beetlebob's Avatar
2015 30' Classic
Green Cove Springs , Florida
My old converter
Name:   ImageUploadedByAirstream Forums1468498974.532336.jpg
Name:   ImageUploadedByAirstream Forums1468499001.231276.jpg
Name:   ImageUploadedByAirstream Forums1468499015.489935.jpg
Think I found out why I was having strange electrical problems with my trailer. 2015 Classic. Babs now I know why I kept blowing fuses
beetlebob is offline   Reply With Quote
Old 07-14-2016, 06:30 AM   #2
beetlebob's Avatar
2015 30' Classic
Picture 1 is they taped over both sides so almost no air movement
Picture 2. I found this loose inside the box and you can see where it has hit the circuit board
Picture 3 is the broken cooling fan. The piece of plastic missing was down into the fan stopping it from working but with the tape covering it what difference would it have made
Quality at its best
Old 07-14-2016, 06:34 AM   #3
beetlebob's Avatar
2015 30' Classic
Have a new progressive PD6455 that I installed. Money well spent. Still under warranty but working inside the Yellowstone national park and no dealer close. Thank goodness I am a master mechanic and a master RV tech so I was able to fix it before I had a fire.
Old 07-15-2016, 06:23 AM   #4
1979 28' Ambassador
2014 27' FB Classic
Port Townsend , Washington
Wow - that was a good find on your part. Amazing that Airstream left tape over the fan and loose pieces in the case.
Just replaced my Parallax Series 500 converter with a PD4655. Was not a direct replacement by any means. Basically had to gut the old converter and mount the new board inside the old chassis with modifications to the case. Glad to have that project done. At least I didn't have the issues you did with yours. Just didn't want to cook my batteries.
rdepas is offline   Reply With Quote
Old 07-15-2016, 02:10 PM   #5
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Bob, AHA! Just glad you finally found the trouble. Spent all this week at Shenandoah NP. High 90's in "lower" VA, but never got above 78 at 3,500 ft. Gorgeous park, nice CG, wonderful to have done all the mods since zero hookups there!
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 07-16-2016, 08:29 AM   #6
2016 30' Classic
Lorton , Virginia
From what I've seen with Airstream, if it isn't in plain view (its hidden or behind a panel), expect the item to either be installed incorrectly, broken, or have issues or defects.
I mean what kind of turds do they have working at the factory? You cannot tell me a worker didn't see 60% of that fan covered with tape. The "I don't give a crap" mentality from the Airstream factory workers is off the chart.
Zybane is offline   Reply With Quote
Old 07-20-2016, 01:17 PM   #7
beetlebob's Avatar
2015 30' Classic
Well found out that they are shipped to the factory with the tape on them and it is suppose to be removed before it is installed OPPS. It is fairly easy to slide the unit out on the classics to inspect it if you are handy. I recommend that. Airstream is making it up to me and for that I am happy. Getting the equipment to check the batteries from work and make sure that they are good before the warranty hoes out
Old 07-20-2016, 02:38 PM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The installer probably thought it (converter) was a radio and the taped over part were speakers! Duh!!!!
Converter fuse blowing (new converter) wannaroam Batteries, Univolts, Converters & Inverters 28 07-06-2015 02:39 PM
Univolt 45 amp converter to a 30 amp converter scooterbug76 Batteries, Univolts, Converters & Inverters 15 02-24-2013 02:59 PM
Old, old, old airconditioner removal bilby05 Furnaces, Heaters, Fireplaces & Air Conditioning 2 10-17-2012 04:19 PM
What to do with old converter? msmst25 Batteries, Univolts, Converters & Inverters 11 06-15-2008 03:32 PM
I had a fun day (pictures) Old trailers and old stuff RichardT Off Topic Forum 11 03-13-2005 03:49 AM
