Old 05-08-2018, 10:24 AM   #1
2012 31' Classic
The Villages , Florida
Lug Nut Damage
I have a damaged lug nut due to removing one of them while on the side of the highway. The outside skin is deformed and a 3/4" socket does not fit all the way down to assure proper nut torque. Does anyone know the wheel brand that is on a 31" 2012 Classic Limited (aluminum wheel)? I know the nut is 1/2"-20 closed end, 3/4" socket size. I also know it must be long enough to bottom at the wheel and not the end of the lug bolt.
I am certain that if I knew the brand of wheel, I could get the correct lug nut.
Help
Email address: unkbill123@gmail.com
Uncle Bill is offline   Reply With Quote
Old 05-08-2018, 10:56 AM   #2
2016 28' International
2015 28' International
2013 28' International
Las Vegas , Nevada
You have the right size nut, just visit your local auto parts store and get a set, make sure to get the long version to accept your long lugs, most will use this opportunity to swap them all out.
I have had this happen once, now I use a six point impact socket and hand fit it all the way to the bottom of the "chrome" AS nut before I start to spin, keep your tool in alignment and fully seated and the AS nuts will last forever, I remove my wheels twice per year for rotation and inspection, only have messed up 1 lug nut.
vintagemotor is offline   Reply With Quote
Old 05-08-2018, 07:54 PM   #3
DaveP's Avatar
2004 28' Classic
Monument , Colorado
10-4 on the six point. And no impact wrenches. Big O Tires wrecked 7 out of 24 lug nuts on my F150 last fall when they installed new tires and rammed-home the lug-nuts with an impact wrench and deformed the outer chrome lug-nut covers!
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 05-08-2018, 10:46 PM   #4
Vantair
Vantair's Avatar
2005 25' International CCD
Westlake Village , California
2piece factory lugnuts
The factory 2 piece lugs are initially nice appearance but honestly quite crap. Looking like a one piece, they will easily twist, contort and separate twisting on itself eventually under normal torquing.
“Single piece” solid metal chrome McGards are one solution. Lifetime warranty never to chip, flake or rust. Now THats what an Airstream should have holding the wheels on. Not pretty pretenders.
Many posts on this which taught me.
Vantair is offline   Reply With Quote
Old 05-09-2018, 04:01 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Plus...made right here in WNY👍🇱🇷👍
Mcgard
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Lug Nut Torque alan Wheels, Hubs & Bearings 46 11-27-2006 09:32 PM
Lug Nut Socket Help... AZstreamin Wheels, Hubs & Bearings 20 09-21-2006 06:04 AM
lug nut/bolt question.... Kistler Wheels, Hubs & Bearings 13 01-25-2006 02:15 PM
Lug Nut Size?? Steve Heywood 1997 -2001 Excella 3 08-16-2005 12:24 PM
Lug Nut Size AYRSTRM2 Axles 0 08-17-2004 12:27 PM
