Old 03-17-2013, 10:13 AM   #1
2012 27' FB Classic
Yakima , Washington
Low point drains in 2012
We have had some trouble with low point drains and now understand that there is a fix. Has anyone else had trouble with these?
Mike-Gloria is offline   Reply With Quote
Old 03-17-2013, 10:50 AM   #2
Low point drains, DO NOT completely drain the system.
But, if you apply an adequate supply of air to the city water hose inlet, then properly used, the low point drains serve their purpose.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-17-2013, 11:15 AM   #3
Maniacal Engineer
barts's Avatar
Lopez Island , Washington
To amplify Andy's comments, you can purge the lines much more effectively using compressed air. You'll need to purge each fixture by openning the valves, one at a time. The last ones to do are the drains; you may need to go around the fixtures twice. It's pretty obvious when all the water is out since there's nothing but hissing w/o any spitting.
Of course, make sure to regulate the air pressure down to a reasonable level.
- Bart
Bart Smaalders
Lopez Island, WA
https://tinpickle.blogspot.com
barts is offline   Reply With Quote
Old 03-18-2013, 09:04 AM   #4
2012 27' FB Classic
Yakima , Washington
thanks to both of you but the problem is not blowing out the lines it is that the points themselves. One fell off and after it was repaired it became loose again. It is doing it again and the dealer told us that airstream knows about the problem and may have a fix. Just wondering if you have had the same issue.
2012 classic, 2013 classic
low point drains on 05 28 ft kingfisher24 2002 - 2005 International 9 12-21-2013 12:34 PM
30' International CCD low point drains? LivLoveLaugh 2011 - 2015 International 5 04-19-2013 07:12 PM
2010 27FB Low Point Drains PJohnson Winterizing, Storage, Carports & Covers 2 10-31-2010 12:17 PM
front low point drains, 19' int'l ericwarren Winterizing, Storage, Carports & Covers 3 12-18-2008 02:58 PM
Low point drains runningbarre Winterizing, Storage, Carports & Covers 5 09-25-2008 06:07 AM
