Old 02-27-2014, 05:19 AM   #57
acstokes's Avatar
2009 30' Classic
Melbourne, FL , Searsport, ME
Gary,
Called Dill already and asked how do you match wheel position to display. Long pause..............
It helps to read the manual.
Fred Stokes
RV Rearview Camera Systems, LLC
WBCCI #2810
acstokes is offline   Reply With Quote
Old 02-27-2014, 10:34 AM   #58
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Originally Posted by acstokes View Post
Gary, It helps to read the manual.
I'm on my second Dill TPMS, first was marked on stems, no problems at all. Second set not marked on stems.
I don't have the manual right now but their Tech Support guy didn't have an answer why they were not marked ABCD
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 03-05-2014, 09:38 PM   #59
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Hitch was successfully installed and we are running the jacks up six inches from the base plates per Sean's suggestion. We took a a test run Tuesday and spent the night at a nearby RV area (about 90 miles one way).
Once we got on site, we started testing and doing some work on the unit. I was waxing the shower with the special polish and a hole just appeared in the shower wall (in this area the gel coat covered a hole...)
I then went outside and saw water dripping from the belly through the LED light above the sewer pipes. I went inside and could see water under the water heater, but no leaking pipes. No water was visible from outside observation.
We fired up the furnace in the morning and the heat register in the bath area was barely moving air. I am concerned the 3" duct is collapsed under the kitchen sink/microwave/oven cabinet. It looked like the intestines of a gutted animal around the furnace just before the cabinet was installed.
We will need to caulk around the shower door better than the current effort from the factory.
So more work next week.
Old 03-06-2014, 07:39 AM   #60
rperrym's Avatar
2017 28' Tommy Bahama
Hot Springs Village , Arkansas
Did the water come from the shower? This sounds like our new trailer we took delivery on in Sept. First trip out the shower poured water out on the floor. The threshold for the shower door was installed backwards. The lip was to the inside, so water ran down the door and poured out. The bathroom door would not stay closed as there is a gap between the door and the latch wall. The walls in the bathroom did not fit and had gaps in them, and all screws were exposed instead of having the white caps over them. The shower caulking looks terrible. Can not believe it ever left the factory that way, and the main reason we are taking it back in April. Also had a leak first night it rained.
Rick
rperrym is offline   Reply With Quote
Old 03-07-2014, 07:59 AM   #61
switz's Avatar
2014 31' Classic
Images: 8
No we did not use the shower because of the hole that appeared when I was trying to apply the was to the interior. We ran the shower head into the toilet to see if there were any leaks in the flex hose.
By lying on the floor and using a flash light, I could see a small puddle of water under the water heater (it is on the opposite side to the shower) with no water pipes showing drips.
The caulking job around the bottom of the shower door was poorly done with visible gaps that would become leaks. I will check for that lip on the inside.
The lift out floor in the closet was already bent out of square on a vertical riser. The wood screws would soon break out, so I used four steel angles to permanently make the 90 degree angle and it won't break now!
The entire kitchen cabinet may have to be removed to discover the cause (like a pinched duct) for the register in the bathroom as no air comes out of the opening with the furnace running.
ID:	206932   Click image for larger version
Old 03-07-2014, 08:48 AM   #62
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Could the water heater leak be caused by expansion in the system while heating the water, especially when using the electric heating mode. If there is no expansion "air bubble" in the top of the water heater the pressure will find a place to escape. Usually out the water heater pressure release valve, but if there is a weak connection somewhere it may release there first.
Could the puddle under the water heater be from the dripping pressure release valve finding a path inside and under the heater? The solution may be to simply restore the air bubble in the water heater. Turn off the water supply, open a nearby faucet and leave open, lift the pressure release valve tab so excess water can drain out and air can enter from the open faucet. Release the pressure release tab, close the faucet, and turn the water back on.
I also installed a small water pressure accumulator under the bath sink to help take up this excess pressure. But that electric heater mode really heats, tends to "boil" a bit of steam for a moment when it's on and you open a faucet, thereby lowering the boiling point inside the water heater (like opening a hot radiator cap). It can spit some water out the pressure release valve for that instant.
Doug and Cheryl
Old 03-07-2014, 08:52 AM   #63
dkottum's Avatar
Our bath heater duct barely provides furnace air as well. I attribute it to size, length, and routing of the duct hose. It is adequate for this tiny space though.
Doug and Cheryl
Old 03-07-2014, 08:58 AM   #64
dkottum's Avatar
And I poked a tiny hole in the inside corner of our shower while using a squeegee after a shower. I was careless and didn't consider the hard edge of the squeegee, and the thin construction of the shower stall in the corner. I patched it with some white sealant and it works fine, don't notice it anymore.
Doug and Cheryl
Old 03-07-2014, 10:41 PM   #65
switz's Avatar
2014 31' Classic
Images: 8
There was no sign of water dripping at the pop off valve or the drain plug when looking at the outside of the water heater. That space was dry. The only moisture was directly under the one corner of the water heater.
It was a slow continous drip overnight.
The photo above of the duct work shows the two runs crossed even before the cabinet was was placed on top of them. I am concerned that no one paid attention when connecting the other ends to the registers that they did not uncross the the two runs and one run to the bath area is now collapsed.
Old 03-08-2014, 06:33 AM   #66
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Hi Switz. On my hot water heater, the flexible hose was cross threaded where it connects to the check valve. This showed up via a puddle of water on the floor under the dinette seat on our first trip. The fix was to remove the dinette seat in order to get at the HWH and then replace the hose. The hose is a 9" hose but the only replacement available was a 15 " hose. I made it work. The cross threading was the result of sloppy workmanship, but yours does not appear to be cross threaded unless it was fiddled with after the photo was taken. It could also be just a poorly made hose. I also had to sort out the ducts that were accessible under the wardrobe where the water pump is located and tidy up all the wiring that was haphazardly jammed in there. One needs a vacuum and plastic ties as part of his everyday arsenal for the first while since little bits and pieces seem to be rolling around on the floor after every leg of a trip. Really like your set up, ready for a big time roll. Jim
Jim Flower is offline   Reply With Quote
Old 04-07-2014, 06:07 PM   #67
switz's Avatar
2014 31' Classic
Images: 8
The shower was repaired by a fiberglass shop under warranty.
My factory photo before the kitchen cabinet was set (five minutes or less from when photo was taken) of the crossed ducts just coming out of the furnace was the culprit for lack of airflow. The dealership mechanic was able to uncross the ducts and now there is more than enough air flow in the bath as well as the bedroom. That oversight redistricting air flow could be a fire hazard if the furnace were to get too hot from lack of air movement.....
The water leaked was not replicated by the dealership, so we will see what happens on the next camping trip.
I received photos today of the new custom stainless steel battery box with the four lifeline batteries sitting in it as well as a photo of the Titan disc brake pump sitting in the original battery box. I will take pictures of the solar panels this coming Thursday when I fly to pick the truck and Airstream up to drive back to Arizona.
ID:	209185   Click image for larger version
Name:	Battery box cover_small.jpg
Name:	Titan pump in old battery box_small.jpg
Old 01-14-2015, 03:32 PM   #68
2004 25' Safari
Fergus , Ontario
Can anyone tell me the measures of the closet in the 30 ft to the 31 classic
paulredkw is offline   Reply With Quote
2013 classic
