Old 01-28-2014, 09:15 AM   #43
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The one key solution?
Our 2013 25FB International Serenity had the usual 751 key for the water access door and a different keying pattern on the same blank for the outside access hatch under the bed. This provided a token of security. On this forum, folks have stated they climbed through the outside access hatch (not me in my shape or agility) and lifted up on the mattress and got into the coach to get their keys.
Thus the only minimalist security would be a latch with a spring clip to keep the mattress from being easily lifted.
There are four outside access hatches on our new trailer. The rear one gains access only to a totally enclosed box below the night stand and the heads of the two twin beds. The two (one on each side) under the twin mattresses could provide access like above. The small side hatch forward would require lifting the bench seat and seat springs of the forward seat of the dinette.
This trailer has the new all plastic locks design for the external access hatches that will be a great replacement parts sales provider for Airstream and the dealers.
The thin wall of solid wood creating the outside wall for the pocket door (other side of the door is the shower area) is bowed inwards in the middle, thus rubbing the door when one tries to slide it. Perhaps the wood was not completely cured and sitting outside unheated in the sub-freezing temperatures at Jackson Center for over a week may have caused this issue. Now that the unit is in the desert with even less humidity, it could change shape again.
The other pocket door has the trim broken away from the wall on the bathroom side with the nails exposed (other side is by fridge) so the wall piece rubs on the door. This could be a simple carpentry repair.
The dented ceiling material issue may require a vinyl panel be removed and replaced and one would like the factory to do the work to make the job look original rather then look like I tried to fix it.
The outside aluminum lower door hinge needs to be replaced due to very deep gouges, a kitchen door was chipped and it should be replaced, and a chrome plastic trim piece has buckled out (this was pointed out at the factory before I left) between the wheel well and the lower center awning support attachment location. The stove will have to be removed to paint the scratched areas on both sides at the front.
A rewash today that is perhaps more more than thorough will get the road salts off the nooks and crannies.
So far there is nothing that precludes using the trailer as just the wife and I will be in it and the lack of operational pocket doors is not that much of an issue after I get the privacy curtain installed beside the toilet.... We can use styrofoam wedges to secure the pocket doors to prevent rubbing while moving.
I am thankful no rocks hit the side of the trailer or windows.
While at the dealership yesterday, along side was a 62 vintage Airstream about 26' long that was polished. Then I looked at the side of ours and realized there was no way I could ever "polish" that huge billboard!
Old 01-28-2014, 09:20 AM   #44
2013 28' International
Bozeman , Montana
I'm sorry to hear of the problems. Hopefully this can all be sorted out correctly and to your satisfaction.
HeadWest is offline   Reply With Quote
Old 01-28-2014, 12:31 PM   #45
casarodante's Avatar
2012 31' Classic
Sorry about the issues but we know where you have been. We got ours about a year ago off a showroom floor.
On our trip home we lost a 2" half moon portion of the front edge of our kitchen countertop. It appears it had been glued back on? Perhaps by the dealer or transporter. We find out the lower kitchen cabinets only had one screw holding them to the outside wall. They move away from the wall and screwed up the counter.
We are very dismayed when you spend the amount of money that we do for these trailers that they are not in better shape. Airstream also seems to be using very cheap materials for latches and other important pieces.
I attached our first punchlist when we took it in for service.
Name:	2013-03-02 14.50.12.jpg
Roger & Roxie (rore62) Smith (Air#178 - WBCCI#1646)
On the road!
2012 31' Classic - Nuestra casa rodante
Blog: https://www.casarodante.org - Old Airstream slides: https://airstream.casarodante.org
casarodante is offline   Reply With Quote
Old 01-28-2014, 01:13 PM   #46
Bozeman , Montana
How did things turn out with your punch list items? Were you happy with the repairs and getting these items fixed?
Old 01-28-2014, 02:07 PM   #47
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We had no punch list to take back to the dealer, the Airstream was very well assembled.
But I did go through the entire trailer to adjust and lube latches and locks, used the Airstream entrance door adjustment video (crude but effective) to get a nicely operating door, check tightness of fasteners and plumbing fittings, and vacuum out the voids. Stuff a dealer probably should do.
I suspect that first trip from factory to dealer shakes things up and takes any tension out component assembly at the factory. Some of this can be expected by the nature of the product and process, but hopefully fixed before the customer sees them.
Like many have claimed, get the assembly bugs out and things get much better as we enjoy the travel, adventures and memories our trailers give us.
Doug and Cheryl
Old 01-28-2014, 02:56 PM   #48
2012 31' Classic
I was very happy with the dealer (Toscanos) that fixed the items. They were not the selling dealer.
We still have a few issues. Some I fixed myself (sliding doors).
As a previous poster said it truly is all about the shaking out. We have had it a year now and feel confident about things staying together.
My wife stated that our '92 didn't have many problems. I reminded her that my parents had it for almost 10 years before we did so my dad had plenty of time to get things right.
On the road!
Old 02-24-2014, 06:51 PM   #49
switz's Avatar
2014 31' Classic
Images: 8
Took our 2014 Classic model 30 off the dealership lot today. It had been there since 27 January. The batteries were allowed to run down due to the CO detector, so they were recharged. All the punch list items will be addressed later at another facility. They did fill the water tank and both propane tanks, so we may try a barebones overnight this weekend to see what else needs attention.
I towed it the 19 miles home with just a straight hitch. The truck and trailer were level due to the level ride air suspension.
But the unit could wiggle some.
Tomorrow is ProPride installation day for me. That will definitely cure the wiggles.
If I get that accomplished, then the next day is 16" Michelin tires install day for me as they are in my storage unit mounted with the Dill TPMS and ready to go with the Centramatic wheel balancers.
The following day will be scales day using my scales to get a base weight and tongue weight.
Old 02-24-2014, 08:30 PM   #50
StreamNTyme's Avatar
2007 25' Safari FB SE
Carolina Low Country , South Carolina
Images: 27
Nice, very nice. You will have many great years traveling in your new Airstream.
Safe Travels!
StreamNTyme
StreamNTyme is offline   Reply With Quote
Old 02-24-2014, 10:34 PM   #51
time2play's Avatar
2013 30' Classic
Kent , Washington
Happy Travels! We love our Airstream. I know you're going to totally enjoy the 30' Classic.
Yolanda (and Phil)
2013 30' Classic Limited
2015 GMC Sierra Denali 2500HD
ProPride 3P Trailer Sway Control Hitch
WBCCI #7878
time2play is offline   Reply With Quote
Old 02-26-2014, 07:13 AM   #52
switz's Avatar
2014 31' Classic
Images: 8
Tires and Electrical
Well, yesterday turned into the 16" Michelin tire & SenDel wheel with Dill TPMS install day as the trailer had to be at it's new height before starting the ProPride hitch installation. I also installed the Centramatic wheel balancers and used new McGard lug nuts with one special keyed locking nut on each wheel. I was worn out by the time I finished as I loaded five tires and wheels into the truck at the storage unit and unloaded them at the trailer. After swapping the tires out, I then loaded the five OEM wheels and Marathons at the trailer and unloaded them at the storage unit.
So, I will be selling the five Marathon tires mounted on the four Airstream Classic factory aluminum wheels and one steel spare wheel along with the factory lug nuts. Four of the tires have about 2,000 miles on them as the trailer was towed from Jackson Center, Ohio to Mesa, Arizona while the spare has only been hand rolled around to the truck to go to the storage unit.
The new Magnum MSH series hybrid converter/inverter has a 120Vac wiring terminal strip that only supports one hot leg and one neutral leg going into the box and the same coming out of the box. With the Airstream 50 amp service option, there are two hot legs and one neutral that have to go into the box and out to the circuit breaker panel. Thus we will have to go with the Magnum MS 2812 as it has the necessary connections for three wires in both directions.
Today is ProPride install day.
Old 02-26-2014, 02:45 PM   #53
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
switz,
Could you check two things on the Dill TPMS please?
1. Did you get the new monitor? Can be identified by checking the back, new monitor has 2 covers for the "chips" old one only has 1 cover.
2. Are your TPMS sensor stem "nuts" marked A, B, C, D?
I just checked my new system part number 1504-416 and it has the new monitor (manual is for the 1506-08&10) but the nuts are not marked A, B, C, D so you cannot index them to a tire location based on the letter on the nut. I think you could reduce the air pressure on 3 tires -2, -4, -6 and drive just long enough for the transmitters to activate and identify the wheel positions. Then re-position chips to match and restore normal air pressure. I'll be firing mine up this weekend.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 02-26-2014, 03:10 PM   #54
acstokes's Avatar
2009 30' Classic
Melbourne, FL , Searsport, ME
I'm not Switz, but I just bought and installed the Dill 1504-453 (6 sensors) last week along w/Sendels & 16" Michelins. My sensor stems were labeled A-F and the monitor had 2 covers for the chips....one cover on each end. The easiest method is to keep track of which letter sensor you put in which tire and mount the wheels on the TT accordingly. You can re-position the chips in the monitor if necessary or they get mixed up.
Fred Stokes
RV Rearview Camera Systems, LLC
WBCCI #2810
acstokes is offline   Reply With Quote
Old 02-26-2014, 04:17 PM   #55
GCinSC2's Avatar
Fred,
I'm on my 2nd Dill TPMS due to converting to 16's. My old stems were marked ABCD, the new ones are not. Called Dill already and asked how do you match wheel position to display. Long pause.............. They also have a numeric code on the sensor body that matches the chip but once the tire is mounted, can's see it anymore.
2 covers = new display and you got 6 monitors so that mandates the new display also.
Just curious how switz' new system was setup.
Gary
S/OS #001
Old 02-26-2014, 10:22 PM   #56
switz's Avatar
2014 31' Classic
Images: 8
No one at the tire shop recorded the letter on the senders and which tire they were in. I went back and they broke the tires down and put the letter on each tire. I used permanent marker to write the letter on the inside of the wheel in multiple locations. I then put the letters in the appropriate location on the display which has the two covers. So the tires, wheels with the Dill TPMS and Centramatics are on. Lookin' Good!
Unfortunately, I hit a major snag on the PPP install today and can't unhitch until some parts come in (⅜" filler plates for the jacks to go between the frame and the edges of the "u" channel in the PPP jack base. I will also have to drill opposing corner holes on the curb side jack for the u-bolt to get the jack in the proper location.
Tomorrow, I will take the portable band saw and trim edges off the jack bases when at 26" from the center of the hitch ball so I can open the battery box lid and be able to lower the propane tank cover down to the frame. I will also, get some black rust-oleum spray paint for the raw edges I will generate on the jack bases.
Hopefully the parts come in Friday and I can get the hitch job done that afternoon. I have lots of small accessories to install while waiting for the hitch parts.
2013 classic
