Old 03-26-2016, 12:27 PM   #1
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Humming/buzzing from propane tank area
I just replaced my batteries. While down there changing batteries I noticed a constant humming coming from the propane tanks.
Does the regulator make noise?
Does the gauge make noise?
I didn't really notice it before changing batteries.
The noise seemed to go away after I changed the batteries and turned the power back on.
Freaky/weird...
What's up with that?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-26-2016, 12:32 PM   #2
1998 30' Excella 1000
Livingston , Texas
Freaky/weird...
I had the same thing happen. I thought maybe the regulator was failing. The humming went away. That was over two years ago. Regulator is still working fine.
Siegmann is offline   Reply With Quote
Old 03-26-2016, 01:31 PM   #3
1994 34' Excella
Warren , Manitoba
That is just the new batteries humming a "happy tune" that they have a new permanant home!! Seriously, I had the same thing when replacing batteries on mine, couldn't figure out what the heck was making the noise, but it went away, and no problems. Replaced the old Boat Anchor charger with a PD9245 as I thought that was the problem. Chris
WBCCI #7394
2002 Chev 2500 HD Duramax
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 03-26-2016, 02:34 PM   #4
1986 31' Sovereign
Miami , Florida
The propane regulator will occasionally hum along happily depending on demand and ambient temperature. It is attention getting but harmless.
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 03-26-2016, 03:13 PM   #5
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Mine does that depending on flow.
Kelvin
Old 03-26-2016, 03:16 PM   #6
m.hony's Avatar
2013 30' Classic
There may be a new converter/charger in my future.
If the OE Parallax doesn't charge my new AGM's, I'll get a Progressive Dynamics PD9260.
TAC #MS-10
Airforums #70955
Old 03-26-2016, 03:36 PM   #7
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
Running the fridge on gas, early in the morning I had a water drop on tin sound that would wake me and I couldn't figure out what it was. I finally got up as the noise was in progress an felt around to find the noise. It was the regulator diaphragm with a small pop, I felt it. Warmer temps and more flow (stove top) no noise. I replaced it.
"Chip Tank" is in Flagstaff Az.
CDONA is offline   Reply With Quote
Old 03-26-2016, 03:45 PM   #8
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
A propane tank will hum when it is getting low on propane. Time to switch over the tanks.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 03-26-2016, 05:54 PM   #9
m.hony's Avatar
2013 30' Classic
Both are full.
TAC #MS-10
Airforums #70955
Old 03-26-2016, 07:37 PM   #10
Wise Elder
Jammer's Avatar
2010 30' Classic
The propane regulator on my trailer hums when there is propane in use but at a very low flow rate. Sometimes the vibration causes the floats in the propane tanks to make noise, too. I think it's a harmless, mild annoyance.
Old 03-26-2016, 08:08 PM   #11
m.hony's Avatar
2013 30' Classic
No propane in use.
In a campground hooked to shore power-
Running water heater on electric-
No need for furnace-
TAC #MS-10
Airforums #70955
Old 03-26-2016, 08:56 PM   #12
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Mine hums too. Weirds me out.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 03-26-2016, 09:06 PM   #13
2016 30' Classic
Erie , Colorado
Michael time to get a 3 stage charger. The OE Parallax, according to many, is a death sentence for the AGM's.
Regulator do sometimes hum. Normally a happy tune like "Its a small world". After about a 100 choruses or so you won't hear it any more from the heavy drinking to make it go away
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 03-26-2016, 09:06 PM   #14
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
If gas is going through the regulator it will "hum", and if it is "humming", gas is going through it.
It is a sound created by the harmonics of the action of the pressure being regulated by the diaphragms. (Rapid oscillation of on and off)
The flow oscillates, as does the pressure within a narrowly defined range, thus the noise.
If nothing is on, and the regulator makes noise, you have a leak.
Superat stultitia.
humming gas tank mixedpuppy LP Gas, Piping, Tanks & Regulators 2 11-29-2015 07:59 PM
Propane Tanks Humming Mrs. Bale LP Gas, Piping, Tanks & Regulators 3 02-19-2012 02:54 PM
Humming / buzzing when hooked up to elect likable_1 Batteries, Univolts, Converters & Inverters 3 08-23-2011 11:42 AM
Buzzing Radio farmerjim General Motorhome Topics 1 02-07-2004 08:56 PM
Univolt Low Buzzing Noise rjones1138 Electrical - Systems, Generators, Batteries & Solar 23 07-16-2003 06:23 AM
