Old 03-28-2016, 08:10 PM   #29
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
No.
Nothing was on-
Electric or gas-
Unless the refrigerator will run with no 12 volt DC power being supplied-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-28-2016, 08:33 PM   #30
1998 30' Excella 1000
Livingston , Texas
Originally Posted by m.hony View Post
No.
Nothing was on-
Electric or gas-
I was suggesting you try to experiment to see if you can cause the sound again. Maybe those new fridges are able to switch over to gas for a bit. Don't know.
Siegmann is offline   Reply With Quote
Old 03-28-2016, 09:24 PM   #31
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Wellllllll.. here goes...
The folks are telling you, the only way for the regulator to 'hum'/vibrate... is flow.. at just the right volume to cause oscillation of the diaphragm inside the regulator...
I had this happen on several propane devices:
1- propane burner (crawfish boiler)... turns out there was a slow leak at the control valve
2- propane BBQ pit ... was a leaky control valve... another time, the 'orifice' was restricted... and set the harmonics.... replaced the BBQ pit once and replaced the valve the next time.
3- a lot of the 'odorant' had found it's way into the supply lines... then found their way into the control(valves).. clean lines/devices.. even the regulator..
4- a 'solenoid' valve was sticking 'open'... jussssst a bit... Replaced the solenoid.
5- a bad regulator, venting propane to atmosphere..slowly.. and you can smell it, if the wind blows the right way... soaping down ALL of your connections is a minimum. You may have picked a crease in the propane line from road debris... and if leaking outside the AS, so, you won't get your LP detector to fire.
Now.. what if... the fridge went from on/off/on... with AC and DC power changing, did the low voltage cause a logic problem with the Fridge control panel causing the solenoid valve to oscillate or leak..?
These are not things to 'dismiss'...PLEASE have the system 'LEAK CHECKED'!!!
Peace and Blessings..
Channing
WBCCI# 30676
Old 03-29-2016, 04:27 AM   #32
m.hony's Avatar
2013 30' Classic
Why would the noise stop when the batteries are hooked up?
TAC #MS-10
Airforums #70955
Old 03-29-2016, 04:29 AM   #33
m.hony's Avatar
2013 30' Classic
Never smelled anything outside or inside.
Propane detector never went off.
I was wondering if the noise continued until the lines themselves were full and then stopped.
TAC #MS-10
Airforums #70955
Old 03-29-2016, 11:25 AM   #34
Livingston , Texas
Ok, let's back up. I thought you were occupying the rig and the propane system was pressurized. But you wonder if the noise occurred until the lines themselves were full. So had the propane system been off before you did your work and you had opened the tanks when you got there?
Old 03-29-2016, 11:56 AM   #35
m.hony's Avatar
2013 30' Classic
No.
Just never noticed the noise until I disconnected power and removed batteries.
Then the noise stopped when I reconnected batteries. I wonder if something about the gauges could cause the noise. Seems like the gauges would have to be pressurized to get a reading or to show the propane level on the monitor inside the trailer.
Couldn't decide if it was the gauges or regulator before it stopped and I haven't investigated any further.
Just thought someone here might have lived the same thing at some point in life-
TAC #MS-10
Airforums #70955
Old 03-29-2016, 03:40 PM   #36
Livingston , Texas
No.
Regarding the gauges on the tanks, unless they have changed them, they are float gauges. Not likely the source of your noise.
Old 03-29-2016, 03:47 PM   #37
m.hony's Avatar
2013 30' Classic
So only thing left to make noise is the regulator?
There is an electrical connection to the propane tank gauges- I assume to the readout inside the trailer-
TAC #MS-10
Airforums #70955
Old 03-29-2016, 07:52 PM   #38
Livingston , Texas
Yup. Sounds the same as on my '98. That sending unit does measure the float position and transmits it to the readout inside.
Old 04-02-2016, 08:44 AM   #39
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
PM sent
Channing
WBCCI# 30676
humming gas tank mixedpuppy LP Gas, Piping, Tanks & Regulators 2 11-29-2015 07:59 PM
Propane Tanks Humming Mrs. Bale LP Gas, Piping, Tanks & Regulators 3 02-19-2012 02:54 PM
Humming / buzzing when hooked up to elect likable_1 Batteries, Univolts, Converters & Inverters 3 08-23-2011 11:42 AM
Buzzing Radio farmerjim General Motorhome Topics 1 02-07-2004 08:56 PM
Univolt Low Buzzing Noise rjones1138 Electrical - Systems, Generators, Batteries & Solar 23 07-16-2003 06:23 AM
