Old 03-04-2015, 11:09 AM   #1
gwg
gwg's Avatar
2015 30' Classic
Glen Mills , Pennsylvania
Thumbs up Hitch height
Can someone give me the hitch height for a 2015 Classic? Ours has just been delivered and I need to get set up with a new TV and the 16" wheels.
gwg is offline   Reply With Quote
Old 03-04-2015, 11:13 AM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
The dealer is your best source
Use the front jack to adjust the front and the rear of the trailer frame equal distances from a flat parking surface.
When the frame is equidistant, measure the top of the coupler. That is the coupler height.
Realize when you load the trailer it will change slightly downward.
The hitch ball height should be 1/2" to 1" higher than the coupler height, to allow for some tow vehicle squat.
I would target >19" as a preliminary ball height when not loaded, then do the final adjust once you get hooked up.
Alan
Old 03-04-2015, 11:18 AM   #3
gwg
gwg's Avatar
2015 30' Classic
Understood, but I have not taken delivery and want to be set up when I pick it up. I have a lifted truck and will need a drop hitch.
Old 03-04-2015, 11:24 AM   #4
SteveH's Avatar
Common Sense , Texas
I've never been about to set one and not have to go back and adjust, sort of trial and error. However, depending on the stiffness of your truck's suspension, I would start at 19-20" to the top of the ball.
Regards,
Steve
Old 03-04-2015, 11:51 AM   #5
1974 Argosy 20
Kooskia , Idaho
The hitch height should be listed in the manual, which is available from Airstream online free. If the 2015 is not there, use the 2014 ore 2013, they should be the same for your rig on order.
Old 03-04-2015, 12:43 PM   #6
casarodante's Avatar
2012 31' Classic
From our 2012 manual. But there is constant tweaking involved in a hitch assembly.
Roger & Roxie (rore62) Smith (Air#178 - WBCCI#1646)
On the road!
2012 31' Classic - Nuestra casa rodante
Blog: https://www.casarodante.org - Old Airstream slides: https://airstream.casarodante.org
casarodante is offline   Reply With Quote
Old 03-04-2015, 12:58 PM   #7
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
Alan and Steve's remarks are both valid.
The chances of getting it right the first time are not great.
Follow their advice, you'll be in the ballpark, and then be prepared to do final adjustments. It's not difficult to do it yourself with the proper tools.
Most important. If it's not precise when you take delivery, do that final adjustment. You'll be happy you did.
Good luck!
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 03-04-2015, 02:14 PM   #8
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
All the input on set it up when you pick it up are spot on. I would suggest you and the dealer personnel set it up when you get it. You can do some preliminary work on height but it's not going to be right on. If I recall the hitch height should be just right at 18", higher if measuring to the top of the ball, say 19.5"
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 03-28-2015, 08:52 AM   #9
gwg
gwg's Avatar
2015 30' Classic
Picked up our new classic Friday and enjoying our first of many camping (if you can call it that!) trips.
Old 03-28-2015, 08:56 AM   #10
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Sweet! Does it tow "level? Or a nudge nose high?
Peace and Blessings..
Channing
WBCCI# 30676
Old 03-28-2015, 09:04 AM   #11
gwg
gwg's Avatar
2015 30' Classic
Lowered my hitch about 2", it's adjustable but I want to get exact and change out to a class 5 drop hitch. I am not using a WD and tows well. I added air bags to my Ram 3500 Cummins, a little bit of over kill..
Hitch height Chuck Hitches, Couplers & Balls 20 04-09-2016 10:21 PM
Hitch Height vs. Ball Height adamwright Towing, Tow Vehicles & Hitches 5 02-12-2015 03:24 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
tow hitch height using a 1960s car oldvws Hitches, Couplers & Balls 15 11-27-2002 03:43 PM
Hitch height help daydreamer36535 On The Road... 4 09-28-2002 01:11 PM
