Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Classic > 2011 - 2015 Classic (all lengths)
Old 04-23-2017, 05:05 AM   #1
Villwocksbj's Avatar
2014 23' International
San Juan Capistrano , California
Fantastic Fan Problem
I have a 2014 23D and both my fan units continue to automatically close with the red led flashing even if not raining. Does high humidity cause this and is their a way I can by pass this automatic shutdown?
Villwocksbj is offline   Reply With Quote
Old 04-23-2017, 05:36 AM   #2
. , At Large
High humidity and dew can cause this, as well as dirt on the sensor.
On some models, you can disable the sensor, but if yours are OEM, you won't have the switch to do so. You can turn the fan speed to 0, though that will also shut off the fans. The sensor works by the moisture closing the circuit, causing the lid to close. It's not terribly difficult to disconnect the sensors, which should prevent this from happening. It will also prevent the lid from closing in the event of rain, so take that into consideration before disconnecting the sensors.
Fantastic fan not so fantastic PeterD General Repair Forum 8 11-16-2015 01:01 PM
Original fan vs fantastic fan KYAirstream Roof Vents, Skylights & Fans 16 08-14-2015 04:51 PM
Maxx Fan Vs. Fantastic Fan Lumatic Roof Vents, Skylights & Fans 19 09-07-2011 07:10 AM
Late 70's light/fan Fantastic Fan installation question tschat Roof Vents, Skylights & Fans 2 07-18-2009 01:30 PM
Fantastic Fan problem davidz71 Roof Vents, Skylights & Fans 10 02-07-2007 04:47 PM
