Old 02-04-2016, 01:47 PM   #1
2016 30' Classic
Livingston , Texas
Did Help for 2015-2016 Classic
Is there anyone out this with a 2015 or 2016 classic that can answer the following question:
1. what is the length, width and depth of the drawer under the "couch".
2. Dimensions of the area where the inverter is located
3. Dimensions of area where the converter charger is located
4. Where is transfer switch located.
Tried to secure this info from AS, but evidently after you place your order and post your deposit, they forget your name.
Thanksfor any assistance.
Molinari47 is offline   Reply With Quote
Old 02-06-2016, 06:42 PM   #2
2016 30' Classic
Santa Rosa , California
My 2016 Classic is at the dealer getting a few items fixed, so I cant give you exact dimensions. But if a good "guestimate" is Ok:
1. The drawer is about 22in wide, about 20in long and about 6in deep. There are wedge-shaped supports inside the drawer at front center and back center - these wedges somewhat reduce the available height by about 3 inches at the immediate front and back of the drawer. I'd say you could fit a 20x14x4 inch package in that drawer.
2. I happened to take a quick look under the front dinette seat weeks ago (when an upholstered panel cover came loose). I saw what I assume is the inverter attached to the street side wall. The electrical diagram in the manual confirms this, and says the transfer switch is there too. Wild guess: the inverter equipment "area" seemed to be about 1 ft wide, 9 inches tall, and about 4 inches deep.
3. The converter is located curbside, at floor level, behind a snap-on finished wood cover located at the left-side base of the wardrobe closet. Behind the wood cover is the usual hinged metal cover for the converter, AC breakers and DC fuses. The visible external area is about 1ft tall and 1ft wide. The literature for the Parallax 5355 unit says it is about 12H x 15W x 14D (in)
4. The button that turns the inverter on/off is located on the curbside wall between the left edge of the stovetop and the right side of the galley window, a few inches above the countertop. As I mentioned in #2, the electrical diagram says the inverter "transfer switch" is located with the inverter under the dinette seat, but I'm unsure if you are referring to that, or to the on/off button.
Hope that helps. If not, perhaps someone else with more precise information can step in.
phann is offline   Reply With Quote
Old 02-07-2016, 01:23 PM   #3
2016 30' Classic
Livingston , Texas
Thanks much. Very helpful.
Old 02-07-2016, 01:35 PM   #4
2016 30' Classic
Livingston , Texas
Old 02-07-2016, 01:39 PM   #5
2016 30' Classic
Livingston , Texas
One more question: dimensions of battery box? Thanks.
Old 02-08-2016, 10:53 PM   #6
2016 30' Classic
Again, a guestimate.... About 14in L x 14in W x 12in D
Old 02-09-2016, 07:21 PM   #7
2016 30' Classic
Erie , Colorado
If you download the Classic Parts manual from the AS website most of the furniture dimensions are listed. Not sure about the battery box.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
2016 AlumaFandango 9/20-25/2016 Glenritas Other Rallies & Events 14 09-26-2016 09:40 AM
2016 AlumaFandango 9/20-25/2016 Glenritas Other Rallies & Events 2 10-26-2015 04:57 PM
2015-2016 Classic Mattress ?? judyjudy 2011 - 2015 Classic (all lengths) 11 10-17-2015 03:08 PM
2015 International 30 vs 2015 Classic ZBoater 2011 - 2015 International 41 05-28-2015 08:47 AM
Difference in 2015 and the 2016 mid year? mrsmup Airstream Trailer Forums 6 05-16-2015 10:25 PM
