Old 08-07-2017, 10:31 AM   #1
time2play's Avatar
2013 30' Classic
Kent , Washington
Day Night Shade Hold Down
I'm getting ready to replace the bobbin on my day/night shade. The string is broken and the bobbin is broken too. I bought replacement bobbin, looks fairly simple, but wanted to check here first.
Any advice on this process? Anything I should watch out for?
Thanks for your help.
Yolanda (and Phil)
2013 30' Classic Limited
2015 GMC Sierra Denali 2500HD
ProPride 3P Trailer Sway Control Hitch
WBCCI #7878
time2play is offline   Reply With Quote
Old 08-07-2017, 10:48 AM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
When replacing, you must tension the string enough to keep the shade in position but not too tight or it will be hard to move. This may take more than two hands. IIRC you can install one side and then tension from the other. It has been a while since I did this so memory may be imperfect.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Al and Missy is online now   Reply With Quote
Old 08-07-2017, 12:32 PM   #3
time2play's Avatar
2013 30' Classic
Kent , Washington
Thank you. I only had to replace one side, the bobbin was a different size than the other one. But it doesn't seem to matter. Anyway, I took your advice, and we did it. So far, so good!
Thank you for the advice.
Yolanda (and Phil)
WBCCI #7878
Goin' down, down, down... Aironius Axles 12 08-23-2014 08:09 AM
Day/night shade tension adjustments? cwf General Interior Topics 3 03-15-2013 08:39 AM
Best way to get an older day night shade replaced? AtomicNo13 Upholstery, Blinds, Walls & Interior Finishes 2 08-15-2012 03:18 PM
Day/Night Shade Repair??? Paul Dobbin Land Yacht/Legacy Motorhomes 1 06-06-2009 04:27 AM
Replacement Day/Night Shade Bambi_Bandit Upholstery, Blinds, Walls & Interior Finishes 0 11-18-2008 10:42 PM
