Old 05-22-2013, 02:36 AM   #1
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Cast acrylic kitchen sink
The Airstream drawing for the dual basin sink shows it has been used at least since the 2007 model Classics.
Has anyone had any staining or breakage issues with this sink?
Has anyone replaced this dual basin sink (each basin is 10.5" x 11.75") for a more usable single basin sink?
Any other comments pro or con?
Thanks.
Old 05-22-2013, 07:07 AM   #2
dznf0g's Avatar
Oswego , Illinois
No issues here...it does scratch easily though.
-Rich-
Old 05-22-2013, 07:11 AM   #3
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
We have an '08 that was built in '07. Cast double sink in kitchen and basin in bath. We use our TT a lot and have had no issues at all with the sinks.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 08-21-2014, 08:14 AM   #4
2014 30' Classic
Columbus , Ohio
We accidentally placed a hot pan in the sink and it melted (not through the entire material.). Anyone know if this type of damage can be repaired? We own a 2014 Classic 30'. Thanks!
Kokomogoggy is offline   Reply With Quote
Old 08-22-2014, 08:26 AM   #5
switz's Avatar
2014 31' Classic
Images: 8
I believe our Classic kitchen sink is also Corian like the countertop and glued to the underside of the countertop. Thus, one would remove the countertop and flip it over to cut the sink off and install a replacement. Would be a great time to consider other design sinks as well.
Our bathroom sink (same material) has developed a small crack. The counter top is wedged between the two walls. Without removing the refrigerator and the common wall with the bathroom, there is no easy way to remove and replace the counter top.
During the build, I saw the left bath wall and the complete vanity with countertop in place. That was all that was in place at that moment street side. Thus adding the common wall with the refrigerator effectively boxed in the countertop.
2013 classic
