Old 09-27-2014, 02:02 PM   #1
time2play's Avatar
2013 30' Classic
Kent , Washington
Bed stuck in the UP position - HELP!
Okay, nobody laugh please. This is probably a first. Our bed was lifted up to access the storage space, and now we can't seem to figure out how to push it back down. The two tension rods holding up the wooden slat seems to be stuck.
Any suggestions? Is there a button or something that will releases the rods. We hate to keep pulling/pushing them, don't want anything to break.
Help! And thanks.
Yolanda (and Phil)
2013 30' Classic Limited
2015 GMC Sierra Denali 2500HD
ProPride 3P Trailer Sway Control Hitch
WBCCI #7878
time2play is offline   Reply With Quote
Old 09-27-2014, 02:13 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Maybe one of you lift and take the load off the rods. And the other try to move the rods toward the closed position. Maybe the rods are stuck in an "over center" position and locked.
David
Old 09-27-2014, 02:16 PM   #3
time2play's Avatar
2013 30' Classic
Kent , Washington
David, we tried that. The rods do seem to be locked, and nothing seems to be working. Just of curiosity, how does one normally lower the bed? Does it normally just go down, or is there something you have to do to "unlock" the rods?
Thanks!!
Yolanda (and Phil)
WBCCI #7878
Old 09-27-2014, 02:25 PM   #4
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
We haven't had this problem but I've seen the advice to others that have - press harder! There isn't a button (that I'm aware of) to release the pressure. Just press harder than you think you should. Good luck!!
Old 09-27-2014, 02:25 PM   #5
Mike91208's Avatar
2009 27' FB International
LA LA Land... , California
Don't know if your bed is like ours (queen), but we faced this as well, in the beginning. You just have to use a lot of force to push it back down. No locks or releases. Just PUSH!
Mike91208 is offline   Reply With Quote
Old 09-27-2014, 02:36 PM   #6
time2play's Avatar
2013 30' Classic
Kent , Washington
Really? Just push? Oh my gosh, we tried to push and it seemed like we were going to break it! We were afraid to push harder. We ended actually unscrewing the ends of the rods and released them. Obviously a temporary solution, but we had to get that bed down!
Once we calm down, maybe we'll screw the rods back in and give it a try. Or maybe we'll just have the Airstream service department show us how it's done when we return the trailer tomorrow.
For now, it's down and I'm happy.
Gosh, should something that simple be that difficult?
Thank you all again!
Yolanda (and Phil)
WBCCI #7878
Old 09-27-2014, 03:02 PM   #7
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you have a couple of 2x4s and a hinge make up a system with the rod that has the same dimensions as the bed and push on it. At least you won't brake the 2x4s and that will tell you how much force you have to use. It is unlikely the gas cylinders are stuck inside so give it a try.
2004 Excursion 4x4
Old 09-27-2014, 03:36 PM   #8
casarodante's Avatar
2012 31' Classic
Very odd. On our 2012, we just push it back down. However with two memory foam pads sometimes we have to hold it up even with the rods.
Definitely have the service department check if you can.
Roger & Roxie (rore62) Smith (Air#178 - WBCCI#1646)
On the road!
2012 31' Classic - Nuestra casa rodante
Blog: https://www.casarodante.org - Old Airstream slides: https://airstream.casarodante.org
casarodante is offline   Reply With Quote
Old 09-27-2014, 04:01 PM   #9
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
Yup, just be firm with it. Our 2011 had the same issue but I gave it a stern talking to and just pushed; all is well
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 09-27-2014, 09:11 PM   #10
Hibby's Avatar
2018 33' Classic
2015 30' FB FC Bunk
2012 30' Flying Cloud
Grand Rabbits , Michigan
Agreed, same issue here. Push, but I would recommend direct pressure over the rods rather than from the end of the bed. You may also look at how well the rods are mounted to the wood frame below. I had to replace the screws in my gas struts because they weren't deep enough.
Hibby
Hibby is offline   Reply With Quote
Old 09-27-2014, 09:53 PM   #11
time2play's Avatar
2013 30' Classic
Kent , Washington
Thank you so much everyone!! I appreciate all the advice. I knew I would find the answer here. Hibby, good suggestion on where to apply pressure.
We still haven't tried to "push down hard", we'll give it a try tomorrow.
Thanks again!
Yolanda (and Phil)
WBCCI #7878
Old 09-28-2014, 05:34 AM   #12
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I think you just gotta push down harder.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-28-2014, 05:44 AM   #13
Msmoto's Avatar
2015 30' International
2007 25' Safari
Greensboro , North Carolina
Images: 135
If, for reasons not understood, there is the phenomenon called "stiction" especially in gas shock absorbers, this might be an issue here. A synthetic lube, used extremely sparingly on the push rod, near the actual gas tension rods, may help to eliminate a recurrence of this problem. A spray synthetic lube may help to get the bed closed.
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Help! Bed is stuck in up position! Honeybadgers General Interior Topics 8 07-05-2014 07:31 AM
Over the bed light switch stuck AIR-Quarius Lights - Interior & Exterior 1 12-05-2011 02:55 AM
Screen door stuck in closed position ESCAPE POD Doors & Locks 4 10-31-2011 03:30 PM
Changing bed position in a 25' FB ocean Breeze Charlotte General Interior Topics 4 07-03-2010 06:27 PM
Sleeping position: Corner bed owners ericwarren Our Community 13 11-05-2008 07:15 PM
