Old 02-12-2015, 06:11 PM   #1
carver 1's Avatar
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo , Florida
Images: 30
Antenna signal malfunction. Door bell?
We love our new to us classic 30. We forgot how much a difference of 5' can make. Two questions:
1. The PO only used the satellite antenna and i am trying, unsuccessfully, to use the standard antenna. I keep getting the message that the antenna connection is weak despite the fact that the green light is on at the booster.
Should there be a coax hooked into the booster? To the right of the booster there is the connections for the satellite with a short piece of coax connecting the in and out male connectors. Help
2. Door bell does not work in spite of replacing the batteries.
>>ron<<
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
carver 1 is offline   Reply With Quote
Old 02-12-2015, 07:23 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
1. Is the ant. raised all the way up and properly aligned?
2. Sorry, I got nothing. Never had a door bell in a trailer.
MICHAEL
Old 02-12-2015, 08:27 PM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Where are the television(s) you are trying to use? To use the antenna, each TV should have a coax cable connected to a nearby wall jack. As Michael said, the antenna must be raised and pointed in the direction of the TV transmitters. You must set the TV for off-air signals and scan to detect them.
The jumper is where the satellite receiver would be connected. Without satellite, the outside coax connection goes through the jumper to the preamp switch and is used for campground cable with the preamp switched off.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 02-12-2015, 08:28 PM   #4
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I don't have my manual with me but I recall something about a small coax jumper cable that's either connected or disconnected when using satellite. In my 27fb it's under the dining table. I've never used satellite so however it's configured works for antenna or cable for me. Wish I could be of more help....
Old 02-14-2015, 10:07 AM   #5
1983 31' Excella
The Woodlands , Texas
I popped out my door bell button and found a replacement from Lowes. It glows in the dark. Works great.
Air83 is offline   Reply With Quote
Old 02-14-2015, 11:08 AM   #6
oldfulltimer's Avatar
1993 34' Excella
Randolph , Vermont
For your standard antennae, the green light on the booster box only means that it is turned on. You should have 12vdc at the connection to your antennae, but if it's a bat wing type antennae, it's possible that the bat wing itself is bad. If you are getting 12 volts at the connection and still no reception than your bat wing could be bad assuming that you have a digital TV and not an analog TV trying to pick up a digital transmission.
oldfulltimer is offline   Reply With Quote
Burner malfunction 78SovIntl31 Stoves, Ovens & Microwaves 2 01-26-2014 05:03 AM
RF causing brake controller malfunction nm1oqrz Phone, CB & Ham Radio 6 04-12-2011 06:03 PM
GM truck antilock brake malfunction dwightdi Tow Vehicles 20 03-13-2006 04:38 PM
345 LP Tank Gauge Malfunction cooperhawk LP Gas, Piping, Tanks & Regulators 1 12-06-2005 01:36 PM
water heater malfunction--help! ready to depart for xmas trip! susanborck Water Heaters, Filters & Pumps 23 12-22-2003 10:31 PM
