Old 04-27-2015, 07:43 AM   #561
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Congratulations to Page and Bob. The best part is YOU WILL NOT BE HOMELESS!
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 04-27-2015, 07:50 AM   #562
2015 30' Flying Cloud
2016 30' Classic
Covington , Louisiana
Fiamma bike rack
Has anyone installed the Fiamma bike rack on a 2015 Classic? If so, are you happy or unhappy you did so and why?
Sjcjr is offline   Reply With Quote
Old 04-27-2015, 08:59 AM   #563
2016 30' Classic
Erie , Colorado
Rod
I setup the stinger so that the top of the stinger that goes into the trailer head was at 15". 14" worked for my FC25 and according to the AS hitch info the head of the Classic is 1 inch higher. That worked out perfectly.
I'm running at 6". Front fender is within 1/2 inch of unloaded condition. I'll hit the scales as I leave Rapid City. CAT scales are next door to where I am camping, Americas Mailbox's small campground.
Not sure on the Fords but GMC says their target is to measure the wheel well and be at the halfway point between the unloaded and loaded without WD engaged. So in my case I use that as the guideline and then check with the CAT scales. For the FC25 is was a couple of 100# less after hookup.
And for right now I am at 80#. Lots of opinions on PSI settings. Seems to be riding well at 80 and nothing is moving that I have left on the counters even with some rough highway joints on the trip. Towing at 67-68mph.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 04-27-2015, 10:00 AM   #564
beetlebob's Avatar
2015 30' Classic
Green Cove Springs , Florida
Babs If you could not tell we were starting to get nervous
beetlebob is offline   Reply With Quote
Old 04-27-2015, 10:10 AM   #565
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Are y'all heading to Florida this afternoon, or waiting until tomorrow morning?
Old 04-27-2015, 05:59 PM   #566
Everyday is a GIFT !!
Nelson428's Avatar
2015 30' Classic
Collins , Mississippi
Send a message via AIM to Nelson428
Congratulations!! Enjoy
J. Nelson
WBCCI # 5314
J. Nelson
TAC # MS-12
WBCCI # 5314
AirForums # 66116
Nelson428 is offline   Reply With Quote
Old 04-28-2015, 05:46 AM   #567
beetlebob's Avatar
2015 30' Classic
Have closing on the house work. Funny how you don't miss things once you sell them. Empty house(yea). Going soon to get and then have to add the electronic stuff. Will be at Alumiapluzza. Think Airstream needs to start prewiring for WIFI boosters and cell phone boosters. Everyone has one now and not going away.
Old 04-28-2015, 07:13 AM   #568
Airstreaming Pagey
Pagey's Avatar
2015 31' Classic
Make that Alumapalooza. :-)
Page
May your days be filled with love and laughter.
Pagey is offline   Reply With Quote
Old 04-28-2015, 08:43 AM   #569
Remax gal's Avatar
2014 27' FB Eddie Bauer
Lake Placid , Florida
So Pagey and Beetle Bob...have you picked up your baby yet?? Ours is due in Orlando on Wednesday!! Such an exciting time!
Laura & Tom
Let the good times roll!! Laura
Remax gal is offline   Reply With Quote
Old 04-28-2015, 10:15 AM   #570
Nelson428's Avatar
2015 30' Classic
Hey y'all don't forget to post pictures.
J. Nelson
WBCCI # 5314
J. Nelson
TAC # MS-12
WBCCI # 5314
AirForums # 66116
Old 04-28-2015, 11:34 AM   #571
beetlebob's Avatar
2015 30' Classic
If all goes well we will be in it Saturday wit a trip to Disney on the way home. No better place to break in an Airstream than at Fort Wilderness.
Old 04-28-2015, 02:13 PM   #572
BAB
BAB's Avatar
2015 30' Classic
Trusting Terry's knowledge, I torqued my wheel lug nuts to 110. I had the occasion to remove a number of them. What I found was that every single lug nut was rusty. The lug nuts were probably fine when they went on, but I have a sneaking suspicion that the chassis of my trailer sat out in the snow in the A/S backlot prior to the build. Which means there are 24 rusty wheel studs on my trailer. Which means that IF I have a flat tire on the road I may well have issues removing a wheel. Rusty wheel studs and cheap lug nuts (soft plating) spell disaster. I think this will constitute a warranty fix.
_________________
ProPride 3P
AIR# 58452
Old 04-28-2015, 04:05 PM   #573
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
I replaced one of my Michelins last weekend (110 lbs ft) since it had suffered from a little premature wear and tear on the outside edge due to a slightly misaligned axel. Most of the lug nuts were not only rusty on the inside but also suffered from cracked plastic on the outside. Not vey impressive quality. Where does one get a better lug nut?
Jim Flower is offline   Reply With Quote
Old 04-28-2015, 04:17 PM   #574
BAB
BAB's Avatar
2015 30' Classic
I bought McGard 64010 Lug Nuts. A set of 4 costs 12.99. Around $78 to replace all of them. I am very unimpressed with what came on my Classic. They seem to have a very soft overlay of chrome, so if you don't have your 3/4" or 13MM socket on ABSOLUTELY perfectly, it is very, very easy to round the edges. Naturally, if you get them round enough you can't get them off without a special socket (made by Irwin). Once you get the bad lug nut off with your Irwin tool you throw that lug nut away because you have destroyed it. I don't normally get excited about lug nuts, but I am very agitated about the set that came on my trailer. I think they are borderline at best.
_________________
ProPride 3P
AIR# 58452
NorCal : 2015 Jackson Rancheria Fally Rally October 9-11, 2015 Coastalview Forum Rallies & Meet Ups 48 05-30-2017 01:49 PM
Question for owners of late model Ram 2500 6.7 Cummins Diesel Owners SteveH Tow Vehicles 110 03-09-2015 12:43 AM
2015 MOUNTAIN AIR Rally April 17-20 2015 shermantic Forum Rallies & Meet Ups 2 01-13-2015 07:43 AM
2015 Classic news Firedog1 Airstream Trailer Forums 7 01-06-2014 05:37 PM
