Old 02-05-2015, 12:04 PM   #351
Everyday is a GIFT !!
Nelson428's Avatar
2015 30' Classic
Collins , Mississippi
Send a message via AIM to Nelson428
Firedog1, i like the Polk system, however i use the Bose Wave System III in my bedroom (personal addiction) and the SoundLink® Bluetooth® speaker III
J. Nelson
WBCCI # 5314
J. Nelson
TAC # MS-12
WBCCI # 5314
AirForums # 66116
Nelson428 is offline   Reply With Quote
Old 02-05-2015, 12:06 PM   #352
Nelson428's Avatar
2015 30' Classic
Opps, i hit sent by mistake, I use the SoundLink® Bluetooth® speaker III outside.
J. Nelson
WBCCI # 5314
J. Nelson
TAC # MS-12
WBCCI # 5314
AirForums # 66116
Old 02-06-2015, 01:13 PM   #353
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
I've asked this elsewhere. Is the cabinetry in the Classic Cherry or ash or some other hard wood finished in Cherry? We did our Bambi II in real Cherry and it was pricy.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 02-06-2015, 02:00 PM   #354
Images: 59
My goodness BAB. It looks like a yacht on wheels.
Old 02-06-2015, 05:11 PM   #355
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
It is my understanding based upon posts by owners of 2015 Classics that the wood is solid cherry.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 02-06-2015, 05:39 PM   #356
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The wood is real Cherry.
Old 02-06-2015, 05:42 PM   #357
DFlores's Avatar
1968 22' Safari
Just thought I'd post on this thread just to see what the high rent district feels like
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 02-06-2015, 05:44 PM   #358
Well Preserved
1993 21' Sovereign
Well, the payments on yours are probably significantly less...
Old 02-06-2015, 06:46 PM   #359
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
Originally Posted by BAB View Post
For those of you with new Classics, here are some pictures of what the interior looks like when you get deeply into personalized upgrades. I have a panel of switches and monitors mounted in the closet. As of now, I don't know what all the switches (12V and 120V) will be used for, but I have color coded wires in place. I did assign the orange wire to three very quiet and low amp muffin fans that you'll see up in the fridge vent. Obviously, I took the refrigerator out because the space behind it provides a great space for my solar controller (the monitor is on the panel in the closet). Also, I have installed an ice maker in my freezer...this 9 cu ft model IS available with an ice maker, but not something we could special order. Simple installation, water will come from PEX going to the o/s shower. BTW, removing the fridge is not for the faint hearted, it is the tightest fit you can imagine, which you want, of course, due to the combustion going on behind it -- no leakage into the cabin. I am MORE and MORE impressed with the construction. Everything perfectly sealed and caulked. An important finding. The electrical panel, once unscrewed from its space, was cleverly done. There is about 3 feet of wire tucked behind it, so you can access every single wire you'd ever want to access. This is great news for those who want to do modifications. I finished up the evening by completing installation of a Progressive Industries electrical monitor/surge protector. Took about 2 hours....primarily because that 50 AMP wire is so incredibly hard to work with. It was necessary to unwire the 50 AMP service from the panel and put it into the PI module. Then I took the exact same type of wire (available at Lowes), and ran it from the output side of the module into the A/S main 50 AMP panel. After plugging it in I was gratified to find that my home 50 AMP panel was wired correctly!
Tomorrow I'll be hooking up the Sat TV. Next will be solar. Then the 4 Lifeline 6V's, and the Magnum MSH.
Vacation, anyone??
WOW! Very impressive! We can't wait to see it!
Get involved and sign up for a Rally!
http://www.airforums.com/forums/calendar.php
WBCCI 4973
blmitch5 is offline   Reply With Quote
Old 02-06-2015, 07:35 PM   #360
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
...but has Catherine's Landing recovered from last year's rally???
As you can see from the photos, yes, the Sat TV did get hooked up, and you can see the proof in the shot of my TV screen. Not sure I would have opted for this if i hadn't read a couple of very positive reviews on AF! Cool to watch it motor up off the roof and find the satellite signals.
Completed wiring and test-out of the WiFi Ranger and the Wilson cell amplifier.
Tomorrow, we will fill water tanks and do an overnight shakedown in Charlotte at my son's house. Did this with the last Airstream as well....and TRADITION is important in my family.
ID:	231857   Click image for larger version
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 02-06-2015, 08:30 PM   #361
Silverbee's Avatar
2015 28' Flying Cloud
2012 25' Flying Cloud
2007 20' Safari SE
Fuquay Varina , North Carolina
I noticed today when I installed the Maxim Skylights that there was an enormous improvement in the box that the Maxims fit over. They are now using a high end aluminum box rather than the flimsy jerry-rigged "panel aluminum" that they used on my '12 Intl CCD.
Barry:
Did you have to remove the original skylights and measure for David to make the new Maxims, or are the measurements now standard so that you can just order for your model? When we did Maxims on our 2012 Flying Cloud, we had to measure first. We need to start the process to order the Maxims for our 2015. Also, did you replace the Fantastic Fans or do you plan to or not?
Tom
Silverbee is offline   Reply With Quote
Old 02-07-2015, 06:21 AM   #362
Remax gal's Avatar
2014 27' FB Eddie Bauer
Lake Placid , Florida
The tv even looks better against that cherry cabinet!!
Laura & Tom
Let the good times roll!! Laura
Remax gal is offline   Reply With Quote
Old 02-07-2015, 07:04 AM   #363
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
They handed me a snifter of brandy when I first posted... And try the foie gras with green onions in duck jus while you're here. It is to die for. I'm starting to like it in this thread...
-Red, hoping he used "snifter" correctly...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 02-07-2015, 07:49 AM   #364
Firedog1
Firedog1's Avatar
2018 30' Classic
Woodbridge Connecticut & , Venice Florida
Hey BAB. What is the other antenna? Is that for WiFi? I need to improve my WIFI. How about a review on WiFi Ranger
Russ and Lisa
2018 Classic 30
2015 F250 King Ranch 4x4 turbo diesel
Sold but not forgotten: 2005 Classic 25 Limited
2015 Classic 30 RB
Firedog1 is offline   Reply With Quote
NorCal : 2015 Jackson Rancheria Fally Rally October 9-11, 2015 Coastalview Forum Rallies & Meet Ups 48 05-30-2017 01:49 PM
Question for owners of late model Ram 2500 6.7 Cummins Diesel Owners SteveH Tow Vehicles 110 03-09-2015 12:43 AM
2015 MOUNTAIN AIR Rally April 17-20 2015 shermantic Forum Rallies & Meet Ups 2 01-13-2015 07:43 AM
2015 Classic news Firedog1 Airstream Trailer Forums 7 01-06-2014 05:37 PM
