03-21-2016, 07:46 PM
2016 30' Classic
Houston
'16 Classic Wheel Nuts
Just took possession of our new Classic. Very exciting. Was checking the unit's wheel nuts to make certain they were properly torqued having read that caution in numerous places. I fear I may have bent or somehow mis-shapen two of the nuts with the torque wrench's socket - perhaps the socket was not properly seated fully on the nut.
Have any of you had similar problems? Any ideas as to how to remove?
The nuts seems to have a soft outer cover - thinking about replacing them with a stronger nut.
Any thoughts would be appreciated. Dennis
03-21-2016, 08:21 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Welcome Aboard....
I found that a 6 point 1/2" drive socket works best in removing the cheep OEM lugs.
I replaced ours with McGard US made replacements....located right here in WNY.
03-21-2016, 08:31 PM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Replaced the extremely cheap Airstream lug nuts with these on all three of my Airstreams which doing the tire conversions:
McGard 24138 Chrome Cone Seat Wheel Locks and McGard 64010 Chrome Bulge Cone Seat Style Lug Nuts (1/2" - 20 Thread Size) phone 800-444-5847 from Amazon
No more issues with lug nuts. I ordered spare "key sockets" directly from McGard.
03-22-2016, 06:02 AM
2016 30' Classic
Houston
Robert, thank you and others for your prompt reply. Re your recommended "6 point 1/2" drive socket", what socket size do you recommend? Metric or inch-defined. Thanks.
03-22-2016, 06:26 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
A 3/4" six point socket is the correct size for. !/2" drive is also the best for a heavy duty torque wrench or breaker bar.
The Airstream OEM lug nuts are especially junky. I think that they use these to compliment the junky Goodyear Marathon tires.
When I upgraded my brand new 25FB with Michelin 16" tires, I also upgraded to the McGard solid lug nuts.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
03-22-2016, 07:30 AM
Firedog1
2018 30' Classic
Woodbridge Connecticut &
, Venice Florida
agree with Switz, replace with McGuard ASAP
Russ and Lisa
2018 Classic 30
2020 GMC Sierra 3500HD Denali Diesel 4x4
Sold but not forgotten: 2005 Classic 25 Limited
2015 Classic 30 RB
03-22-2016, 09:13 AM
2016 27' Flying Cloud
Olympia
In torquing my lug nuts, one of them "cracked," and I found that they are two-piece nuts: an inner, steel nut with an outer chromed cap, the latter of which split and left me unable to remove the nut. The cap easily slipped off. After a lot of experimentation, I found that the inner, steel nut was easily removed with a 18 mm, 6-point socket. The capped nuts are removed with a 3/4 inch socket. I've ordered new, one-piece nuts from Amazon:
http://www.amazon.com/gp/product/B00...ilpage_o00_s00
24 nuts for $20
Richard Wills, Olympia, WA --- WBCCI 8873, WL7Z
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
RIP "BigDog": M Harlequin Great Dane, 150 lb
"St. Rocco": M Black Great Dane, 150 lb
03-22-2016, 11:15 AM
2013 30' Classic
Greenwood
, Mississippi
Beat the socket on to the lug nuts to get them off.
Get 24 new chrome lug nuts- not the ones with the cheesy chrome cover-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
03-22-2016, 12:50 PM
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario
, Ontario
Where is WNY???
03-22-2016, 12:52 PM
Blenheim Ontario
, Ontario
Originally Posted by robert cross
i found that a 6 point 1/2" drive socket works best in removing the cheep oem lugs.
I replaced ours with mcgard us made replacements....located right here in wny.
ditto!
03-22-2016, 01:02 PM
Blenheim Ontario
, Ontario
Most of the replies here were very good informations, but don't forget to use a calibrated torque wrench as per proper protocol, and ensure the studs do not have any lube on them of any kind.
If you do lube the studs, be sure that you know HOW to torque them, as the lube changes the friction factor significantly. (damaged or broken studs.)
03-22-2016, 01:26 PM
2015 30' Classic
2012 28' International
Greensboro
, North Carolina
Like others who have already posted, I ended up replacing all the lug nuts with the McGard's. You most definitely do want to use a high quality torque wrench, and you'll need to recheck the torque after driving on the newly installed lug nuts -- several times -- as they will seat into the wheels. I would NOT use any lube on a lug nut. BTW, I ended up having to use a nut extractor on one of the original lug nuts. Despite my best efforts and high quality sockets, one lug nut's cheesy chrome covering simply dissolved.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
03-22-2016, 05:25 PM
2021 25' Globetrotter
Oracle
picking up our Classic in 2-3 weeks (weather dependent) and I might as well be prepared- how many lug nuts do I need to order?
03-22-2016, 06:12 PM
2013 25' International
Corolla
, North Carolina
Check Amazon for McGard solid lug nuts. And always use a six point socket when torqueing.
03-22-2016, 07:19 PM
Retired.
, At Large
24.
AND TORQUE THEM TO 110 Ft/lb!
03-22-2016, 08:22 PM
2014 31' Classic
Apache Junction
Or order four locking lug nuts and 20 regular lug nuts.
McGard 24138 Chrome Cone Seat Wheel Locks and McGard 64010 Chrome Bulge Cone Seat Style Lug Nuts (1/2" - 20 Thread Size) phone 800-444-5847 or from Amazon
