Old 11-08-2011, 02:21 PM   #1
tdmaymac's Avatar
2011 27' FB Flying Cloud
Moschelle , Nova Scotia
Winterizing Question from a First-Timer
Last weekend, I undertook my first winterizing of my 2011 Flying Cloud and things seemed to go as planned. However, I am curious to know whether it is better to keep my batteries in place in the trailer with a continuing 110V connection from my house or to take the batteries out for the winter and store them in my basement. I don't own a stand-alone trickle charger, so the indoor storage of the batteries might lead to their eventual depletion if I don't have a way to recharge them, correct? If I do keep them in the trailer for the winter (which is stored outside on my property), I believe I need to check the water level periodically so they don't run dry. I'd appreciate any advice you may offer as to what works best for you. Thanks.
Tom
tdmaymac is offline   Reply With Quote
Old 11-08-2011, 02:49 PM   #2
dznf0g's Avatar
Oswego , Illinois
If I were going to keep the trailer plugged in all winter, I would unplug the converter from the wall and get a BatteryMinder Plus and keep the batts maintained with that. That is, unless you have thrown out that Parallax converter the trailer came with. If you have upgraded to a quality 3 stage charger, you'd be fine with just keeping it plugged in and connected to the batts.
I would put your disconnect switch on the off position if you go the BatteryMinder route.
-Rich-
Old 11-08-2011, 02:59 PM   #3
I agree, remove the batteries and store them at room temperature not on concrete, disconnect the battery lines and trickle charge them from time to time or upgrade your converter to a three stage charger. The stock Paralax converter has only a high level of charge and will fry the batteries if left plugged in all winter.
handn is offline   Reply With Quote
Old 11-08-2011, 03:40 PM   #4
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
I haven't tossed the Parallax yet (expect to have that done by the weekend). What has worked for me was to let them charge for 24 hours when I did my winterizing routine which included checking the electrolyte levels, then put the battery switch to Store. I then put a day each month on my calendar to change the switch from Store to Use and flipped it back the next day. Since I also keep the trailer at the house, this is convenient to do.
If you have a true 3 stage converter, it can be left on through the winter. As others have suggested an alternative is to bring them in... They still need to be charged every 30 - 60 days as lead acid batteries discharge on their own. The regular charge cycles brings the electrolyte to a slight boil which keeps the batteries from stratifying and forming sulfate crystals. Some of the 3 stage converters have a built-in desulphation cycle that periodically bumps the voltage up briefly to accomplish that goal.
AIR 47751
Silver Goose is offline   Reply With Quote
Old 11-08-2011, 03:51 PM   #5
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
Interstate Batteries, and I believe that's what you have in your unit, says this (I called them).
The batteries themselves will not freeze as long as they are charged. And they are good safe from damage, way below zero.
It gets down to the proximity of the trailer to your shore power, and as long as you recharge them once a month (for about 24 hours), you're good to go.
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 10-11-2012, 06:47 PM   #6
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
It has been about a year since the last response in this thread - don't know if folks are still watching....but here goes...
We plan to purchase the FC 27FB next spring and intend to do long weekends monthly (say MAy through Oct) then store for the winter in New England. We have been looking at a storage space for RVs that is uncovered and without electricity. Reading this thread made me wonder whether that's a good or bad idea. IF we did this, would we need to remove the batteries and store them at home with a charger? Thanks for any insights for we not-even-qualified-to-count-as-newbies-yet!
Old 10-11-2012, 06:53 PM   #7
dznf0g's Avatar
Oswego , Illinois
Welcome, Steve, Sue. Storing in New England with no power....definitely take the batts out and store them at home on a BatteryMinder Plus.
-Rich-
Old 10-12-2012, 12:35 AM   #8
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***
We take our batts out and store inside for the winter - charging them every couple of weeks for several hours and then disconnecting ... Montana is very cold in the winter!
2015 25' Eddie Bauer International Sp Ed
2017 GMC Yukon SLT; equalizer hitch
AIR# 44105; formerly WBCCI 2015.1
Terminal Aluminitis; 2-people w/ 2-dogs
Old 10-13-2012, 06:10 AM   #9
tdmaymac's Avatar
Steve and Sue -
I own a 2011 27' FB Flying Cloud in New England (Avon, MA) and happen to be writing this from the comfort of my Airstream on a cold (30 degrees) Saturday morning.
In answer to your first question, as noted by dznf)g, I take my batteries out and connect them to a BatteryMinderPlus. That does the trick.
I store my AS at an outdoor storage facility in Lakeville, MA. This has worked well. In fact, I just pulled it out of storage yesterday to bring it to a nearby KOA for the weekend so that I can winterize it.
If you would like to correspond directly with me about my AS experience thus far, you can reach me at tdmay@me.com. In our case, we've been very happy we made the leap.
Tom
Old 10-21-2012, 04:09 PM   #10
Travel Bird's Avatar
2012 27' FB International
Denver , Colorado
Does anyone have a list for this "Newbie" on how to winterize? We're picking up our new AS next month in NJ and driving it back to Denver. We found covered storage that does have electricity. I'm clueless where to begin on winterizing. Also, "IF" we want to take a trip, let's say in Feb/Mar/Arp perhaps, I'm assuming we still have to winterize, right? Thanks for all and any advise. Cheers!! Anna
Anna
Blog: Glamper~An Airstream Diary
www.glamperanairstreamdiary.com
WBCCI #4846, WBCCI DenCO Unit
Air #62992
Travel Bird is offline   Reply With Quote
Old 10-21-2012, 05:16 PM   #11
richinny's Avatar
2011 34' Classic
anna, while the folks here are great....have your dealer/seller walk you through the process. take written notes and make a video if possible. when the time comes you'll have the exact info you need for your trailer. don't just watch, move the levers yourself to see what it should feel like. also discuss with the dealer/seller what to do if the temps drop very low going home. a lot of folks i meet that head south for the winter, travel 'dry' if it gets very cold.
Ricky
Old 10-21-2012, 08:47 PM   #12
Denver , Colorado
Thank you!!!
Anna
Air #62992
Old 10-22-2012, 06:24 AM   #13
tdmaymac's Avatar
Anna -
I would recommend you buy a copy of the e-book (or paper version) of "The Newbies' Guide to Airstreaming" by Rich Luhr. This has a very good section about winterizing your Airstream. The ebook is available from Amazon as a Kindle book or from Apple's iBooks Store. I believe the paper version is available through the Airstream Life magazine site, as Rich is the publisher of that magazine.
I have a copy of the book on my iPad and it has come in very handy as I winterized my trailer each of the past two seasons. I just winterized my trailer last weekend and the key steps involve the following (don't rely on my list - get the Newbies book or search this forum for others' winterizing lists):
1. Remove all perishables from the trailer.
2. Remove anything else that could be made into a nest for animals wanting to use your trailer as a winter home.
3. Turn off the fridge, clean it out and use the plastic brackets to hold the doors open to air it out.
4. Empty the fresh water tank by opening all the faucets until the system runs dry (but don't let your water pump run for long without water flow)
5. Drain the black and grey water tanks (I do this at a local campground near my storage facility) and flush out the black water tank thoroughly.
6. Look for and open the drain valve for the fresh water tank. Open the "low point" valves under your trailer (they vary from trailer to trailer). Raise and lower your hitch to fully drain out water from these valves.
7. Drain your hot water tank. Bypass the tank after draining and before adding antifreeze to your fresh water lines (otherwise, you'll up putting antifreeze into the hot water tank.
8. Add RV antifreeze to your fresh water system (some advise clearing your water lines if you have easy access to an air compressor to blow all the water out of the lines). To add the antifreeze, I've found that it is very helpful to install a valve upstream of the water pump so that you can add antifreeze at that point. These kits are available at RV service centers if you don't already have such a setup. I usually end up pumping in about two gallons of the antifreeze (available also at the RV service center)
9. Make sure the drain traps receive about one cup of the antifreeze to protect them.
10. Shut off the propane tanks.
11. Remove the batteries for the winter and place them indoors where they can be put on a trickle charge system (look for a BatteryMinderPlus device at Camping World, for example).
Others will add to or correct what I've listed, but this gives you an idea what is involved. I think the procedure is best done in the morning to make sure you have plenty of daylight and don't run out of time. It should take you about 1/2 half day, assuming you don't run into issues. Please don't rely on what I've just listed as a guide. It is just to give you an idea. And don't be intimidated by the length of the list. Have your cell phone handy to call your Airstream dealer if needed. That's another reason to start this in the morning (and not on a Sunday to avoid having the dealer's service center be closed). Good luck.
Tom (still a newbie too)
2011 27' Flying Cloud
Old 10-22-2012, 09:13 AM   #14
Denver , Colorado
Originally Posted by tdmaymac View Post
Anna -
Thank you so much, Tom!!! I will help a great deal and I will pull out my Newbie's guide before the big trip and read it again. I had forgotten all about it and the info. on winterizing. Cheers! Anna
Anna
Air #62992
Steel / Aluminum wheel question polarlyse Wheels, Hubs & Bearings 12 05-29-2011 07:49 PM
1980 Caravelle axle question Seymour Axles 5 05-14-2011 08:28 PM
EVAP Canister? question 8rmesse Classic Motorhomes 23 04-24-2011 06:41 AM
Blasphemous question woytovich General Repair Forum 15 04-09-2011 08:36 AM
Trailering Question Cracker Jacks, Stabilizers, Lifting and Leveling 14 01-02-2011 02:55 PM
